12 Jun 2024
Highlights:
Through this close collaboration, Cadence and Samsung have demonstrated the following:
“Samsung and Cadence have a close collaboration to advance technology and help our customers deliver competitive designs to the market efficiently,” said Sangyun Kim, Vice President and head of Foundry Design Technology Team at Samsung Electronics. “Our joint efforts enable customers to utilize Samsung’s latest process and technology innovations to push the limits for the most advanced AI, hyperscale computing and mobile SoC designs.”
To learn more about Cadence AI offerings, please visit: Cadence.ai.
About Cadence
Cadence is a pivotal leader in electronic systems design, building upon more than 30 years of computational software expertise. The company applies its underlying Intelligent System Design strategy to deliver software, hardware and IP that turn design concepts into reality. Cadence customers are the world’s most innovative companies, delivering extraordinary electronic products from chips to boards to systems for the most dynamic market applications, including consumer, hyperscale computing, 5G communications, automotive, mobile, aerospace, industrial and healthcare. For 10 years in a row, Fortune magazine has named Cadence one of the 100 Best Companies to Work For. Learn more at cadence.com.
© 2024 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, the Cadence logo and the other Cadence marks found at www.cadence.com/go/trademarks are trademarks or registered trademarks of Cadence Design Systems, Inc. All other trademarks are the property of their respective owners.
Category: Featured
Cadence Newsroom
408-944-7039
newsroom@cadence.com
Source: Cadence Design Systems, Inc.
Highlights:
- - Cadence.AI digital and analog tools optimized for advanced node SF2 gate-all-around (GAA), driving enhanced quality of results and accelerating circuit process node migration
- - Cadence’s best-in-class 3D-IC technology enabled for all of Samsung Foundry’s multi-die integration offerings, accelerating the design and assembly of stacked chiplets
- - Cadence’s broad IP portfolio and tools for next-generation AI designs will enable customers to achieve first-pass silicon success and accelerate time to market
- - Cadence.AI enables lower leakage power and development of SF2 GAA test chips: Cadence, in close collaboration with Samsung Foundry, has leveraged the Cadence® Cerebrus Intelligent Chip Explorer and its AI technology in both DTCO and implementation to minimize leakage power on their SF2 GAA platform. Compared to the best-performing baseline flow, the Cadence.AI result achieved a more than 10% reduction in leakage power. As part of this ongoing collaboration, a mutual customer is actively involved in the development of a test chip using Cadence.AI for an SF2 design.
- - Cadence backside implementation flow certified for Samsung Foundry SF2: As a result of extensive collaboration between Cadence and Samsung Foundry, a complete Cadence backside implementation flow has been certified for the SF2 node to accelerate the development of advanced designs. The full Cadence RTL-to-GDS flow, including the Genus™ Synthesis Solution, Innovus™ Implementation System, Quantus™ Extraction Solution, Pegasus™ Verification System, Voltus™ IC Power Integrity Solution and Tempus™ Timing Signoff Solution has been enhanced to support backside implementation requirements such as backside routing, nano TSV insertion, placement and optimization, signoff parasitic extraction, timing and IR analysis, and DRC. The Cadence backside implementation flow has been validated with a successful Samsung SF2 test chip, demonstrating the flow is ready for use.
- - Cadence has collaborated with Samsung Foundry to enable solutions for Samsung Foundry’s multi-die offerings: The Cadence Integrity™ 3D-IC platform is enabled for all of Samsung’s multi-die integration offerings, and its early analysis and package awareness features are now compliant with Samsung’s 3DCODE 2.0 version. In addition, Cadence and Samsung have expanded the multi-die collaboration by enabling differentiating technologies like thermal warpage analysis using the Cadence Celsius Studio and system-level LVS with Cadence Pegasus Verification System. Cadence is also supporting Samsung with a package PDK that reduces design time with the Allegro X system. Combined with the Integrity 3D-IC platform, it optimizes the package design flow.
- - Cadence.AI’s Virtuoso Studio flow successfully deployed for analog circuit process migration: Purpose-based instance mapping in the AI-powered Virtuoso Studio provided rapid retargeting of the schematics, while circuit optimization in Virtuoso Studio’s Advanced Optimization Platform helped Samsung achieve a 10X improvement in turnaround time when migrating a 100MHz oscillator design from 14nm to 8nm. In addition, a FinFET-to-GAA analog design migration reference flow is available for joint customers, with successful experimental results.
- - Cadence mmWave RFIC design flow successfully used to tapeout 14RF circuit design: Cadence and Samsung successfully taped out a 48GHz power amplifier design, representing silicon validation of the robust, full system reference flow that leverages the Cadence EMX Designer to create passive devices with fast modeling and layout automation. Full design EM extraction with the EMX 3D Planar Solver and EM/IR analysis using Voltus XFi and Quantus ensured that the IC met aggressive metrics, Pegasus was used for signoff DRC/LVS, while AWR VSS provided a seamless environment to carry out initial system-level budgeting and post-layout verification. Mutual customers can feel confident utilizing this flow to deliver leading-edge designs to market in a timely manner.
- - Cadence Pegasus Verification System is certified for Samsung Foundry's 4nm and 3nm process technologies: Through the collaboration with Samsung Foundry, the Cadence physical verification flow is optimized to allow mutual customers using Samsung Foundry’s advanced nodes to reach signoff accuracy and runtime goals for a faster time to market. The Pegasus system is now certified across multiple advanced nodes at Samsung Foundry, which are proven and in production by customers, with simplified, all-inclusive licensing support. The Pegasus system is integrated into the AI-powered Cadence Virtuoso Studio as iPegasus to enable in-design signoff quality DRC and interactive metal fill in the layout implementation, offering up to 4X faster turnaround times.
- - Cadence IP portfolio offers comprehensive industry solutions on advanced Samsung nodes:
- - Cadence’s latest IP built on Samsung SF5A includes industry-leading PHY IP for 112G-ULR SerDes, PCIe® 6.0/5.0, UCIe™ , DDR5-8400, DDR5/4-6400 Memory and USB 2.0, offering customers complete platform solutions
- - Cadence’s PHY IP for PCIe 6.0 on Samsung SF5A has been successfully certified for PCIe 5.0 x8 compliance and demonstrated seamless interoperability with other PCIe 5.0/6.0 system and test equipment, further showcasing its PCIe solution maturity
- - Cadence is furthering its partnership with Samsung Foundry by pushing the performance envelope, designing advanced memory IP for GDDR7 on Samsung SF4X and SF2, and helping reshape the HPC/AI industry with this new memory standard.
- - Advanced verification for AI design complexity: Samsung Foundry applied Cadence’s advanced verification technologies, such as the Palladium Enterprise Emulation System, JasperC, STG, and Xcelium ML, to tackle rising AI chip complexity and achieve time-to-market requirements in SF3.
About Cadence
Category: Featured
Cadence Newsroom
408-944-7039
