            [0] => /forum/threads/most-advanced-processes-in-200mm-wafers.24260/
Most advanced processes in 200mm wafers
laurchar
Some project need low volume, compared to what 300m wafer may offer.
200mm wafer is the best choice, but limited by the process node : often 110nm, although 90nm is also offered by Skywater.
But what is the smallest process node offered in 200mm ? with which foundry ?
Laurent
200mm 90nm should be available from several foundries. For small volume and high end nodes (less than 65nm), you can try MPW wafers provided by all foundries.
