            [0] => /forum/threads/system-verilog-which-final-is-final.2538/
System Verilog : Which final is Final ?
Dear Reader,
Recently I posted one blog post “System Verilog Final Means Final !”
As we all know final means final in system Verilog, Final block will get called at the end of the simulation before $finish. Now with this understanding we can have few questions. Recently I have received an request and some question on the same like and thought of answering those questions.
  1. Is multiple final block is allowed in System Verilog?
  2. If yes, what will be the execution order in simulation, which final is final?
Here are the answers to these questions :
Multiple final blocks are allowed in system Verilog, you can define multiple final block in your testbench. Some time you might require to use final blocks in different places of environment. Here we need to understand one most important thing on final block is that, final blocks are called at the end of the simulation before $finish. It is like a calling a function which executes in zero simulation time.
If you have multiple final block in your testbench all final blocks are called at same simulation time before your simulation ends. Let’s take an example to have better understanding:
program ankit_with_ankit;
class final_test;
task final_activity();
$display (“ASIC With Ankit 1 @%t”,$time);
#10;
$display (“ASIC With Ankit 2 @%t”,$time);
endtask
endclass
initial begin
final_test ft;
ft = new;
ft.final_activity();
end
final begin
$display (“ASIC With Ankit 3 @%t”,$time);
end
final begin
$display (“ASIC With Ankit 4 @%t”,$time);
end
endprogram
Simulation Result:
ASIC With Ankit 1 @ 0
ASIC With Ankit 2 @ 10
ASIC With Ankit 3 @ 10
ASIC With Ankit 4 @ 10
Here you can observe that I have used 2 final blocks in this simple exercises. You can have less or more based on your testbench requirement. When you run this with any simulator result will tell you all the final blocks will be called at same simulation time. So you could see all the messages for final blocks will be print at same simulation time. This is the reason you could see printing time for all the messages defined in the final blocks are 10ns.
So answer to question which final is final?’ is ‘All finals are final’!
I hope this will give you a more understanding on final block usage and execution. Comments, suggestions are welcome.
Happy Reading!
ASIC With Ankit
