t2mip
20th January 2025: T2M IP Technology proudly unveils its partner's latest portfolio additions: advanced 16-bit Analog-to-Digital (ADC) and Digital-to-Analog (DAC) converters, engineered for cutting-edge applications across diverse industries.
16-Bit SAR ADC
Our 16-bit Successive Approximation Register (SAR) ADC delivers outstanding performance with versatile configurability, making it ideal for precision-driven applications.
Key Features:
• Selectable resolutions up to 10-bit for flexible operation.
• Conversion rate up to 5 MS/s with a maximum clock frequency of 230 MHz.
• Wide analog supply range (3.6V to 1.6V) and 1.1V digital supply.
• Power consumption scales linearly with the sampling frequency.
• Rail-to-rail input support with single-ended or differential inputs.
• Includes a 4:1 analog input multiplexer for multiple signal sources.
• Extended sampling-time option and calibration engine for offset, gain, and linearity adjustments.
• Compact die area optimized for integration in space-constrained designs.
• Operates reliably in harsh environments (-40°C to +125°C).
16-Bit Delta-Sigma DAC
The 16-bit voltage-output Delta-Sigma DAC is designed for exceptional fidelity and power efficiency, making it a standout solution for high-performance analog signal generation.
Key Features:
• 16-bit monotonic performance with 80 MHz modulator rate.
• Output bandwidth of 10 kHz for precise signal reproduction.
• Low power consumption (<1 mA) with internal reference generation.
• Analog supply voltage of 1.8V ±5% and digital supply voltage of 0.75V ±5%.
• Programmable gain and offset for versatile application adaptability.
• Broad operating temperature range (-40°C to +125°C) for robust performance in diverse environments.
Applications:
These IP cores are ideal for applications in industrial automation, consumer electronics, automotive systems, and more, where precision, efficiency, and scalability are paramount.
Both solutions are designed with a compact die area, enabling seamless integration into modern semiconductor systems.
T2M IP Technology – Driving innovation with precision-engineered IP solutions.
These state-of-the-art IP solutions empower automotive manufacturers to design smarter, safer, and more efficient vehicles. Contact T2M Technology today to explore how these IPs can elevate your automotive designs.
For inquiries and licensing opportunities,
Contact:
Email: mini@t-2-m.com
Website: www.t-2-m.com
16-Bit SAR ADC
Key Features:
Key Features:
Applications:
Contact:
