            [0] => /forum/threads/euv-was-never-going-to-be-single-patterning.8935/page-3
EUV was never going to be single patterning
The focus for minimal LER is different for different pitches and patterns. A big contribution is from "fading" which originates from the light propagating in the EUV mask being different for different angles.
If you can not measure it correctly, then you can not control/adjust the process properly. Currently, CD/LER/LWR and LCDU are reported from CDSEM(rarely from AFM, OCD will be different approach). Result from thin resist(<20nm) is impacted by CDSEM image quality severely. CDSEM noises might contribute more than 100% on true data from the wafer(process). It used to be nuisance in mature nodes like 14nm and above, but it becomes critical in advanced nodes. For details, you might refer to the paper reported by imec in SPIE conference: https://www.spiedigitallibrary.org/...sist-for-high-NA-EUVL/10.1117/12.2614046.full
Fractilia FAME 300 relies on SEM images, is there already noise control applied?
There is also this one: https://doi.org/10.1117/1.JMM.21.2.021207
It is impractical to use AFM for metrology in production, but for research work it looks increasingly necessary to use AFM to get accurate results.
AFM could be complementary to CDSEM and OCD. There is hybrid metrology methodology to be used in advanced nodes been discussed in the past 5-10 years. In the thin resist CDSEM challenge study, AFM was used to validate PR thickness and profile if applicable.
