            [0] => /forum/threads/intel%E2%80%99s-18a-rumors-meet-a-thermal-brick-wall-says-semiwiki.24458/
Intel’s 18A rumors meet a thermal brick wall says SemiWiki
Intel has attracted plenty of chatter over the past few weeks, with talk that Apple could come crawling back for some M-series work, but now it appears that iPhone chips…
Intel has attracted plenty of chatter over the past few weeks, with talk that Apple could come crawling back for some M-series work, but now it appears that iPhone chips on Chipzilla’s fanciest nodes are a non-starter.
In recent weeks, GF Securities and DigiTimes have claimed Apple might use Chipzilla’s 18A-P process for its lowest-end M-series parts in 2027. The same reports floated the possibility of non-Pro iPhone chips in 2028.
GF Securities also said Job’s Mob’s bespoke ASIC, expected in 2028, would use Chipzilla’s EMIB packaging. That is the sort of detail that makes rumours sound “real” while still being completely free of consequences.
There has been noise that Job’s Mob signed an NDA with Intel and pulled PDK samples for 18A-P to evaluate. Chipzilla’s 18A-P is intended to be its first node supporting Foveros Direct 3D hybrid bonding, enabling chiplets stacking via TSVs.
Now, a bunch of industry insiders on the SemiWiki forum have poured cold water on Intel’s manufacturing of iPhone chips. The core gripe is Chipzilla’s decision to go all-in on Backside Power Delivery for its 18A and 14A nodes.
Unlike TSMC, which offers some nodes with BSPD and others without it, Chipzilla has pushed BSPD across its bleeding-edge stack. That leaves it without an easy “same node, less drama” option when a customer prioritises thermals over bragging rights.
BSPD can boost performance because the chip is powered through shorter, thicker metal paths on the backside, cutting voltage drop and helping to stabilise frequencies. It also frees up front-side routing, which can lift transistor density or reduce congestion.
For mobile silicon, insiders reckon the performance bump is small. The trade-off is a worse self-heating effect, which increases cooling requirements in places phones would rather avoid.
SemiWiki forum, commenter IanD said: “kept around 20C cooler with BSPD for the same die temperature in hotspots (because vertical heat spreading is bad but lateral is even worse now there’s no thick silicon substrate), and that’s simply impossible in many use cases which rely on air cooling or have a maximum allowable case temperature.”
X, commentator Jukan said there is “zero chance” that Chipzilla can manufacture Job’s Mob iPhone chips anytime soon, although he thought that M-series parts might still be on the table.
Just curious, I learned that BSPDN can reduce power consumption compared to FSPDN, so is the heat problem is the truly issue for BSPDN?🧐
@Daniel Nenni
Congratulations to you and the fellow bloggers. SemiWiki is getting much more attention and mention now.
No, this is not true.
That rubbish just say when transistor get smaller, there is more heat, just like when you place LED array closer and closer, it will heat up the strip.
1) All transistor FSPD or BSPD going to suffer from this (density vs heat), why only BSPD.
2) Last time I am in high school, Copper (which the signal and power line is make of) is one of the best thermo property out there way better than Silicone, the heat is going to out faster not slower.
3) Last time I am in high school, I learn about the cross cut section thickness the larger the cross cut the lesser the resistance, BSPD will have inherently thicker cable as they separate power and signal into different layers
The only remote places that BSPD is going to be at a disadvantage in heat is:
As better cell utilization rate, packing transistor in a denser manner than FSBD, so accordingly, they said higher density = higher heat but that applies to FSPD too.
Speaking as someone who has actually done thermal analysis comparison of FSPD vs. BSPD in real high-performance chips vs. high-school posting about copper thermal conductivity...
In a conventional FSPD chip the die is face down, the transistors are embedded in (or thermally directly connected to) a thick (typically 700um) silicon substrate, which has about half the thermal conductivity of copper. This conducts heat to the back of the die where the heatsink contacts it, as a consequence something like 90% or more of the heat leaves the chip this way. Even with this you get significant hotspots in regions with high power density, either at block level or all the way down to gate level, typically the hottest devices run maybe 20C hotter than the die backside -- the substrate also wicks heat away laterally (heat spreading) which helps keep temperatures down.
There's another path down through all the metal layers to the substrate/PCB but this is much higher thermal resistance because copper coverage on each layer is small, especially through tiny vias in the thin/fine-pitch metal layers, and there's no heatsink/cooler on this side, so only a small amount of heat (less than 10%) leaves this way.
With BSPD the die is flipped the other way up, with BSPD power rails and bumps underneath a very thin die (a few microns at most), with the transistors on top of this and the thin/fine-pitch routing layers on top, with no power rails -- this is where the area saving comes from, plus the supply connections are lower resistance because they go straight from thick metal underneath to the transistors without having to crawl down through the thin metal stack (more than 15 layers).
The problem now is that the thermal connection from the hot transistors up to the topside heatsink is through the thin/fine-pitch metal signal layers, which are *much* higher thermal resistance than silicon -- what copper there is might be 2x the thermal conductivity of silicon but there's not much thermally-contacted coverage of this, the rest is oxide/dielectric which is 100x lower conductivity. As well as this vertical resistance, there's nothing good conducting heat laterally either (unlike a silicon substrate) so small hotspots get even hotter as a result.
The end result is that transistors (e.g. in clock drivers) and circuits with high power density get a *lot* hotter than with FSPD, it's very easy to get an extra 20C (40C total) local temperature rise (actually, you can get even more than this if you don't take special layout precautions). This causes problems with leakage and reliability (electromigration), so especially bad for devices that run all the time 24/365 and need long lifetimes. Things are also made worse if you use the higher density from BSPD to increase gate density, this puts power density (W/mm2) up by another 20% or so (if you have a dense power grid), so you can in theory end up with +50C hotspots (30C worse than FSPD) -- though this may not be so bad in practice since the hottest bits probably don't shrink much.
If you have a chip like this (e.g. in a data center) and you can't allow the circuits to run that hot, the only solution is to keep the top of the die/heatsink cooler than with FSPD, typically by 20C. That will usually mean very aggressive cooling is needed, either with truly massive air-cooled heatsinks or liquid-cooling, and will exclude using BSPD in applications where this isn't possible -- unless you're willing to let the chips get *really* hot sometimes, OK for burst use (throttle down after a few seconds?) or intermittent use or if you don't care whether the chip lasts more than a couple of years...
On top of this the PPD improvement with BSPD depends strongly on the FSPD power grid density -- in high-power chips with a dense power grid (e.g. HPC) the area saving and speed improvement are pretty significant, but in lower-power chips with a less dense power grid (most chips!) these are much smaller. Also the wafer cost is currently considerably higher, by more than the area saving.
All of which is are the underlying reasons behind why TSMC recommends A16 (with BSPD) only for "HPC-type devices -- dense power grid with active cooling". For these BSPD definitely has more pros (including better PPD) than cons, which is why it's being adopted for such devices -- also higher die cost doesn't really matter if the selling price is many thousands of dollars each. Since this (CPUs) is also Intel's main market, going BSPD-only works for them, it's the right choice.
For more "normal" chips -- most of the market by number of chips, and probably also wafer volume in the near future -- FSPD is better than BSPD, and for these TSMC is promoting A14 (for all the right reasons) not A16 (BSPD only) -- and it's why Intel (BSPD-only) don't have much of a chance in this market, they have the wrong process for it. Sure it *could* be used in a mobile and have very good performance, so long as you don't mind the high price and can keep it cool, but that's not usually going to be the case -- or you throttle it down as soon as it gets hot, which certain phones have been heavily criticised for... ;-)
It's worth noting that the hotspot problem with BSPD is likely to get worse in future, because with every new process node the power density per mm2 tends to creep up -- and this will get even worse when stacked CMOS comes along, especially for the "bottom" transistor, which will also increase power density further. Should still be fine for HPC with nice cold liquid cooling (which will however get more challenging...), but even worse for everyone else without such a luxury... :-(
P.S. All the numbers above are examples for high-speed high-power-density circuits -- the actual temperature rises will be smaller for a lot of chips, but the difference will still be there... ;-)
P.P.S. TSMC will do a BSPD version of A14 about a year later, as a next-node follow-on to A16 for the same markets (e.g. HPC)
P.P.P.S. This is also the sensible order, FSPD first to MP to drive down the D0 curve, then BSPD for the reticle-sized HPC chips which really *need* super-low D0...
Strangely, the first Intel BSPD (PowerVIa) product, Panther Lake, is for laptop computers. How do Intel and the OEMs overcome the cooling and battery drain problems? There isn’t a practical or inexpensive way to use liquid cooling in a laptop PC, unless they throttle down the performance to control heat and extend battery life. How does Intel solve these problems and this dilemma?
Why didn’t Intel apply BSPD to a processor for servers or desktop PCs first, where liquid cooling is feasible and meaningful?
Intel decided 20A and 18A were all BPSD..... a jump ahead technology. Also the roadmap today is not what the roadmap was in 2022. Products were cancelled and delayed and changes
How does Intel work around the Panther Lake's heat issues described by @IanD on the laptops? I assume they don't use liquid cooling.
Laptops nowadays are usually cooled with heat pipes to take the heat away to a larger remote heatsink/fan -- and bear in mind that most are 'thin'n'light' with relatively low power dissipation. They also only run at high power/voltage a fraction of the time in real life as opposed to running benchmarks -- usually in relatively short bursts, and use throttling to keep peak temperature down. They're probably also not so worried about lifetime/reliability degradation while hot, because of burst running and frankly being a disposable consumer item -- you can see this by the high boost voltages used to maximise short-term clock rates, which are also well above the limits for long-term voltage allowed over lifetime.
So for CPUs in laptops in particular some of the downsides of BSPD -- including die cost -- can be kind of hidden from the end user, and the PPD advantage promoted as an "Intel inside" plus point. But this doesn't apply to foundry customers who can see all the gory details... :-(
Intel are much stronger in the laptop market (with higher margins on relatively small die?) than the desktop market, so it makes sense for them to attack this first. On top of this the desktop market has moved towards either larger multicore die (usual Intel approach) where lower yield while a process is being brought up is a bigger problem, or multi-chiplet designs where silicon cost per mm2 is an issue and AMD have an advantage because they use TSMC. Here the heat isn't such a big problem, but even with liquid cooling you need a more powerful cooling system with BSPD to keep die temperature down, which is another disadvantage especially for big many-core systems.
So for Intel the right approach is laptop first, server/desktop second -- which is exactly what they're doing.
They do indirectly, that's what heatpipes to a remote HSF do. Most laptops nowadays are also low-power "thin'n'light" so most of the time keeping the CPU cool isn't a big problem, though it may mean more throttling when running benchmarks -- or they might just allow the circuits to run hotter knowing that this only happens occasionally so increased leakage and reduced lifetime isn't a problem, that's a system-level decision.
None of this applies to many foundry applications where cooling is more restricted and has to be done using air convection or heat to a metal case or a *tiny* fan, and where duty cycle is a lot more challenging, or devices run hot for years -- then the BSPD issues really show up.
BSPD is still an excellent choice for the right products*** where its PPD advantages (in higher-power-density chips) matter more than the cooling/cost disadvantages, which is why TSMC recommend A16 for these HPC-type applications -- and this will be a huge market, but with a relatively small number of designs. For more general foundry use (i.e. most designs) where the cost and cooling problems matter more, FSPD is the better choice.
*** which can include laptops... :-)
It is also possible these laptop CPUs are clocked lower to mitigate some of these thermal issues and they also operate at much lower power levels with an emphasis on higher perf/watt at lower watts.
We are missing the fact that if Intel had other mitigating factors applied to 18A/14A like some innovation in materials used to improve the co-efficient of thermal conductivity of dielectric+metallic interconnect signal layers (the side that is in contact with heat spreader now) vs substrate silicon of FSPDN. Ofc it cannot be as good as silicon substrate alone but any improvement they have had is good in heat dissipation.
Also de-cluttering the signal routing side on the front side by moving the power interconnect lines to the backside means, the signal interconnect layers could have relaxed pitch/width on some layers increasing the metallic content per layer (increasing the vertical heat dissipation through the metal line which has higher co-efficient of thermal conductivity even vs a silicon substrate).
The power delivery side definitely have wider metal interconnects (as shown in many of Intel's own BSPDN demo pics) as they don't need to shrink down as much as before to feed the power to transistors in BSPDN & now feed the power to transistors via Nano Through Silicon Vias (why Intel calls its BSPDN as PowerVia).
Having said all these, I do agree these 18A & 14A BSPDN process looks unsuitable for every kind of Mobile Phone SoCs (one area where Intel Products team has no footprint - supports the idea these processes were developed with Intel Products team as priority customer) which don't have any cooling mechanisms like heat pipes or vapor chambers. Some high end Mobile Phone SoCs do have vapor chamber or heat pipes these days iirc. But as an external foundry, Intel may miss out on some market segment due to BSPDN (unless they have something else up their sleeves like I talked about above).
There's not a lot you can do to lower the thermal resistance of the dielectrics used in the signal layers, low-k and ultra-low-k are even worse than oxide (which is 100x worse than silicon).
You also can't do a fat lot to wick heat up through the signal metal layers without using significant parts of the area up for what then looks very much like a topside power grid, which not only screws up the routing density but defeats the whole purpose of BSPD -- and is still not very good at vertical heat transfer, or heat spreading along the rows of cells. The last bit down to the transistors is particularly bad, this is where the routing is typically close to 100% full of signals because the cell libraries have been shrunk down to take advantage of BSPD...
Dumb Question -
How much does heatsink size actually help here?
Assuming the thermal conductivity between the CPU and the heatsink is the same whether the heatsink is "very large" vs. "small, but big enough" (i.e. covers the entire CPU lid) - wouldn't both heatsinks still pull off heat at approximately the same rate, limiting W/mm2 to roughly the same at the CPU side?
(i.e. isn't the effect of bigger air coolers, or even liquid coolers muted significantly due to the "new" insulation between the thermal compound/heatsink and the CPU die itself?. The lid can only pull so much heat off in the first place, unless radiant energy from a hotter heatsink is more meaningful in this scenario?)
Thanks..
I am not an expert on Semiconductor manufacturing, so I only postulated here that Intel could have done some innovation here (maybe even a new dielectric material) based on my understanding. Also, Intel said that they mitigated this issue when they did the Blue Sky Creek test chip (Intel 4 + PowerVia to de-risk 20A/18A).
Dumb Question -
Thanks..
The issue is how cool you have to keep the lower face of the heatsink/package lid that contacts the top of the die, and how much hotter than this the on-die temperature gets. There will always be some extra thermal resistance between the die and the external heatsink, due to TIM1 (thermal interface material between die and lid) and TIM2 (between lid and heatsink) -- a thick copper lid in between can help spread out the heat which helps with TIM2 thermal resistance, but then it's easier to use a low thermal resistance material for TIM1 (e.g. indium-tin solder) because it's inside the package and assembly is more controlled (thinner TIM).
This means that the top of the die will run hotter than the heatsink temperature, typically by something like 10C -- same regardless of process, only depends on power dissipation.
Let's say for example that the maximum temperature allowable at the transistors is 115C (a typical design reference temperature for EM and reliability), and that we have +20C hotspots on-chip (a typical figure for high-speed circuits in a FSPD process like N2 -- note that this is worse for nanosheet processes than finFET, which are in turn worse than planar CMOS), and this means the top of the die needs to be kept at 95C, which means the heatsink bottom has to be at 85C -- regardless of how this is cooled.
With BSPD there might be an extra +20C local hotspot temperature rise (depends on design and layout!), which means the heatsink now needs to be at 65C if you want to keep the same maximum on-chip temperature -- which in some cases isn't really necessary (e.g. low-duty-cycle at high power, short lifetime, reliabilty less important) depending on the product, but let's assume it is.
In some cases this makes the difference between feasibility and non-feasibility, for example where this is set by things like the external temperature of a case or plug-in module, and where keeping it 20C cooler is just not possible.
In other cases it means the system design has to be changed -- for example with high-power FSPD chips an 85C heatsink might be OK for air-cooling (e.g. delta-T=40C for 45C ambient air) but halving the heatsink thermal resistance for BSPD is impossible, so you have to go to liquid cooling.
No amount of playing about with heatsink/TIM materials can change the fact that the top of the BSPD chip has to be kept (for example) 20C cooler than the top of the FSPD chip... :-(
You can try and reduce this penalty for BSPD by tweaking the on-chip design to get more thermally-connected metal but this is not easy, the metal is thin and has low coverage (especially vias), and it eats into the area for routing just like a topside power grid -- which was the whole point of BSPD in the first place... :-(
Sorry to disappoint you, but there are no usable dielectric materials which are low thermal resistance and low-k which can be used for the fine-pitch signal interconnect layers, and I don't see any real prospect of them given the material properties needed... :-(
(for example diamond is thermally fabulous but is high-K, and is not exactly practical -- especially not around 20nm pitch metal tracks...)
Trying to add low-thermal-resistance paths up through the metal layers is difficult and directly conflicts with one of the reasons for going BSPD in the first place, which is increased density by getting rid of the topside power grid.
The "mitigation techniques" are likely to be things like spreading out high-power-density circuits like clock drivers and distributing them over a large area, which helps for these circuits and reduces the problem -- but increasingly there are some circuits like high-speed SERDES (especially for HPC!) where this doesn't really work, and these are also becoming more common on CPUs. Intel may also be using local temperature sensing and dynamic voltage control/throttling to prevent local overheating, this can be done in CPUs (at the cost of some performance reduction) but not in many applications where a given amount of processing must be done per second.
So yes, for Intel's particular case there are things that can be done to reduce (or hide...) this problem with BSPD but they don't get rid of it, and some of this may be sweeping the problem under the carpet and hiding it under the "throttling in continuous operation" blanket -- it makes this worse, but this is just accepted as a fact because there's no direct comparison with a FSPD chip from the same generation.
However this doesn't work for many (most?) foundry chips, where the customer can directly see all this happening when they do self-heating/hot-spot analysis, which is a compulsory part of the design flow nowadays -- assuming the tools do predict this correctly for BSPD, which I would certainly hope is the case but is by no means guaranteed -- the FSPD SHE analysis used to have some big holes in it, and even now it's not perfect... :-(
Still comes back to the fact that BSPD probably *was* the right choice for Intel who are targeting the CPU/HPC market (same as TSMC A16), but not for the general foundry market where FSPD is the right choice today (as TSMC admit) -- and Intel don't have a suitable process to compete with TSMC N2/A14 in this market, even assuming they could compete on price/yield/volume.
BSPD is an HPC technology for all the reasons Ian pointed out above and also because it costs more and requires new design techniques. The mobile guys do not want BSPD, they don't want the cost, it doesn't align with their needs and they don't know how to design for it.. TSMC has 2nm without BSPD, then A16 with BSPD (that I hear will be pretty much an NVIDIA node), then A14 without BSPD and then an A14 follow on with BSPD. The mobile guys will use 2nm and A14 and the HPC guys will use A16 and the A14 follow on process. I have heard Intel may offer a 14A version without BSPD, if so that would make them a mobile option once it comes out.
