            [0] => /forum/threads/where-are-the-semiconductor-breakthroughs-for-ai.23967/
            [XF] => 2030871
Where are the semiconductor breakthroughs for AI?
milesgehm
Active member
It seems like the current attitude is: Apple needs a trillion-parameter model so Daniel can plan his vacation. Apple will buy 0.666 billion Nvidia chips. That requires more power than the Hoover Damn (sic). Solution: buy the chips, build 2 nuclear power plants, charge the people more for the electricity they need to cool/heat their homes. Daniel gets to go on a vacation that is better.
Where are the breakthroughs in architecure and chip design that avoid this disaster?
The breakthrough you're asking about exists, and it starts with a radically different approach: what if we could do the same AI computations with 100-100,000x fewer transistors? Dynamic Reconfigurable Data Center Logic (DRDCL), developed by SoftChip, does exactly that by fundamentally rethinking how silicon is utilized. Current AI chips waste enormous resources because they're built as fixed-architecture processors. A typical solution might use 3,200+ transistors where DRDCL uses just 38 - and those 38 transistors can dynamically reconfigure in nanoseconds to perform thousands of different operations. This transistor efficiency translates directly to 100-100,000x power efficiency improvements and 99% power reduction at the datacenter level. The real-world impact: instead of needing two nuclear power plants for Apple's AI infrastructure, DRDCL could deliver equivalent performance using a fraction of the chips and 1MW instead of 100MW.
This isn't theoretical - it's mathematically proven (original paper, addendum) and we're raising capital to develop the silicon compiler that will integrate DRDCL seamlessly into existing chip design workflows. Today's AI infrastructure runs at catastrophic 5-25% utilization for inference workloads - meaning 75-95% of the silicon Daniel's vacation planner uses is sitting completely idle, burning power for nothing. DRDCL's architecture can push utilization to 85-95% while using orders of magnitude less power per computation. We don't need to choose between AI services and heating people's homes - we need architectures that aren't burning $400 billion worth of silicon doing nothing. The mathematical proofs are published. The architecture is patent-pending. The industry needs this now.
- Tom Jackson, Founder & VP Business Development, SoftChip
TJ@SoftChip.tech
I respect the writeup and the work your team is doing. This looks honestly exciting, and I'm glad (as a consumer and enthusiast) to see someone is tackling this from a different angle. (Of course - with 1,000x greater power efficiency, software developers can always invent new ways to need 1,000x more energy to achieve the same result -- see Python vs. C++/Assembler in CPU history).
However, I would caution that this efficiency gain is not proven until there's working silicon and independent benchmarks have proven the results.
P.S. What's doubly exciting is - if this does work as stated, you won't even need 'the most advanced node' to (significantly) exceed the performance of GPUs. That could help with cost and availabiltiy of products tremendously. Good luck with this.
Respectfully,
John
Just a dumb question - your technology could work for replacing logic, but the big challenge for AI isn't the logic. It's really the architecture that links computation to massive amounts of memory and the ability to map and execute models to the combination of compute and memory. From your paper, you don't do anything for memory. Are you suggesting static memory within in your chips ?
I think you're a little off on your thinking - there are really three different pieces to the puzzle.
* Data Center training
* Data Center inference using frontier models
* Edge / client inference
Hopefully Apple and Daniel use mostly edge / client inference for most tasks - there are many companies including Apple that are doing all kinds of innovation to build better hardware and optimized models for client-side usage. Data training and inference is much more focused on rack level optimization for tuning hardware and very large models. And like the semiconductor industry, or CPU industry, most of the improvements aren't breakthroughs, but a slew of steady optimizations across all aspects. Watch this bit from Andrej Karpathy, one of co-founders of OpenAI. The whole 2 1/2 hours are totally enlightening, but this bit deals with the evolution of AI - no breakthroughs, just improvements all over.
John,
Thank you for the thoughtful response - you're absolutely right on both counts.
On the software efficiency paradox: you're describing Jevons paradox perfectly - efficiency gains often just enable more waste. That said, orders of magnitude improvements aren't just incremental gains, they're revolutionary shifts. We're talking about the difference between needing nuclear power plants versus not. That headroom matters.
On proven silicon: completely agreed. The mathematical foundation is peer-reviewed and the architecture is patent-pending, but you're right that nothing substitutes for working silicon and independent benchmarks. That's exactly why we're seeking fabless partners who can take DRDCL from mathematical proof to production-ready IP. That's exactly why we're seeking fabless partners to bring DRDCL to production silicon.
Your P.S. hits on what excites us most: DRDCL's power efficiency, speed, and real-time reconfigurability can deliver competitive performance on mature manufacturing nodes. That's what changes the economics - revolutionary performance without the expensive fab dependency or multi-year lead times.
- Tom Jackson, Founder & VP Business Development, SoftChip | TJ@SoftChip.tech
Kevin,
You're right that the memory wall is a critical crisis - but it's not the only one. We're building nuclear power plants and $30B fabs because traditional architectures use 3,200+ transistors where DRDCL uses 38, AND they spend 70-80% of their energy and time moving data between compute and memory.
DRDCL attacks both problems:
Logic Efficiency: 100-100,000x fewer transistors for the same computations through nanosecond reconfiguration - the same 38 transistors perform thousands of different operations. Radically reducing chip area and power dissipation while increasing logic speed will be very helpful for AI, even as memory remains the dominant bottleneck.
Memory Bottleneck Solutions: Dynamic reconfiguration accomplished by the chip logic itself, combined with integrated short-term memory elements (microseconds) with negligible impact on chip density, opens up new architectural possibilities. The transistor efficiency creates headroom for on-chip I/O acceleration:
Integrated I/O acceleration - circuits dynamically optimize data movement patterns
Adaptive memory controllers that reconfigure based on access patterns
On-chip preprocessing for data compression/decompression to reduce bandwidth requirements
Intelligent caching that adapts to workload patterns in real-time
We're essentially flipping the ratio: instead of 70% data movement overhead and 30% computing, we're targeting 80% useful compute with 20% optimized I/O. This might even lead to completely new architectures that aren't possible with today's fixed silicon.
This is why we're focused on the silicon compiler first - the tooling needs to handle the logic reconfiguration and I/O optimization to fully exploit what DRDCL enables.
Kevin,
TJ@SoftChip.tech
I read the papers you posted. Really dense stuff. Lots of familiarity to me though, since I've unfortunately been forced to think about (for one reason or another) every generation of reconfigurable logic that's come along since the 1990s. One of the projects in one of my chip groups was called "programmable state machines", and reading your papers was very reminiscent of some of the ideas, and the reasoning was similar to what your papers discussed. That programmable state machine work never came to fruition, because the area of computing it was aimed at wasn't really broad enough to justify the investment, and static state machine implementations were just a better way to go.
What you're discussing, replacing CPUs, GPUs, and TPUs (and other computing accelerators) is much broader, and, assuming you had a practical solution, could justify a large R&D investment. The question that sticks in my mind though, and isn't answered in the papers, is how your company sees the full stack implementation of DRDCL with existing AI applications. Obviously, these are written in programming languages intended for instruction set driven chips. It seems like, from your posts, you think your devices will replace the instruction-set chips, or did I misinterpret and are you thinking your devices will be more like accelerators and just augment conventional devices? How do you think your strategy will go from Python (just as an example) to utilizing DRDCL devices? Recompilation is probably no problem, but unless you can run current applications, meaning you don't need applications specifically designed for your chips to execute, it is difficult to see the path to success in a reasonable time frame.
Can you elaborate?
Wow, that video is amazing! Mind blown.
You're absolutely right that the industry advances through continuous optimization across all layers. The Karpathy perspective on incremental improvements is spot-on for how AI models and software evolve.
Where DRDCL fits is at the hardware architecture layer - and here, breakthroughs do occasionally happen. The transistor, the integrated circuit, the shift from CPU to GPU for AI - these were discontinuous jumps, not incremental improvements. DRDCL represents a similar architectural rethink: we're not shrinking transistors, we're making transistors work better. Instead of fixed silicon running software, we have silicon that reconfigures in nanoseconds to match workload demands.
Your three-tier breakdown (datacenter training, datacenter inference, edge inference) is exactly right. DRDCL's 100-100,000x power efficiency and real-time reconfigurability deliver benefits across all three:
Can you elaborate?
Hi Blueone,
Excellent question - and thanks for investing the time to read our papers. You identified the critical adoption challenge. Your programmable state machine experience gives you exactly the right context to understand both the opportunity and the implementation complexity.
You're right that we're not replacing instruction-set architectures at the application layer. DRDCL fits into the design flow at the chip design/synthesis level, not the application runtime level. Here's how the stack works:
The Design Flow:Engineers continue using standard HDL (Verilog, VHDL, SystemVerilog) to describe their designs - whether that's a datacenter AI processor to compete with NVIDIA, an edge AI chip, or a custom ASIC. Our Silicon Compiler acts as a drop-in replacement for traditional synthesis tools in existing EDA flows:
Traditional: HDL → Synthesis (Synopsys/Cadence) → Gate-level netlist → Place & Route
  • SoftChip: HDL → SoftChip Silicon Compiler → Optimized DRDCL trees → Place & Route (same tools)
[detailed graphic below. more details on request]
The compiler uses AI-assisted Monte Carlo optimization to convert HDL descriptions into optimal DRDCL tree configurations, then integrates back into standard EDA flows (Cadence, Synopsys, Siemens).
The Application Stack:Python/TensorFlow/PyTorch applications run unchanged. They compile to whatever instruction set the chip designer chose - we don't change that. What changes is the efficiency of the underlying hardware implementing those operations. A chip designer building an AI processor gets 100-100,000x better power/performance from their HDL using our compiler instead of traditional synthesis - enabling them to build chips that compete with or outperform NVIDIA without the power/thermal constraints.
Target Use Cases:We're primarily targeting chip designers building AI processors - whether datacenter chips competing with NVIDIA's GPUs, edge AI chips for power-constrained environments, or custom ASICs for specialized AI workloads. The power/performance advantages make previously impossible designs viable.
Does this clarify the positioning? Do you see anything we're not considering? Happy to dive deeper into any aspect.
Best,
Hi Blueone,
I guessed this was your objective.
This is also basically what I guessed you'd say. (I always want to be sure when I'm guessing.) You're assuming the silicon compiler will transparently insert DRDCL blocks into a custom ASIC design. I see the challenge as there are basically two categories of AI chips being designed. C1: Nvidia and AMD GPUs. C2: The custom AI processors being designed by Google (TPUs), Microsoft (Maia), Amazon (Tranium and Inferensia), Meta (MTIA), Tesla (A15)... there are probably others. C1 is almost certainly off limits, so C2 is your target market. Unfortunately, if that's the case I think you have a very tough road ahead of you to get any of these major companies to risk a very expensive chip design, with so much at stake for their businesses, on an unproven technology, however promising. And C1 + C2 >= 99% of the AI datacenter chip market. Or you could look to just get acquired and go to internal development. (Intel once acquired an Ethernet switch ASIC company because they were using asynchronous logic, and that fascinated some of their senior technologists. Nothing came of it, but they did achieve an exit.)
My top of mind suggestion, which is probably worth what you're paying for it, is not to count on the AI ASIC integration path at first. I suggest you use your technology to create an accelerator chiplet for some market segment's very important and CPU-intensive functionality that needs a very high performance yet low power silicon solution. Design the chiplet to the UCIe interface, and find one or more partners in an ASIC business that needs your strengths. Networking protocol processing, data compression, encryption, security protocol processing... there must be others. Prove the technology and when you can excite everyone with hardware results go after one or more of the custom cloud AI processors to acquire you or incorporate DRDCL chiplets in their designs. Another possibility along this line of thought is to partner with an existing chiplet provider, like Ayar Labs.
We're at a very different place and time, but I remember Xilinx experimenting about 15 years ago with dynamically changeable logic for advanced datapath designs where the theory was that the logic would change each cycle for the next stage rather than the data moving to the neighboring logical block. Each CLB had 8 on the fly changeable LUTs. I think that project ran into 3 problems as I remember it -
* Design partitioning / mapping over 2 dimensional layout and the added time dimension was ugly.
* Utilization was far lower than expected because routing resource limits precluded time domain reuse of some of the logic. Basically, the routing wasn't flexible enough to keep up with functional variability.
* I/Os and memories were still too contained and fixed. Great datapaths aren't so useful if you can't eventually store the data and get it to the next chip.
The latest from Jim Davis, patent author, on Xilinx.
"Thanks for reminding me of the secret Xilinx project. I'm not familiar with its details although I heard about it from a Xilinc executive that was on the @Road Board with me .... I don't believe DRDCL will have the same issues largely caused by circuit and chip architecture Xilinx chose. DRDCL and its Silicon Compiler will be largely driven from the target chip dataflow from the chip fixed boundary inputs and outputs, and will exploit DRDCL tree's having multiple outputs, trees having the capability of reprogramming any of those outputs based on its other outputs. I'm also sure we will discover other flexibilities as we work to develop the Silicon Compiler."
Just saw this blog this week - best specific predictions on where the power/performance/cost breakthroughs will come for the current forms of LLMs over the next 3 years. The biggest silicon component is semiconductor component is the 5x via heterogeneous system scaling. To find out what that means and how it's achieved, you need to read the blog.
One other important realization from this article - It's important to look at MFU (Model FLOPs Utilization), the metric used to measure the efficiency of large language model (LLM) training on hardware like GPUs or TPUs. MFU represents the ratio of the actual computational throughput achieved during training to the theoretical peak throughput of the hardware. DeepSeek V3/R1 inference system, which features FP8, Wide-EP, and PD disaggregated serving. Despite being released a year ago, DeepSeek’s software efficiency—with ~35% MFU for prefill and ~15% MFU for decode—still outperforms many US model providers which typically operate in the 10-20% zone.
I wonder if there are a few 'simple' "architecture" tweaks that might provide high yields.
Examples: 1. A better caching strategy to reduce demand on memory, 2. Reducing clocks of AI GPUs further to allow lower voltages to significantly improve power efficiency, 3. Is HBM clocked efficiently or for performance (tweaking the frequency/voltage/bus communications curve here for better efficiency). 4. Some kind of memory compression implementation that provides a better balance than traditional INT4/INT8/FP16 decision making.
It seems like when your silicon product 'must' be better than the previous generation in terms of performance, the performance/efficiency ratio tends to favor efficiency less over time.
TJ@SoftChip.tech
Can this help Bitcoin chip?
Do you really mean yields ? I think the holy grail for data center inference now is the right combination lower power, lower cost, higher capacity, and acceptable latency. But it sounds like the next major ‘tweaks’ come from specializing the hardware resources to the specific application/model architecture.
I don’t think there is any possible reduction in memory demand - the KV cache is central to transformer models and is poised to grow. Tiering and better routing help.
Sorry - poor choice of words on this forum. I should have said 'might yield greater efficiency'.
i.e. is it for certain that GPUs like RTX PRO 6000 (Blackwell) aren't leaving some efficiency on the table for AI workloads just via lowering the clocks a little bit (allowing for lower voltage)? etc.
Are there classic/boring ways to get a 2X overall improvement in efficiency even with existing hardware being produced.
In my naive world, “goodness” all comes down to this set of curves for data center inference - cost per million tokens, with cost including capital costs and energy/cooling expenses, versus multi-user max token rates for a range of standard models, user context sizes, etc. Max token rate is important, because neoclouds can charge more for lower latency and faster rates in their service level agreements. So far SemiAnalysis is the only entity that really benchmarks at this level with somewhat realistic data center level loading, but others, like Artificial Analysis, seem to be moving in the same direction.
In the paper I linked earlier, I thought the author did a good job speculating on where the 1.25 to 2x logic improvement was going to come from. But the real wins come from aligning and co-optimizing the entire inference stack (application/model/networking/processor) for rack and data center level configurations and loads.
