Gartner has a new report out on IoT that might be worth reading if you are curious about the next big semiconductor thing. There are probably more than ten but this is as good of a start as any.
The bigger picture is the next transformation of the semiconductor industry, the one that started with the mobile revolution. We document the first transformation in our book "Fabless: The Transformation of the Semiconductor Industry" which is available on Amazon or via PDF if you are a registered SemiWiki member.
The next transfortaion starts with our book "Mobile Unleashed: The Origin and Evolution of ARM Processors in our Devices" where, starting with Apple, Samsung, and others, mobile systems companies are taking control of the fabless semiconductor ecosystem. IoT is of course going to be an extension of that transformation and you have to ask yourself how chip companies with already challenged margins will copete with system companies with layers of software and services built into the profit margin equation? Just my opinion of course...
D.A.N.
Ten Technologies That Will Enable Organizations to Unlock the Full Potential of the IoT
Gartner, Inc. has highlighted the top 10 Internet of Things (IoT) technologies that should be on every organization's radar through the next two years.
IoT Security
IoT Analytics
IoT Device (Thing) Management
Low-Power, Short-Range IoT Networks
Low-Power, Wide-Area Networks
IoT Processors
IoT Operating Systems
Event Stream Processing
IoT Platforms
IoT Standards and Ecosystems
http://www.gartner.com/newsroom/id/3221818http://www.gartner.com/newsroom/id/3221818
D.A.N.
"The IoT demands an extensive range of new technologies and skills that many organizations have yet to master," said Nick Jones, vice president and distinguished analyst at Gartner. "A recurring theme in the IoT space is the immaturity of technologies and services and of the vendors providing them. Architecting for this immaturity and managing the risk it creates will be a key challenge for organizations exploiting the IoT. In many technology areas, lack of skills will also pose significant challenges."
The technologies and principles of IoT will have a very broad impact on organizations, affecting business strategy, risk management and a wide range of technical areas such as architecture and network design. The top 10 IoT technologies for 2017 and 2018 are:
IoT Security
The IoT introduces a wide range of new security risks and challenges to the IoT devices themselves, their platforms and operating systems, their communications, and even the systems to which they're connected. Security technologies will be required to protect IoT devices and platforms from both information attacks and physical tampering, to encrypt their communications, and to address new challenges such as impersonating "things" or denial-of-sleep attacks that drain batteries. IoT security will be complicated by the fact that many "things" use simple processors and operating systems that may not support sophisticated security approaches.
"Experienced IoT security specialists are scarce, and security solutions are currently fragmented and involve multiple vendors," said Mr. Jones. "New threats will emerge through 2021 as hackers find new ways to attack IoT devices and protocols, so long-lived "things" may need updatable hardware and software to adapt during their life span."
IoT Analytics
IoT business models will exploit the information collected by "things" in many ways — for example, to understand customer behavior, to deliver services, to improve products, and to identify and intercept business moments. However, IoT demands new analytic approaches. New analytic tools and algorithms are needed now, but as data volumes increase through 2021, the needs of the IoT may diverge further from traditional analytics.
Long-lived nontrivial "things" will require management and monitoring. This includes device monitoring, firmware and software updates, diagnostics, crash analysis and reporting, physical management, and security management. The IoT also brings new problems of scale to the management task. Tools must be capable of managing and monitoring thousands and perhaps even millions of devices.
Selecting a wireless network for an IoT device involves balancing many conflicting requirements, such as range, battery life, bandwidth, density, endpoint cost and operational cost. Low-power, short-range networks will dominate wireless IoT connectivity through 2025, far outnumbering connections using wide-area IoT networks. However, commercial and technical trade-offs mean that many solutions will coexist, with no single dominant winner and clusters emerging around certain technologies, applications and vendor ecosystems.
Traditional cellular networks don't deliver a good combination of technical features and operational cost for those IoT applications that need wide-area coverage combined with relatively low bandwidth, good battery life, low hardware and operating cost, and high connection density. The long-term goal of a wide-area IoT network is to deliver data rates from hundreds of bits per second (bps) to tens of kilobits per second (kbps) with nationwide coverage, a battery life of up to 10 years, an endpoint hardware cost of around $5, and support for hundreds of thousands of devices connected to a base station or its equivalent. The first low-power wide-area networks (LPWANs) were based on proprietary technologies, but in the long term emerging standards such as Narrowband IoT (NB-IoT) will likely dominate this space.
IoT Processors
The processors and architectures used by IoT devices define many of their capabilities, such as whether they are capable of strong security and encryption, power consumption, whether they are sophisticated enough to support an operating system, updatable firmware, and embedded device management agents. As with all hardware design, there are complex trade-offs between features, hardware cost, software cost, software upgradability and so on. As a result, understanding the implications of processor choices will demand deep technical skills.
Traditional operating systems (OSs) such as Windows and iOS were not designed for IoT applications. They consume too much power, need fast processors, and in some cases, lack features such as guaranteed real-time response. They also have too large a memory footprint for small devices and may not support the chips that IoT developers use. Consequently, a wide range of IoT-specific operating systems has been developed to suit many different hardware footprints and feature needs.
Some IoT applications will generate extremely high data rates that must be analyzed in real time. Systems creating tens of thousands of events per second are common, and millions of events per second can occur in some telecom and telemetry situations. To address such requirements, distributed stream computing platforms (DSCPs) have emerged. They typically use parallel architectures to process very high-rate data streams to perform tasks such as real-time analytics and pattern identification.
IoT Platforms
IoT platforms bundle many of the infrastructure components of an IoT system into a single product. The services provided by such platforms fall into three main categories: (1) low-level device control and operations such as communications, device monitoring and management, security, and firmware updates; (2) IoT data acquisition, transformation and management; and (3) IoT application development, including event-driven logic, application programming, visualization, analytics and adapters to connect to enterprise systems.
Although ecosystems and standards aren't precisely technologies, most eventually materialize as application programming interfaces (APIs). Standards and their associated APIs will be essential because IoT devices will need to interoperate and communicate, and many IoT business models will rely on sharing data between multiple devices and organizations.
Many IoT ecosystems will emerge, and commercial and technical battles between these ecosystems will dominate areas such as the smart home, the smart city and healthcare. Organizations creating products may have to develop variants to support multiple standards or ecosystems and be prepared to update products during their life span as the standards evolve and new standards and related APIs emerge.
More detailed analysis is available for Gartner clients in the report "Top 10 IoT Technologies for 2017 and 2018." This report is part of the Gartner Special Report "The Internet of Things", which looks at the necessary steps to building and rolling out an IoT strategy.http://www.gartner.com/newsroom/id/3221818http://www.gartner.com/newsroom/id/3221818
