MOUNTAIN VIEW, Calif., Oct 15, 2019 /PRNewswire/ --
Highlights:
With the differentiation available through native automotive solutions, designers can generate the industry's first FuSa intent early in the design flow to describe safety mechanism behavior, which is used as input and maintained throughout the digital design flow. Synopsys' native automotive solutions comprise a complete digital design flow incorporating FuSa-enabled technologies, which work together to maximize efficiency. These technologies include:
Synopsys Automotive Design Solutions
Synopsys' comprehensive automotive design solutions deliver complex FuSa analysis, implementation, and verification capabilities. Differentiated offerings for automotive design, such as unified functional safety verification and native automotive solutions, enable designers to prove at the planning and implementation phases that their chip safety architecture can achieve target ASILs. The unified functional safety verification solution brings together best-in-class technologies for fault campaign management under a single unified cockpit. Early functional safety analysis can quickly identify candidates for TMR and DCLS redundancy and estimate metrics for target ASILs. Synopsys' native automotive solutions provide the industry's most comprehensive feature set to efficiently implement and verify FuSa mechanisms, such as TMR, DCLS, and failsafe FSM. Comprehensive digital/analog fault injection and simulation can be performed to produce reliable metrics for final analysis and roll-up. Synopsys also provides complete solutions to address reliability challenges, including electromigration (EM), voltage (IR) drop, device aging, and robust redundant via insertion (RVI) capabilities. Synopsys provides designers with a broad portfolio of automotive IP that is designed and tested for AEC-Q100 reliability, offers ASIL-ready ISO 26262 certification, and supports automotive quality management.
Furthermore, Synopsys' unified functional safety verification solution includes:
Synopsys' native automotive solutions will be generally available in December 2019.
For more information, please visit www.synopsys.com/automotive.html.
About Synopsys
Synopsys, Inc. (Nasdaq: SNPS) is the Silicon to Software™ partner for innovative companies developing the electronic products and software applications we rely on every day. As the world's 15th largest software company, Synopsys has a long history of being a global leader in electronic design automation (EDA) and semiconductor IP and is also growing its leadership in software security and quality solutions. Whether you're a system-on-chip (SoC) designer creating advanced semiconductors, or a software developer writing applications that require the highest security and quality, Synopsys has the solutions needed to deliver innovative, high-quality, secure products. Learn more at www.synopsys.com.
Editorial Contact:
James Watts
Synopsys, Inc.
650-584-1625
jwatts@synopsys.com
SOURCE Synopsys, Inc.
Highlights:
- Synopsys' native automotive solutions enable designers to efficiently implement and verify functional safety mechanisms to achieve target ASIL for safety-critical SoCs
- Synopsys' differentiated solutions enable designers to avoid custom scripting solutions and improve runtime, job-execution capacity, quality-of-results, and ease-of-use
- TestMAX FuSa performs early functional-safety analysis at RTL- or gate-level and identifies candidates for TMR or DCLS redundancy to achieve single-point fault metric (SPFM) goals for target ASIL
- Design Compiler® NXT synthesis, IC Compiler™ II place-and-route, and Fusion Compiler™ design insert, check, and report the safety mechanisms implemented
- Formality® equivalence checker functionally verifies that the RTL matches the netlist after redundancy or additional logic modules are inserted
- IC Validator physical signoff verifies the layout and reports that all redundancy mechanisms are correctly implemented
- VC Functional Safety Manager, a high-quality, scalable, and distributed FMEDA automation tool delivering the highest productivity through the FMEA/FMEDA and unified fault campaign process
- TestMAX FuSa performs fast, early functional-safety analysis at RTL- or gate-level
- Z01X™ fault simulator for fast, proven digital fault simulation
- VC Formal™ FuSa App to accelerate fault classification through application of formal filtering
- TestMAX CustomFault™ fault simulator delivers high-performance analog and mixed-signal fault simulation for full-chip functional safety and test coverage analysis
- ZeBu® emulator performs fault emulation for long, software-rich tests
- Verdi® Fault Analysis for debug, planning, and coverage, including integration with industry-leading requirement tracking tools
- Certitude® functional qualification to demonstrate verification flow robustness in support of ISO 26262 Part 8-9 assessments
About Synopsys
Editorial Contact:
James Watts
Synopsys, Inc.
650-584-1625
jwatts@synopsys.com
