            [0] => /forum/threads/can-intel-recover-even-part-of-their-past-dominance.23972/page-4
Can Intel recover even part of their past dominance?
Looking back at how Intel lost it's dominance, it's almost as if someone came from the future to sabotage the company:
- 2005, Intel's Board rejects Otellini's pitch to buy Nvidia for $20B
~ 2006, right before ARM and Mobility takes off, Intel divests it' StrongARM/Xscale effort. (AMD made a similar mistake that led to Qualcomm's Adreno)
~ 2007, Otellini nopes the iPhone
~ 2011, Intel's GPU efforts may have been doomed, but they exited entirely at this point with Larrabee and no replacement, just as GPUs really took off
~ 2013, Intel hires a CEO that reinforces the most complacent behavior possible - not taking AMD or TSMC seriously
~ 2018-2019, Bob Swan hedges bets with TSMC N3; combined with the strategic shift with "5 Nodes 4 Years", Bob's (then Pat's) actions ensure that Intel internal nodes will get even more expensive over the next 5 years then they would have been otherwise
~ 2022, Intel fully drops Optane, just as AI demand starts and could probably use this technology as 'higher capaicty / lower cost DRAM-like' memory
~ 2022, Intel fully fumbles the ARC Alchemist launch (Raja..) , damanging their future ability to respond to GPU demand
(Dates are from memory and may be off)
Too early to call LBT's efforts - they look good so far, but the 14A "may not be developed" disclosure in the financials signals that Intel may be ready to give up on node development. Not a sign of confidence for future potential fab customers..
Adding lots of latches/D-types to shorten pipelines (e.g. to "double frequency") does put clock rates up, but usually increases power per gate transition/operation because the D-types don't contribute any useful function, they just take power (both to propagate data and for clocking). Yes this increases OPS/mm2 and clock rate, but usually total power for a given function also increases -- this is what Intel found out the hard way with NetBurst... ;-)
We've done exactly this comparison many times in DSP design, and the conclusion is always that it's better to have more gate depth between latches and fewer latches and clock more slowly, so long as you can afford the extra silicon area because more parallel paths running more slowly decreases power but increases area for the same task.
This may not work for bitcoin miners because they also have to worry about die size/cost and squeezing more MIPs out of each mm2, and in this case extra pipelining might help meet this requirement.
Because no other chip's power consumption accounts for 80% of total cost.
Let's check 5nm as an example. If Latch/DFFs account for 30% power.
Double the Latches will have the power to 1.3X.
Lower the voltage from 0.4 -> 0.3 will have power at (0.3/0.4)^2 = 0.5625.
Since the Vth is around 0.2, so the speed will be same.
Dynamic latch is very small, maybe 5% area.
1.3 * 0.5625 * 1.05 = 0.77.
You can reduce costs by 20%, which could double your profit.
You're talking about architecture changes here, all of which which are perfectly valid but are independent of the tradeoff between PDP and voltage. That suggests to me that you're well familiar with optimizing architectures (gate level design), but not with optimizing library conditions (transistor level design and choice of library operating conditions i.e. building custom gate libraries).
Regardless of the architecture or circuit or process node, you *always* get PDP curves like the ones I posted, and there's *always* a voltage where PDP is minimized -- this moves around with process corner and exact circuit design and clock rate (which trades off dynamic vs. leakage power), but is basically defined by device threshold voltage because below this current drops exponentially (subthreshold slope, causes leakage) and above this current rises roughly as (Vgs-Vth)^2, at least for small overdrives which we're dealing with here for low-voltage operation.
With higher Vth (e.g. LVT/SVT gate, slow process corner, low temperature) the minimum PDP is both higher and occurs at a higher voltage, with lower Vth (e.g. ULVT gate, fast process corner, high temperature) the minimim PDP is lower and occurs at a lower voltage -- here are some results for N7 again showing these two extreme cases. Even for the fastest gate type (ULVT) the minimum PDP in the slow/cold corner is about 0.57V, in the fast/hot corner it's off the LH side of the plot around 0.33V, for typical conditions (not shown) it's around 0.45V.
The majority of this shift is due to process corner not temperature, and there's nothing you can do about this unless you're willing to lose a lot of yield at either chip or even wafer level. The voltage for minimum PDP hardly changes with process node because it's pretty much linked to Vth, the curves all the way from N7 down to N2 (I've done this analysis for every node) are pretty much similar except that they all move downwards each node (lower power consumption, lower gate capacitance, higher gate speed). And I have *never* seen a case where chips from the middle of the process spread have minimum PDP at 0.32V.
In practice you need to decide which power consumption to minimise, the maximum allowed (slow process corner), typical, or somewhere in between. You can't pick the ultra-low voltage for the fast corner (e.g. 0.33V) and claim this as your "operating Vdd" because hardly any chips will run fast enough at such a low voltage. This assumes that you need a constant level of processing power, on top of this if there are cases where this is lower (e.g. a CPU) then of course you can drop the supply voltage and save power by reducing both dynamic and leakage power -- but if you're just hammering away crunching data all the time (like a bitcoin miner?) you can't do this.
And just to be even clearer, to do all this you need to build custom cell libraries which meet your operating conditions, and have circuits on-chip which measure gate delay or circuit speed, and have an individually-adjustable supply *per chip*. You can't use standard cell libraries from the vendors (e.g. TSMC, Synopsys) because these invariably have corners which are based on standard supply tolerancing and are "the wrong way round" (e.g. SpeedMin=slow process/cold/Vddmin, Power_max=fast process/hot/Vddmax).
This is all just to minimise power consumption for a given function; if you want to minimise die area/cost ("double your profit") the tradeoffs are completely different, you want to run at a higher voltage to get more throughput per mm2, the result will be a smaller cheaper chip but one that dissipates more power.
Good discussion. I'm going to run spice today.
I might be telling my granny to suck eggs, but make sure you use realistic values for gate type (not just inverters), fanout (to match real circuit, typically 3 or so), tracking load, and interconnect resistance (advanced technologies are often interconnect-dominated) -- otherwise you can get unrealistic results... ;-)
I think you misinterpret decisions required due to failure with poor strategy. No company, including Intel can do what ever it puts its mind to.
As I have said before, Intel was a leader in Mobile strategy, GPU strategy, AI accelerator strategy. Cost effective execution was the weakness.
Intel cannot do graphics, they are too slow and failed (larrabee wasnt cancelled. it failed)
Optane is 5x slower than DRAM, no one wanted it and intel delayed it too long. It was cancelled when they realized there were no sales.
Intel could not do mobile, they are too expensive and slow. They did many leading edge parts and lost billions
Intel decided to outsource manufacturing because internal was 2x the price and not a node ahead. 2027 will tell us if anything changed.
Pat decided to do foundry (Knowing that Intel loses tons on manufacturing), but Intel was arrogant and told customers what they should do and no one signed up but the USG (LBT fixed that).
Intel purchase multiple AI companies.... and derailed them so they disappeared.
LBT talked about cancelling 14A since no one was committing to it and it costs billions per year to keep development going. We will see if it changes.
Side note: what if during that time, Intel had decided to outsource manufacturing (like Nvidia, Apple, Broadcom, Qualcomm, AMD, IBM) and put the resources into CPUs and Accelerators?
Intel is a very smart compute company that was very slow, expensive and customer unfriendly. LBT can make them a very smart compute company that prioritizes its strengths not its weaknesses. Not to regain 1995.... but succeed in 2028.
