    [term_id] => 25005
    [name] => ChipAgents AI
    [slug] => chipagents-ai
    [term_taxonomy_id] => 25005
    [count] => 24
    [cat_ID] => 25005
    [category_count] => 24
    [cat_name] => ChipAgents AI
    [category_nicename] => chipagents-ai
Coverage Closure and Formal Verification at AI Speed
    [term_id] => 25005
    [count] => 24
    [cat_ID] => 25005
Agentic AI Is Reshaping Semiconductor Design
by Daniel Nenni on 09-21-2026 at 10:00 am
ChipAgents DAC2026 agentic ai
63 DAC TechTalk | William Wang, ChipAgents.ai & Nimay Shah, Analog Devices, Inc.
Artificial intelligence is moving rapidly from an experimental aid to a foundational part of semiconductor engineering. In a recent industry talk, leaders from ChipAgents and Analog Devices described how agentic AI could help chipmakers manage soaring design complexity, accelerate product development, and improve the likelihood of producing working silicon on the first attempt.
The central problem is an expanding gap between chip complexity and engineering capacity. Semiconductor designs now contain billions—and sometimes trillions—of transistors, while engineering teams are not growing at a comparable rate. Advanced chips can require hundreds of millions or even billions of dollars in research and development. A mistake discovered after fabrication may force an expensive respin and delay market entry. Meanwhile, engineers must interpret lengthy specifications, integrate numerous intellectual-property blocks, operate fragmented toolchains, and coordinate across architecture, design, verification, implementation, manufacturing, and validation.
REPLAY: Break the Timing Closure Bottleneck with AI
Agentic AI offers more than conventional code completion or question answering. Early generative-AI copilots produced useful but limited productivity gains because engineers still had to direct every action. Autonomous agents can instead interpret a goal, develop a plan, identify relevant files and tools, execute individual steps, and document their reasoning. Multi-agent systems extend this approach by dividing complicated work among specialized agents that examine specifications, RTL, testbenches, logs, and waveforms simultaneously. Like an engineering team conducting a bug-review meeting, these agents can exchange findings and converge on a likely root cause.
This capability is particularly valuable in verification and debugging, which consume a substantial share of semiconductor development time. ChipAgents reported cases in which bugs that previously required days or a week to isolate were identified within minutes. Such results suggest that AI can shorten individual tasks while also reducing costly iterations across the product lifecycle. Background agents could eventually run regressions continuously, categorize failures, investigate root causes, and support round-the-clock verification through automated development infrastructure.
Analog Devices emphasized that speed alone is not the ultimate objective. The company wants to increase “learning-cycle velocity”: the rate at which teams generate, evaluate, and refine possible designs. If engineers can explore fifteen architectures instead of four, they may begin implementation with stronger evidence and make better product decisions. AI can also help designers create higher-quality unit tests before handing work to verification teams, thereby improving collaboration and reducing downstream rework.
Successful enterprise adoption nevertheless requires more than purchasing a general-purpose model. Semiconductor companies need hardware-native platforms that connect securely with established electronic-design-automation tools and understand domain-specific representations, constraints, and workflows. Deterministic sign-off tools will remain essential; probabilistic AI reasoning must complement, not replace, formal checks and trusted engineering processes. Organizations also need rigorous benchmarks that evaluate model quality, agent orchestration, cost, and—most importantly—the correctness of real engineering outcomes.
Analog Devices described a practical “buy plus build” strategy. It partners with specialists for the underlying agent platform while retaining ownership of knowledge and capabilities that provide competitive differentiation. Adoption is led by experienced domain experts who become internal champions, establish benchmarks and governance, and then guide wider groups of engineers. This approach has helped the company reach thousands of daily users across its AI solutions.
The speakers ultimately presented engineers not as casualties of automation but as orchestrators of increasingly capable digital teams. Experts will define intent, exercise judgment, challenge outputs, and coordinate agents, while junior engineers may use the same systems to understand legacy designs and develop expertise faster. Important obstacles remain, including trustworthy hardware representations, outcome verification, data security, and the coexistence of generative reasoning with deterministic design requirements.
WEBINAR: Break the Timing Closure Bottleneck with AI
Bottom line: The direction is clear. To meet demand for more powerful, efficient, and specialized chips, semiconductor companies must rethink both their tools and their organizational structures. Agentic AI could become the industry’s next major abstraction shift, enabling engineers to spend less time navigating repetitive workflows and more time making the critical architectural and creative decisions that determine product success.
Webinar – ChipAgents Shows You How to Break the Timing Closure Bottleneck with AI
How Agentic AI Turns IC Engineers into Architects
NVIDIA Brings Agentic AI Toolkit to EDA
