Dear All,
I am using the following technology file and reference files for layout purpose:
technology file: tsmcn65_9lmT2.tf
reference file : tcbn65gplus_200a/frame_only/tcbn65gplus
After running, i am getting these following errors regarding pitch area and AP.
warning: Layer 'AP' is missing the attribute 'minArea'. (line 744) (TFCHK-012)
Warning: Cut layer 'VIA1' has a non-cross primary default ContactCode 'VIA12'. (line 1207) (TFCHK-092)
Warning: Layer 'M1' has a pitch 0.2 that does not match the recommended wire-to-via pitch 0.225. (TFCHK-049)
Warning: Layer 'M7' has a pitch 0.2 that does not match the recommended wire-to-via pitch 0.41 or 0.35. (TFCHK-049)
Warning: Layer 'M9' has a pitch 0.8 that does not match the recommended wire-to-via pitch 3.6. (TFCHK-049)
Warning: Layer 'M3' has a pitch 0.2 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'M4' has a pitch 0.2 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'M5' has a pitch 0.2 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'M6' has a pitch 0.2 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'M7' has a pitch 0.2 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'M8' has a pitch 0.8 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'M9' has a pitch 0.8 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'AP' has a pitch 6.5 that does not match the doubled pitch 1.6 or tripled pitch 2.4. (TFCHK-050)
Warning: CapModel sections are missing. Capacitance models should be loaded with a TLU+ file later. (TFCHK-084)
Could someone help to resolve these issues ? and also if i ignore these warnings, will it be any effect on my design during the tap-out.
Your help will be appreciated.
Thanks in advance.
Sachin
Thanks in advance.
Sachin
