    [term_id] => 14
    [name] => Synopsys
    [slug] => synopsys
    [term_taxonomy_id] => 14
    [count] => 823
    [cat_ID] => 14
    [category_count] => 823
    [cat_name] => Synopsys
Synopsys silicon innovation banner
    [term_id] => 14
    [name] => Synopsys
    [slug] => synopsys
    [count] => 823
    [cat_ID] => 14
Customized Foundation IP Enables the Next Generation of Automotive Compute
by Kalar Rajendiran on 06-09-2026 at 10:00 am
chip design for blog foundation ip
As vehicles become increasingly software-defined, automotive semiconductor suppliers face growing pressure to deliver higher compute performance while maintaining strict requirements for power efficiency, reliability, and long-term product support. Advanced driver assistance systems (ADAS), electrification, vehicle networking, and intelligent control systems are all driving greater computational demands across automotive platforms.
While advanced process nodes continue to improve performance and density, scaling alone is no longer enough. Automotive designers must balance increasing compute demands against stringent reliability standards, extended product lifecycles, and challenging operating environments. As a result, many companies are exploring how advanced process technologies and application-specific optimization can work together to enable the next generation of automotive compute.
Why FinFET Matters for Automotive SoCs
As automotive compute requirements continue to rise, the limitations of traditional planar technologies have become increasingly apparent. Achieving higher performance often comes with greater power consumption, increased leakage, and diminishing area efficiency.
FinFET technology helps address these challenges through improved transistor control, enabling higher performance, lower leakage, and better power efficiency. These advantages make FinFET an attractive path for automotive semiconductor suppliers seeking to support next-generation workloads while maintaining demanding quality and reliability requirements.
Automotive Reliability Creates Unique Challenges
Despite its benefits, FinFET adoption introduces additional complexity. Automotive devices must support long service lifetimes, operate across broad voltage and temperature ranges, and meet stringent quality expectations with extremely low defect rates.
As a result, transitioning to FinFET is not simply a process migration. Logic libraries, embedded memories, characterization flows, and reliability methodologies must all be validated for automotive-grade operation. Success requires a coordinated approach that addresses technology, IP, characterization, and reliability together.
Synopsys Customized Foundation IP as an Enabler
Many automotive applications require optimization beyond standard IP offerings. Power budgets, leakage targets, operating conditions, and reliability objectives often demand additional customization to meet product-specific requirements.
Building on the proven capabilities of Synopsys Foundation IP, customization of these IP enables logic libraries, embedded memories, and characterization views to be tailored for specific automotive requirements. This approach helps design teams achieve demanding performance and efficiency targets while accelerating adoption of advanced process technologies.
Customer Engagements Illustrate the Value of Customization
Recent customer engagements demonstrate how customized Foundation IP can help automotive semiconductor suppliers navigate advanced-node transitions.
In one collaboration, a leading automotive semiconductor company sought to deploy a next-generation SoC portfolio on an automotive-qualified FinFET process. While standard Synopsys Foundation IP provided a strong starting point, requirements for ultra-low leakage, expanded characterization coverage, and stringent internal reliability targets required additional customization.
Working closely with the customer, the Synopsys Foundation IP team leveraged its proven IP portfolio and extended process, voltage, and temperature characterization to better reflect automotive mission profiles while optimizing memory solutions for low-power operation and reduced leakage. The collaboration also expanded to include enhanced reliability analysis and measurement methodologies, combining the customer’s application expertise with Synopsys IP design and characterization experience.
The resulting solution enabled the customer to advance its FinFET roadmap with confidence while meeting aggressive performance, power, and reliability objectives.
What These Engagements Reveal About Automotive Node Adoption
A broader lesson emerging from these collaborations is that advanced-node adoption in automotive markets is increasingly a system-level challenge.
Success depends not only on transistor technology, but also on aligning IP development, characterization, reliability methodologies, and implementation flows around application-specific requirements. Synopsys customized Foundation IP serves as a key enabler in this process, helping engineering teams optimize performance, power, and reliability simultaneously.
Thei engagement also highlights the value of close collaboration between semiconductor suppliers and the Synopsys Foundation IP team. By combining application expertise with proven IP and advanced characterization capabilities, teams can address requirements that standard solutions may not fully satisfy.
Enabling the Next Generation of Automotive Compute
As vehicles become more intelligent, connected, and software-defined, demand for advanced semiconductor technologies will continue to grow.
Customized Foundation IP helps bridge the gap between advanced process capabilities and automotive-specific requirements. Through proven IP, customization expertise, and close engineering collaboration, automotive semiconductor suppliers can unlock the full value of FinFET technology while maintaining the quality and reliability standards expected in automotive markets.
FinFET technology offers significant opportunities for automotive semiconductor suppliers pursuing higher performance, greater efficiency, and increased integration. Realizing those benefits, however, requires more than adopting a new transistor architecture.
Customer engagements demonstrate that Synopsys customized Foundation IP, combined with extended characterization, reliability-focused methodologies, and collaborative engineering support from the Synopsys Foundation IP team, can help organizations successfully navigate advanced-node transitions. By optimizing across the design stack, semiconductor companies can accelerate innovation while delivering the reliability and longevity required for next-generation automotive systems.
Visit Synopsys Foundation IP page.
Synopsys and Samsung Foundry Extend AI-Driven Design Collaboration for Advanced 2nm and Multi-Die Systems
Intel: Pushing EMIB Forward: Design Methodology Insights with Synopsys Tools
The Great Divide: A Tale of Three Hardware Emulation Architectures
