[0] => /forum/threads/intel-14a-risk-production-in-2028-hvm-in-2029-lip-bu-tan-at-cisco-ai-summit-3-feb-2026.24482/
[XF] => 2030871
That's what LBT says at 51:40So they said Risk Production was 2027 in the IFS Connect 2025 now it's 2028 are they moving timelines?
[News] Intel Ramps Up Foundry Race: 14A Risk Production in 2027; 18A Variants Drop in 2026 and 2028
Shortly after TSMC announced plans to mass-produce A14 in 2028, Intel appears ready to compete with an aggressive roadmap for 14A and 18A. According t...www.trendforce.com
problem is small volume won't justify 14A it needs big volume also i think that 28 risk production is for external and 27 for InternalI think this may be quite smart (humble) timing of INTEL, these customers have their main orders with TSMC being made in 2028, they trust that that will come. And then INTEL will deliver some small overflow capacity in 2029 of say 5-10%. In that way these customers do not risk major parts of their production if INTEL fails. Makes sense for both sides.
I hate the way they always pick a comparison that makes something look artificially good -- why isn't the comparison A14 vs. N2P, which is the real alternative?That's what LBT says at 51:40
LBT clearly has two major concerns regarding 14A, the variability of the yield and the IP availability. It seems they simply need more time to get that in a better shape. He only wants 5 or 10% of a major product of early customers for 14A to commit to that so that he can get the trust of those companies.
So perhaps Apple, NVIDIA, Microsoft will commit to some small wafer orders to be manufactured in 2029........He will not give the names of the intended customers that he hopes will sign purchase agreements in H2-2026.
I think this may be quite smart (humble) timing of INTEL, these customers have their main orders with TSMC being made in 2028, they trust that that will come. And then INTEL will deliver some small overflow capacity in 2029 of say 5-10%. In that way these customers do not risk major parts of their production if INTEL fails. Make sense for boith sides.
Will be interesting to see if TSMC now goes full in on A14, scheduled for HVM in 2028? They have started building the new fab for A14:
https://en.eeworld.com.cn/news/manufacture/eic712929.html#:~:text=Furthermore, TSMC notified its customers,platform officially put into operation.
The reason TSMC emphasized that A16 is HPC-exclusive is that implementing BPD requires a specific process step that must be performed during the wafer flip, and that step significantly degrades the heat dissipation (thermal spreading) performance of backside power delivery. As a result, chips fabricated on the A16 node inevitably become HPC chips that mandatorily require liquid cooling.
If it didn't come directly from TSMC***, that could have be lifted what from what I posted here earlier today -- after being simplified by about 100x... ;-)I've seen an interesting tweet here, that says that Intel's 16A / 14A are useless for mobile applications, because of the compulsory BPD
No, this is not true.
That rubbish just say when transistor get smaller, there is more heat, just like when you place LED array closer and closer, it will heat up the strip.
1) All transistor FSPD or BSPD going to suffer from this (density vs heat), why only BSPD.
2) Last time I am in high school, Copper (which the signal and power line is make of) is one of the best thermo property out there way better than Silicone, the heat is going to out faster not slower.
3) Last time I am in high school, I learn about the cross cut section thickness the larger the cross cut the lesser the...
And the post greatly exaggerates what I wrote, it makes out that BSPD (especially Intel) is pretty much unusable except for HPC -- the reality is that it's *recommended for/targeted at* HPC because there the advantages are larger and the negative points (thermal, cost) can be dealt with, so FSPD is the best choice for most other applications especially lower-power ones or ones which are harder to cool or more cost-sensitive.If it didn't come directly from TSMC***, that could have be lifted what from what I posted here earlier today -- after being simplified by about 100x... ;-)
*** it didn't -- it came from an earlier post I made in Semiwiki on the same subject. It's all getting a bit circular... ;-)
