            [0] => /forum/threads/keeping-moore%E2%80%99s-law-going-is-getting-complicated-cmos-2-0-will-require-exceptional-creativity-to-rewire-and-3d-stack-the-chip.18053/
Keeping Moore’s Law Going Is Getting Complicated CMOS 2.0 will require exceptional creativity to rewire and 3D-stack the chip
A disc with hundreds of darker squares attached in a regular array.
Three-D integration is just one of a number of techniques that will be essential to the future of CMOS—or, as some in the industry are beginning to call it, CMOS 2.0.
IMEC
3D INTEGRATIONMOORE'S LAWSYSTEM TECHNOLOGY COOPTIMIZATIONBACK-SIDE POWER DELIVERYNANOSHEET TRANSISTORSMICROCHIPS
There was a time, decades really, when all it took to make a better computer chip were smaller transistors and narrower interconnects. That time’s long gone now, and although transistors will continue to get a bit smaller, simply making them so is no longer the point. The only way to keep up the exponential pace of computing now is a scheme called system technology co-optimization, or STCO, argued researchers at ITF World 2023 last week in Antwerp, Belgium. It’s the ability to break chips up into their functional components, use the optimal transistor and interconnect technology for each function, and stitch them back together to create a lower-power, better-functioning whole.
“This leads us to a new paradigm for CMOS,” says Imec R&D manager Marie Garcia Bardon. CMOS 2.0, as the Belgium-based nanotech research organization is calling it, is a complicated vision. But it may be the most practical way forward, and parts of it are already evident in today’s most advanced chips.
How we got here​
In a sense, the semiconductor industry was spoiled by the decades prior to about 2005, says Julien Ryckaert, R&D vice president at Imec. During that time, chemists and device physicists were able to regularly produce a smaller, lower-power, faster transistor that could be used for every function on a chip and that would lead to a steady increase in computing capability. But the wheels began to come off that scheme not long thereafter. Device specialists could come up with excellent new transistors, but those transistors weren’t making better, smaller circuits, such as the SRAM memory and standard logic cells that make up the bulk of CPUs. In response, chipmakers began to break down the barriers between standard cell design and transistor development. Called design technology co-optimization, or DTCO, the new scheme led to devices designed specifically to make better standard cells and memory.
But DTCO isn’t enough to keep computing going. The limits of physics and economic realities conspired to put barriers in the path to progressing with a one-size-fits-all transistor. For example, physical limits have prevented CMOS operating voltages from decreasing below about 0.7 volts, slowing down progress in power consumption, explains Anabela Veloso, principal engineer at Imec. Moving to multicore processors helped ameliorate that issue for a time. Meanwhile, input-output limits meant it became more and more necessary to integrate the functions of multiple chips onto the processor. So in addition to a system-on-chip (SoC) having multiple instances of processor cores, they also integrate network, memory, and often specialized signal-processing cores. Not only do these cores and functions have different power and other needs, they also can’t be made smaller at the same rate. Even the CPU’s cache memory, SRAM, isn’t scaling down as quickly as the processor’s logic.
Without a doubt lithographic scaling has slowed down again after the frantic speed up we saw with the introduction of MP and EUV, and DTCO scaling is fast approaching it's final stages with the introduction of single fin finFET/GAA devices and the eventual rise of CFETs. The approaches outlined in this article will without a doubt allow for increased SOC functionality while maximizing the value extracted per mm^2 of real-estate from the most cost effective nodes for each die. I do think IEEE was underselling the added value from the increasing performance/efficiency that we will see from new materials. At least from all of the whitepapers we see, it seems like those kind of improvements are not going anywhere any time soon. Can't wait to buy that phone with an A10 CFET logic die, SiC power domains, N3 R-F modem, N4P i/o, and 3D-DRAM 3D stacked onto the package that has a total area around a nickle.
I think it interesting that they did not mention the possibility of further stacking beyond CFETs. Regardless the CMOS 2.0 vision might enable more niche transistor architectures to have a place in the lime-light. If we do end up seeing a process technology divergence you could almost see something like with how AMD does disag LLCs on CPUs/GPUs where the SRAM and or IO die(s) get fabbed with VTFETs or as stacked vertical nanowires like 3D-NAND. While these ideas might never come to light for monolithic or GP process technologies because of the PP part of PPAC. But if CMOS 2.0 ends up making a HUGE market for nodes that can deliver the best AC for specialized applications, then maybe they have a shot.
