Will there ever be a chip that uses light instead of electrical current? Is it even possible?
[0] => /forum/threads/optical-chips.24011/
Between optical chips and large scale chips like the Cerebra's large-scale chip could this change the whole game as far as size and location of data centers and even bring that power to offices and the home cutting the demand for data centers in the future by as significant amount?The idea of using light instead of electricity to power computer chips is moving from science fiction to reality. Photonic chips, or optical processors, transmit information using photons rather than electrons. Because photons travel at the speed of light and produce virtually no heat, they promise enormous gains in speed and energy efficiency. Instead of metal wires, these chips use waveguides to steer light, modulators to encode data, and photodetectors to read signals.
Companies such as Intel, IBM, Ayar Labs, and Lightmatter are pioneering silicon photonics—integrating optical components with traditional transistors. These hybrid systems are already used in data centers to accelerate communication and reduce power consumption. Researchers are also experimenting with purely optical logic systems capable of performing computations through light interference, potentially transforming AI and supercomputing.
Podcast EP69: Ayar Labs and the Future of Optical I/O - Semiwiki
Dan is joined by Hugo Saleh, senior VP of commercial operations and managing director of Ayar Labs, UK. Hugo discusses the technology and application of optical I/O, its use and impact now and in the future. The views, thoughts, and opinions expressed in these podcasts belong solely to the...semiwiki.com
Many of these optical connectivity technologies are evolving with ever increased speed rate, and like everything else is labeled AI now. In this case, it is absolutely the key components of AI infrastructure or AI foundry. To me, the other 2 are XPUs and memory.The (silicon photonics) optical chips are used for data transport -- and switching, in Google's case -- but not for processing the data, this is still all-electronic and there's no obvious route to changing this.
The data center game -- and demand for optical transport and silicon photonics -- is changing because the massive AI models need data centers which are simply too big and power hungry to build in one place, so the AI processing has to be distributed over a number of smaller (but still massive!) data centers spread across a local region (typically 10-100km apart) which need to behave like one big one as far as AI is concerned -- this is what is being referred to as "scale-across". And what it needs is a monumentally huge data bandwidth between these data centers, far bigger than for any normal networking application.
Distributing it further into homes and offices simply doesn't work -- this is the equivalent of "edge computing", there's a need for this but it's nowhere near the AI data center demand.
Electron De Broglie wavelengths are ≈1 Angstrom or 10^(−10) m typically. Near infrared light used in photonics devices has wavelengths in the range of 1000 nm (or 10^(-6) m, which is 10,000 times larger than the electron wavelengths. Fundamentally, for this reason photonics circuits have to be much larger than the electron-based chips. Lack of Moore's Law type scaling is the main problem with silicon photonics for compute.Will there ever be a chip that uses light instead of electrical current? Is it even possible?
Dan, is there anything like a photonic transistor that doesn't use any electrical current out there and is even possible?The idea of using light instead of electricity to power computer chips is moving from science fiction to reality. Photonic chips, or optical processors, transmit information using photons rather than electrons. Because photons travel at the speed of light and produce virtually no heat, they promise enormous gains in speed and energy efficiency. Instead of metal wires, these chips use waveguides to steer light, modulators to encode data, and photodetectors to read signals.
No.Dan, is there anything like a photonic transistor that doesn't use any electrical current out there and is even possible?
people are trying for sure. I have seen at least one startup attempting all optical control and compute
Yes such optical modulators exist, and the small ones (ring modulators) typically occupy a few hundred um2, driven by the wavelength of light (around 1um) -- and need tens of milliwatts to drive them.I'm foggy on the details, but you can manipulate the phase of light to encode a binary 1 and 0.
An all-optical computer is theoretically possible, but of course, it is infinitely less mature than a silicon computer, and the trillion-dollar question is can it ever be as mature as silicon.
