    [count] => 776
    [category_count] => 776
    [count] => 776
Getting Faster DRC Results with a New Approach
by Daniel Payne on 02-04-2025 at 10:00 am
Key Takeaways
  • Traditional Design Rule Checking (DRC) methods struggle with the complexity of modern IC designs, creating runtime and resource bottlenecks.
  • The 'shift-left' approach in verification, as implemented by Siemens' Calibre nmDRC Recon, enables earlier checks that reduce debug time and improve efficiency.
  • Calibre nmDRC Recon focuses on local checks to quickly identify layout errors, allowing for faster iterations and significant reductions in hardware requirements.
As IC designs become increasingly complex, traditional Design Rule Checking (DRC) methods are struggling to keep up. The old “construct by correction” approach, initially developed for simpler, custom layouts, is creating substantial runtime and resource bottlenecks. Traditional DRC relies on an iterative, sequential approach that is not well-suited for today’s automated and multi-layered design hierarchies. New methodologies, such as the “shift-left” approach, are helping to address these challenges. This blog post will explore how Siemens’ Calibre nmDRC Recon, has enabled a shift-left strategy, that allows for faster DRC, maximum check coverage, and minimal hardware usage.
Traditional DRC
Traditional DRC methods involve a manual process where layout designers create shapes, identify violations, and make corrections. While this worked well for simpler designs at larger process nodes, it’s not efficient for today’s automated design environments and smaller process nodes. In modern designs, components are routed individually, and then again at the top-level, plus the final design is assembled at different stages of readiness. Design teams typically run all design rules on all available layouts and then review individual results one-by-one, adjusting as needed. This iterative process can be extremely time-consuming, especially with the complexity of today’s advanced process design rules. Designs are often made up of multiple IP blocks designed by different teams on different timelines, which makes it difficult to have a fully assembled design for full verification. This leads to longer runtimes and higher compute requirements.
Shift-Left Approach
A better approach is to shift verification steps to earlier stages of the design process, significantly reducing debug time and expediting time to tape-out. Calibre nmDRC Recon is designed for early layout, whether at the IP, block, or chip level. It uses AI techniques to identify and run only those rules that are local in scope, meaning those that do not require checking across long distances or hierarchy. By focusing on local checks, Calibre nmDRC Recon significantly reduces runtime and hardware requirements.
Run time improvements using Calibre nmDRC Recon
Memory Improvements using Calibre nmDRC Recon
The checks are local, so the root-cause of errors are usually close to where the errors are reported. This allows designers to quickly identify and fix system layout issues like floorplan, cell placement, or chip finishing errors. Calibre nmDRC Recon also allows designers to enable or disable certain rules or specify layers that have been changed to automatically enable all dependent rules. Identifying and fixing root-cause problems early on eliminates many individual DRC errors, further reducing the debug time.
Running a subset of checks might seem counterintuitive, but it can reduce overall iteration time. The reason is that gross root-cause problems can be fixed quickly based on local checks. Rules requiring a more global scope, such as those that depend on connectivity information, can be addressed later. For these more global rules, Calibre nmLVS can help by identifying shorts early, ensuring that subsequent DRC iterations are more effective.
Using Calibre nmLVS Recon early in the flow
Full DRC checking is still necessary for final tape-out, however using techniques like split-deck runs, where checks that require significant runtime or hardware are run in parallel, overall performance can be improved. Using Calibre interactive, the individual results from each split can be combined into a single DRC results database.
Incomplete Designs
Another challenge is dealing with incomplete designs, as IP blocks of a design are not always ready at the same time. Using a combination of Calibre nmDRC Recon and Calibre nmDRC auto-waivers feature can be used. This allows designers to identify incomplete regions and exclude them from checking using markers. This “gray-boxing” technique allows designers to focus on their specific components of interest while still considering only the context of interest from clean layouts. By eliminating geometries, there is the risk of creating false errors, but the auto-waiver feature allows those errors to be removed so designers can focus on their specific component without impacting other areas of the design.
Gray-box Regions
Gray-box Regions
Specified regions
Specified regions
Combining Recon and auto-waivers has proven to be significantly faster than traditional methods for design layout generation and final tape-out.
Microsoft
Microsoft used Calibre nmDRC Recon to accelerate their DRC process, achieve maximum check coverage, and minimize hardware use. They started using Calibre nmDRC Recon iterations at the floorplan stage and then at the physical implementation stage. By that point, most of the designs were clean of PG shorts.
Shorter run times
Shorter run times
Microsoft found that DRC Recon improved their early design stages, as it provided a solid foundation for pinpointing violations efficiently and significantly reduced runtimes. By adopting the shift-left approach with Calibre nmDRC Recon and auto-waivers, Microsoft was able to significantly reduce runtime, hardware requirements, and debugging time.
Conclusion
The shift-left verification strategy, using tools like Calibre nmDRC Recon is critical for addressing the challenges of complex IC designs. By focusing on local checks early, using techniques like auto-waivers, and leveraging split-deck runs, design teams can achieve faster and more efficient IC design. Microsoft showed the benefits of this approach, emphasizing the importance of adopting shift-left verification for achieving faster time-to-market.
Read the 10 page paper online.
