            [0] => /forum/threads/phison-announces-successful-deployment-of-the-worlds-first-pci-sig-certified-pcie-5-0-redriver-ic-ps7101.16033/
Phison Announces Successful Deployment of the World's First PCI-SIG Certified PCIe 5.0 Redriver IC PS7101
Phison’s PCIe 5.0 Redriver IC PS7101 Achieves PCI-SIG Certification Milestone and Aims to Solve Compatibility Pain Points of High-Speed Transmission Between CPU and Peripheral Devices
Phison's redriver IC PS7101 is the world's first PCI-SIG certified redriver. (Graphic: Phison)
May 18, 2022 02:30 AM Eastern Daylight Time
SAN JOSE, Calif.--(BUSINESS WIRE)--Phison Electronics Corp. (TPEX:8299), a leading provider of NAND controller and NAND storage solutions integration services, announced today that it is successfully deploying the world's first PCIe 5.0 Redriver IC PS7101 certified by the PCI-SIG Association (Certified integrator list: Link) to help solve the compatibility problems of high-speed signal transmission between CPU (Central Processing Unit) and peripheral devices (such as SSD and graphics card, etc.).
“Phison is thrilled with the industry’s rapid adoption and deployment of the world’s first PCI-SIG certified PCIe 5.0 Redriver IC PS7101. Achieving the Association’s certification from the PCI-SIG Association is a significant industry endorsement and affirms Phison's commitment to innovation”
Tweet this
In the generation of PCIe 5.0 high-speed transmission, Redriver ICs will be required in devices such as desktop computers, servers, industrial computers, cables, and notebook computers. Depending on the degree of signal attenuation and the number of compensation channels, each system device will require 2 to 16 Redriver ICs. According to market research agencies, high-speed transmission signal enhancement ICs (including Redriver and Retimer ICs) will reach a market size of 50 million per year in 2025.
With the vigorous development of massive data, artificial intelligence, and cloud computing, demand for high-speed data transmission continues to rise. The CPU is the core of high-speed signal transmission. Under the leadership of CPU chip suppliers such as Intel and AMD, the transmission interface of the system has ushered the PCIe 5.0 generation, and the single-lane transmission speed reaching 32Gbps per second, which is twice that of the previous generation PCIe 4.0. However, in the high-speed transmission environment of PCIe 5.0, compatibility issues such as signal attenuation and noise effects on the motherboard have become common problems and challenges faced by all system integrators.
Phison is committed to the research and development of high-speed transmission interface technology and is one of the few IC companies with the capability to independently develop PCIe 5.0 PHY physical layer IP. The PCIe 5.0 Redriver IC PS7101 adopts Flip-Chip packaging and testing technology to reduce signal reflection and crosstalk interference caused by IC packaging, simultaneously improves the heat dissipation capability of the IC, which will effectively solve the problem of signal attenuation of high-speed transmission of the motherboard of the PC and the server platform or the riser card. It is an IC product with high gain, high linearity, and cost-effectiveness.
“Phison is thrilled with the industry’s rapid adoption and deployment of the world’s first PCI-SIG certified PCIe 5.0 Redriver IC PS7101. Achieving the Association’s certification from the PCI-SIG Association is a significant industry endorsement and affirms Phison's commitment to innovation,” said K.S. Pun, CEO of Phison. “In addition to PCIe 5.0 Redriver ICs, Phison is also actively developing a new generation of PCIe 5.0 Retimer ICs (sampling is expected to begin in the first half of 2023) for use in different system environments. Phison strives to strengthen its IC design capabilities that will create the market’s most reliable and complete high-speed storage and high-speed transmission solutions, and scale with global customers.”
Phison's PCIe 5.0 Redriver IC PS7101 provides multi-band independent compensation, allowing system R&D engineers to independently adjust parameters for different cable or PCB materials to achieve the best compensation for signal attenuation. In addition, Phison provides the exclusive patented Auto Tuning Tool, which can be used with SSD products designed by Phison. This automatically brings in different Redriver gain parameters in the customer's development environment and finds the corresponding optimal parameters, accelerating system integrators' products to market quickly.
Notably, Phison is one of the few suppliers delivering high-speed transmission ICs and also serves as a partner to provide customers with signal system analysis, simulation and compatibility issues. Phison’s goal is to equip customers with complete support solutions that solve technical problems encountered by customers in the development of high-speed interface platforms, to cooperate with the continuous development of new products from CPU chip manufacturers, and to enable the high-speed interface technology with increasing transmission speed to be used more widely on every platform.
Phison's PCIe 5.0 Redriver IC PS7101 is actively shipping samples, and has received system design recognition from many mainstream motherboard, server, industrial computer and cable developers. Mass-produced products by end customers are expected to be launched in Q3 2022.
[About PHISON]
Phison Electronics Corp. (TPEX:8299) is a global leader in NAND Flash controller IC and storage solutions. We provide a variety of services from controller design, system integration, IP licensing to total turnkey solutions, covering applications across SSD (PCIe/SATA/PATA), eMMC, UFS, SD and USB interfaces, reaching out to consumer, industrial and enterprise markets. As an active member of industry associations, Phison is on the Board of Directors for SDA, ONFI, UFSA and a contributor for JEDEC, PCI-SIG, MIPI, NVMe and IEEE-SA.
To know more about Phison, please visit Phison Website or Phison Q&A for details. Read our blog: phisonblog.com
[PHISON IR Distribution List Application Form]
If you would like to receive PHISON press release or announcement, please register our IR distribution application form from the link: Phison IR Distribution List
Contacts​
Phison media inquiries:
andrew@alanizmarketing.com
press_americas@phison.com
Phison product inquiries:
sales@phison.com
PHISON Deputy Spokesperson
Kuo-Ting Lu
TEL: 037-586-896 #2622
Mobile: 0979-075-330
Email: kuoting_lu@phison.com
PHISON Spokesperson
Antonio Yu
TEL: 037-586-896 #1019
Mobile: 0979-105-026
Email: antonioyu@phison.com
