t2mip
Member
T2M-IP, a global specialist in semiconductor IP solutions, highlights its USB 3.2 Gen1 and Gen2 IP Core, a complete, production-proven PHY and Controller solution supporting 5Gbps and 10Gbps data transfer. Designed for performance, flexibility, and low power, this IP cores supports multi-lane operation and is optimized for a wide range of high-speed interface applications across consumer, automotive, and industrial domains.
Fully compliant with the USB 3.2 specification, the IP cores support Host, Device, OTG, Dual-Role, and Hub configurations. It is also USB Type-C compatible, enabling seamless integration into USB-C-based designs, including support for dual-role functionality and alternate mode readiness.
With the increasing adoption of USB Type-C and higher bandwidth peripherals, SoC designers are under pressure to deliver robust USB performance while minimizing power and area. T2M-IP’s USB 3.2 IP stands out by offering a unified, scalable solution that supports diverse use cases—from compact wearables and smartphones to high-throughput automotive infotainment and industrial control systems. Its adaptability across roles and applications makes it an ideal choice for future-proof designs.
Key Features of T2M-IP's USB 3.2 IP cores include:
High-Speed USB 3.2 Support: Compliant with Gen1 (5Gbps) and Gen2 (10Gbps), with support for multi-lane operation to boost throughput.
Flexible USB Roles: Highly configurable for Host, Device, OTG, Hub, and Dual-Role applications.
Type-C Integration Ready: Supports key USB Type-C features, ideal for modern SoCs with reversible connectors and dynamic role-switching.
Low Power & Compact Footprint: Optimized PHY architecture ensures minimal area and power, perfect for mobile and embedded systems.
Robust Signal Performance: Built-in signal integrity and error-handling features ensure reliable performance in harsh environments.
Proven Across Markets: Successfully deployed in automotive, external storage, consumer electronics, gateways, and industrial systems.
T2M-IP’s USB 3.2 Gen1/Gen2 solution is part of a rich interface IP cores portfolio that includes PCIe, HDMI, DisplayPort, MIPI, DDR, Ethernet, V-by-One, SD/eMMC, and programmable SerDes, all available with matching PHYs. IP cores are silicon-proven and available across leading foundries and advanced process nodes.
Immediate licensing Availability: These Semiconductor Interface IP Cores are immediately available for licensing as stand-alone IP Cores or with pre-integrated Controllers and PHYs. Please submit a request / MailTo for more information on licensing options and pricing.
About T2M: T2M-IP is a global independent semiconductor technology expert, supplying complex semiconductor IP Cores, Software, KGD, and disruptive technologies to allow faster development of your Wearables, IOT, Automotives, Communications, Storage, Servers, Networking, TV, STB, and Satellite SoCs. For more information, please visit www.t-2-m.com.
