100X800 Banner (1)
    [term_id] => 16126
    [name] => Lithography
    [slug] => lithography
    [term_taxonomy_id] => 16126
    [count] => 183
    [cat_ID] => 16126
    [category_count] => 183
    [cat_name] => Lithography
How Secondary Electrons Worsen EUV Stochastics
by Fred Chen on 10-06-2025 at 8:00 am
Increasing dose not only faces diminishing returns, but lets electron noise dominate over photon noise.
The EUV lithography community should now be well aware that rather than EUV photons driving resist chemical response directly, they release photoelectrons, which further release secondary electrons, that in turn cause the photon’s energy to be deposited over many molecules in the resist [1]. While this directly leads to a blurring effect which can be expressed as a quantifiable reduction of image contrast [2], this also leads to consequences for the well-known stochastic effects. The stochastic behavior in EUV lithography has often been attributed in large part to (absorbed) photon shot noise [3], but until now there has been no consideration of the direct contribution from the electrons themselves.
There is a randomness in the number of electrons released per absorbed EUV photon [4]. The upper limit of 9 can be taken to be the maximum number of lowest energy losses (~10 eV) from an absorbed 92 eV photon, while a lower limit of 5 can be estimated from considering Auger emission as well as the likely loss of an electron through the resist interface with the underlayer or the hydrogen plasma ambient above the resist. Intermediate values are also possible, e.g., two secondary electrons may precede an Auger emission, leading to 7 electrons total. Thus, unlike the classical split or thinned Poisson distribution which characterizes photon absorption [5], a uniform distribution of integers from 5 to 9 as the probability mass function can be reasonably used, at least as a starting point. Let’s now take a closer look at the statistics from such a distribution.
