            [0] => /forum/threads/spacex-wants-to-put-1-million-solar-powered-data-centers-into-orbit.24445/
            [XF] => 2030871
SpaceX wants to put 1 million solar-powered data centers into orbit
The company claims it’s a cheaper and more environmentally-friendly alternative to land-based centers.
SpaceX has filed a request with the Federal Communications Commission to launch a constellation of up to 1 million solar-powered satellites that it said will serve as data centers for artificial intelligence.
The company’s filing lays out a grandiose vision, not just describing these planned satellites as “the most efficient way to meet the accelerating demand for AI computing power” but also framing them as “a first step towards becoming a Kardashev II-level civilization — one that can harness the Sun’s full power” while also “ensuring humanity’s multi-planetary future amongst the stars.”
The Verge argued that the 1 million satellite number is unlikely to be approved outright and is probably meant as a starting point for negotiations. The FCC recently gave SpaceX permission to launch an additional 7,500 Starlink satellites, but said it would “defer authorization on the remaining 14,988” proposed satellites.
There are currently around man-made 15,000 satellites orbiting the Earth, according to the European Space Agency, and they’re already creating issues with pollution and debris.
The filing also comes as Amazon — citing a lack of rockets — is seeking an extension on an FCC deadline to have more than 1,600 satellites in orbit. Meanwhile, SpaceX is reportedly considering a merger with two of Elon Musk’s other companies, Tesla and xAI (which already merged with X), ahead of going public.
So, how do you cool your chips in space where you can’t just dump the heat into the atmosphere or the sea? And what to do about the part of low earth orbit where the sun sets behind earth?
You radiate the heat out into space behind the solar panels -- might take similar area to solar panels for input power (see calculations elsewhere), but cooling rig weight could be "challenging"... ;-)
I assume they'd use orbits in a band around the Earth which are always roughly at right-angles to the sun, so they never go into the shadow.
What happen when there is so much junk up there it blocks the sun?
Even a million orbiting data centers would occupy only a *tiny* fraction of the orbital area...
“Space is big. You just won't believe how vastly, hugely, mind-bogglingly big it is. I mean, you may think it's a long way down the road to the chemist's, but that's just peanuts to space.”
