            [0] => /forum/threads/panther-lake-design-rules-revealed-no-hd-cells.24596/page-3
Panther Lake design rules revealed, no HD cells
But the decap shows that Panther Lake use HP cell for overall device, no HD cell. And I remember Panther Lake performance is not high ( its clock rate even lower than Arrow Lake), and it emphasizes more on efficiency. So question is why Panther Laker don not just use HD cell?
there could be any number of reasons.
they need the performance
The HP cell has better stability, lower error rate
The layout did not show a penalty for a larger cell. using a HD cell to save 1mm2 might not be a good idea. with chiplets and dummy silicon you could end up with no penalty.
I mentioned to someone on here that 20 years ago, we never used the most dense SRAM. Designers were not going to risk a product to save 2mm2.
The reason for using HD cells is to increase density, and to reduce energy consumption per operation (gate transition) for cases where this matters more than maximum clock speed. For most CPUs HP cells are more appropriate, they're a better fit to the device priorities. For most ASICs HD cells are a better fit to the device priorities. Neither is "better" than the other, they have different pros and cons.
(but stability and error rate are nothing to do with it, at least not in any application I'm aware of...)
Depends on what you compare with also
ARL has 17 Metal Layers
LNL has 20 Metal Layers
PTL has 21 Metal Layers
This is also very strange too….
Intel said FS 14-16 ML is for high performance, but PTL dose not pursuit high performance?
And why fewer ML (12ML) is for high density?
Wow, this really surprise me. I originally think ASIC chip may focus on performance over power consumption due to the less limitation on cooling capabilities?
Some ASICs like NPU/GPU, sure. But most ASICs don't have liquid-cooling systems, and requiring the cooling system to keep the heatsink perhaps 20C cooler -- if there is a heatsink at all! -- is somewhere between difficult/expensive and impossible.
So HPC chips (including CPU/NPU/GPU) tend to use HP libraries and maybe BSPD (but not always, especially if power efficiency is the #1 priority) and other ASICs tend to use HD libraries and FSPD to reduce cost and power consumption (but not always, especially if performance is the #1 priority).
for BEOL M0 32nm with EUV Low NA 0.33 Direct Print, Intel R&D is confident but Intel Volume Manufacturing cannot yield? source = 2026-Feb-SPIE
for Intel 18A, Intel R&D was/is confident about 32nm with EUV Low NA 0.33 Direct Print, but can Intel Volume Manufacturing yield?
for Intel 14A, Intel R&D would be confident about 24nm with EUV High NA 0.55 Direct Print, but can Intel Volume Manufacturing yield?
by the way, Intel 14A PDK 0.5 is promised/scheduled to be delivered to customers in 2026-Q1
For 18A we have more products yet to be launched we only have 1 product right now so it's too soon to say as for it Intel always has gotten Volume Manufacturing even if there were setbacks(10nm)
Nope, Intel 14A M0 is 28nm.
not new info, Intel 18A 1st chip = Panther Lake compute tile, 2nd chip = Clearwater Forest compute tile 3x4 dies per reticle field, each die of ~8.7x6.2 mm2, yield is higher for small dies than 1 or 2 large dies per reticle field, source = 2025-Oct-IntelTechTourUS, https://www.computerbase.de/artikel/prozessoren/intel-clearwater-forest-288-kerne-detail.94509/
Is this many chiplet design was built this way specifically because of the 18A target and yield curve / ramp considerations? I definitely get that overall this design could not fit within the reticle limit, but for instance it looked this way too on 10nm/Intel 7: Sapphire Rapids with more chiplets -> Emerald Rapids with consolidation and much bigger dies a year or two along the yield/ramp curve.
From a pure perf/W perspective, is it usually correct that the monolithic design wins out? For instance, Nvidia’s leading designs continually do reticle limit monolithic dies.
Intel from 2024-Feb-SPIE to 2026-Feb-SPIE, glad to see these progressions toward being realistic for volume manufacturing
from >28nm to 32nm, EUV 0.33NA Direct Print
from green-yellow to green, EUV 0.33A SALELE
from 22-20nm to 24-20nm, from 19-16nm to 20-16nm, BEOL M0 pitch
from DSA to Metallization, last row
