Ann Wu is Co-founder & CEO of Silimate. Before Silimate, Ann designed several generations of custom silicon at Apple, helped manage inference ASIC programs at Meta, and led product strategy and execution at Celestial AI. Ann has a M.S. in Electrical Engineering from Stanford University and a B.S. in Electrical Engineering from University of Illinois Urbana-Champaign.
Akash Levy’s Bio is Co-founder & CTO of Silimate. Akash’s technical expertise spans EDA, AI, and cloud computing through his time at Synopsys, NVIDIA, and AWS. He has taped out three chips, published 14 papers on circuit design, and holds two patents in the EDA space. Akash has a PhD in Electrical Engineering from Stanford University and a B.S. in Electrical Engineering from Princeton University.
Tell us about your company.
We build AI-native tools and agents for fast, efficient chip design and debug. Our tools are licensed by Fortune enterprises and chip unicorns, where they accelerate frontend iteration and convergence by orders of magnitude.
With Silimate, chip companies can achieve PPA-optimized, functionally correct IP in days instead of weeks or months. Our mission is to enable autonomous, spec-to-freeze-ready RTL in three months instead of the current 12–18 months. Our goal is to help chip companies build better chips, faster.
We were founded in 2023 and became profitable for the first time in 2025. Our current areas of focus are frontier R&D, rapid product execution, and customer success. We’re based in Mountain View, California.
From an application perspective
We’re solving the two long poles in frontend digital design: PPA convergence and functional bug closure.
About 85% of the time and effort expended during a tapeout cycle goes toward closing the gap between the design’s current state and its specification targets. From a PPA perspective, that means resolving timing violations that could render the chip inoperable while meeting likely aggressive area and power budgets so that the chip is highly competitive. From a debug perspective, that means ensuring the chip works across all target customer workloads.
We enable PPA optimization on bleeding-edge designs and PDKs in hours or days instead of weeks or months. We also enable autonomous fixes for more than 70% of deep, complex functional bugs while using over 30% fewer tokens.
From a tooling perspective
We’re building a new category of critical, agent-native EDA tools that provide rapid PPA and debug feedback for agent-driven frontend workflows, enabling fast, always-on frontend agents.
Traditional EDA tools are not well suited to agent-driven chip-design and debug workflows because they take a long time to run and are heavyweight and complex to use. Fundamentally, agent workflows need fast, efficient feedback that can fit within individual agent sessions and context windows.
With agent-native EDA tools, agent-driven frontend workflows become faster, more token-efficient, more accurate, and fully left-shifted.
We currently deliver measurable results across frontend workflows.
Design and PPA
We see customers use Silimate in two stages:
- They execute much larger, more opportunistic design explorations to quickly discover, rank, and identify the best architecture or microarchitecture seed for their target PPA tradeoffs.
- They then deploy agents to iterate from that identified seed – or from an existing design snapshot – and rapidly converge on their specification targets.
Our north star is to enable chip companies not only to build chips faster, but to build better chips faster.
Debug
We see customers use Silimate to generate complete root-cause analyses on complex designs, where the underlying bugs are often far removed from the observed failure point.
Solutions such as Claude Code integrated with a waveform API are generally limited to simple, shallow bugs, often identified through grep-based workflows. By contrast, we research first-principles EDA methodologies that efficiently constrain, extend, and inspect the specific cones associated with a failure.
This methodology has produced successful one-shot root-cause analyses for bugs located many levels deep within the design, and it continues to evolve.
A few concerns come to mind:
- The risk of missing an imminent design-freeze or tapeout milestone
- Spiking token costs that do not always produce clear, measurable ROI
- The possibility that competitors are using AI more effectively than they are
- The fact that every new tapeout is becoming harder and riskier due to shrinking technology nodes, increasingly complex heterogeneous architectures, and other factors
The common answer to these concerns is that the industry needs fast, efficient design and PPA co-optimization. It needs systems that can accurately map the design space and stochastically descend toward the optimal microarchitecture for a target PPA tradeoff, given the architecture, workloads, and PDK constraints – all while co-optimizing for functional correctness.
What does the competitive landscape look like, and how do you differentiate?
We see three major components in AI-driven chip design: the agent harness, the integrated tools, and the underlying LLMs.
- Most efforts across the competitive landscape have focused on the agent harness. However, the moat around the harness is relatively thin, and many chip companies are increasingly investing in their own custom agent harnesses.
- The integrated tools are where we have invested significant effort. This is where we differentiate and deliver best-in-class ROI and results through our agent-native EDA tools.
- For the underlying LLMs, closed-source, state-of-the-art models remain best in class – and continue to improve – at the time of writing. We are also experimenting with fine-tuning models for design, PPA, and debug, as a nascent frontier.
What new features or technology are you working on?
We’re developing always-on frontend agents – across the harness, tools, and models – to support end-to-end, spec-to-freeze-ready RTL.
If you’re also interested in this new modality, please reach out to speak with us.
Reach out to us to schedule a meeting or demo:
https://www.silimate.com/contact
Interview with Simon Davidmann, AI + EDA Researcher and Former CEO of Imperas
CEO Interview with Ohad Agami of Hiveware
CEO Interview with Dr. Il Park of Primemas
Semiconductor Market Doubling in 2026 – Last Issue
