    [term_id] => 28152
    [name] => llmda.ai
    [slug] => llmda-ai
    [term_taxonomy_id] => 28152
    [count] => 7
    [cat_ID] => 28152
    [category_count] => 7
    [cat_name] => llmda.ai
    [category_nicename] => llmda-ai
llmda semiwiki company banner
    [term_id] => 28152
    [name] => llmda.ai
    [slug] => llmda-ai
    [count] => 7
    [cat_ID] => 28152
The Hidden Cost of Using Claude for Documentation
by Mike Gianfagna on 05-29-2026 at 8:00 am
Key takeaways
Why Generic LLMs Fall Short for Critical Engineering Documentation
Engineering documentation has always been difficult to produce, maintain, and scale. But with the rise of generative AI, many organizations are asking a reasonable question: can a general-purpose large language model (LLM) like Claude automate the work? At first glance, the answer appears to be yes.
Modern LLMs can generate polished technical prose, summarize complex inputs, and connect to enterprise systems through agents, skills, and connectors. It’s easy to imagine a workflow where engineering teams simply connect an LLM to Jira, Confluence, design repositories, or internal specifications and ask it to generate a user guide, limitations section, technical reference manual, or release note.
But the reality is more complicated. A new white paper from llmda.ai examines the true complexity and cost involved. A link to the white paper is coming but first let’s examine some details. Engineering documentation is not just a writing problem. It is a precision production process for technical truth. And that distinction changes everything. And that’s why generic LLMs fall short for critical engineering documentation.
Engineering Documentation Is Not Ordinary Content
Unlike marketing copy, internal notes, or general knowledge articles, hardware and systems engineering documentation must be correct, repeatable, traceable, and governed. A single incorrect register definition, interface description, timing constraint, or product limitation can create real downstream consequences.
Documentation errors can lead to design confusion, validation gaps, customer escalations, support burdens, schedule delays, and reputational damage. That means automation cannot simply produce content that sounds right. It must produce content that is grounded in authoritative sources, aligned to the correct product revision, reviewable by the right stakeholders, and suitable for formal publishing.
This is where generic LLM approaches begin to hit limits.
The Hidden Cost of “Just Use Claude”
The white paper explains that the real cost of using a general-purpose LLM is not token consumption. Tokens are usually the smallest part of the equation.
The larger cost is the internal platform an organization must build around the LLM to make it safe for engineering documentation. A generic model may provide the language engine, but the enterprise still needs to build ingestion pipelines, retrieval systems, grounding logic, citation traceability, template enforcement, approval workflows, publishing pipelines, access controls, audit logs, monitoring, and version alignment.
In other words, the company does not just adopt an LLM. It becomes an internal documentation platform vendor.
This is especially important because engineering documentation is deeply tied to product lifecycle management. Documents must track Rev A versus Rev B. They must align with RTL, IP metadata, design specifications, validation reports, and release notes. They must be updated incrementally and consistently. They must also support structured formats such as Word, PDF, DITA, ReST, and other publishing outputs.
Generic LLMs were not designed to provide this full enterprise layer out of the box.
Prompting Becomes Programming
The white paper also highlights a subtle but important operational problem: prompting becomes programming, but without the guarantees of software engineering.
For example, asking an LLM to “generate the Limitations section from Jira tickets” may work in a demo. But in production, Jira fields change. Ticket formats vary. Metadata may be missing. Release labels may be inconsistent. Internal comments may contain sensitive or unverified information. The model may classify bugs incorrectly, omit critical constraints, or elevate ambiguous internal language into published documentation.
The point is made that LLMs are not useless. They are powerful drafting tools. The problem is that high-stakes engineering documentation requires determinism, repeatability, and auditability. A probabilistic prompt-driven workflow is difficult to test, difficult to reproduce, and difficult to govern at scale.
llmda Spectra™ – Why Purpose-Built Matters
The white paper estimates that building a llmda Spectra-like documentation automation system around a generic LLM could require a dedicated multidisciplinary team of six to eight engineers, including backend, machine learning, DevOps, security, workflow, and publishing expertise. Annual staffing costs are estimated at roughly $1.5 million to $2.5 million, with a typical 12- to 24-month time-to-value.
The opportunity cost may be even higher. Every engineer assigned to internal documentation infrastructure is an engineer not working on silicon innovation, system architecture, performance optimization, customer features, or other product-differentiating work. Depending on product velocity and market timing, the white paper estimates that delayed revenue opportunities could reach $5 million to $50 million.
That is the central economic argument: the “cheap” LLM path can become expensive when organizations must build the missing enterprise infrastructure themselves.
The alternative presented in the white paper is llmda Spectra, a platform built specifically for engineering documentation automation. Spectra is positioned not as a general-purpose assistant, but as a governed documentation system designed for source-grounded generation, deterministic workflows, structured engineering outputs, role-based access control, revision-aware versioning, collaboration, sign-off, tool execution, and publishing integration.
This distinction matters. A drafting assistant can help individuals move faster. A documentation platform helps organizations produce reliable, reviewable, publishable engineering content at scale.
To Learn More
Generic LLMs have an important role to play in engineering productivity. They can accelerate drafting, summarization, brainstorming, and individual workflows. But when documentation becomes part of the product lifecycle, the requirements change.
Engineering teams need more than fluent text. They need source-grounded truth, repeatable generation, governed workflows, secure collaboration, structured outputs, and auditable decisions.
That is why the white paper’s conclusion is direct: use LLMs where they help, but do not rebuild an engineering documentation platform from scratch when a purpose-built solution already exists. If this discussion resonates with your needs when building complex systems, you must download this white paper.
You can access your copy here  to better understand why generic LLMs fall short for critical engineering documentation.
If You Struggle with Up-To-Date Documentation llmda.ai Can Help
CEO Interview with Nagesh Gupta of llmda.ai
Webinar: How Agentic AI Keeps Documentation Consistent and Accurate
