            [0] => /forum/threads/tsmc-repurposing-old-fabs-to-bring-euv-pellicle-production-in-house.23593/
TSMC Repurposing Old Fabs to Bring EUV Pellicle Production In-House
TSMC is repurposing its old, wound-down, 8-inch Fab 3 in Hsinchu Science Park to produce extreme ultraviolet pellicles, bringing this production in-house. An EUV pellicle is a thin, highly transparent membrane stretched above a photomask to prevent particles from contacting the mask during EUV exposure. It is designed to withstand intense EUV radiation and thermal stress while minimizing optical absorption and wavefront distortion.
Producing pellicles is a way to shorten replacement cycles and exert more control over a component that, in EUV environments, must protect photomasks from particles while coping with extreme exposure conditions. Unlike older DUV processes, EUV systems operate with 400 W light sources and localized heating that can approach 1,000°C at the mask, increasing contamination risks and making pellicle performance more influential to wafer yields.
The economics around pellicles have encouraged divergent approaches. DUV pellicles are relatively inexpensive, at about $600, which has enabled their widespread use in earlier nodes. However, EUV variants have recorded prices near $30,000, which is a step increase that has deterred some chipmakers from blanket deployment and may have contributed to documented yield gaps.
By internalizing production, TSMC wants to achieve lower per-unit costs and more predictable supply, making pellicle integration viable at scale. That financial case goes hand in hand with materials research: carbon nanotube membranes are the most promising candidate to meet the twin demands of durability and optical transparency. Membranes must resist accelerated degradation from stronger light sources while minimizing absorption that would reduce exposure efficiency. TSMC plans to validate solutions as it ramps N2 and A16 process technologies, where improved pellicle performance could significantly boost yields and preserve its edge on advanced nodes.
Here is an explainer of what EUV pellicles are used for:
Is TSMC outsourcing the pellicle production to external companies right now?
TSMC repurposed Fab 3 for pellicle production last year. Fred will know more about this but TSMC did not use pellicles at 7nm but you have to use them today. Making your own pellicles can be a competitive opportunity, not using the same ones as your competitor. A reduction in cost as well. Great move by TSMC, absolutely.
Mitsui Chemicals licensed technology from ASML and IMEC to produce EUV pellicles which they sell. Samsung and TSMC have published their ongoing evaluation efforts. TSMC has gone so far to set up its own EUV pellicle infrastructure in preparation for producing its own pellicles for its own use. Without pellicles, you'd have to inspect printed wafers frequently to make sure the mask doesn't get dirty. As may be expected, larger dies are more vulnerable. But pellicles themselves get defective and can even rupture, especially with high EUV power. So the pellicle materials have been changed often. Carbon nanotubes are the most recent candidate.
This is bad, in-house production is not good
What is the purpose of horizontal division of labor?
This is an IDM in a sense.
Where are the IDM deniers?
The YouTube channel of @Fred Chen is a great source for understanding semiconductor manufacturing and technology. 👍
Intel has been using pellicles for a long while now, even pre euv, I wonder if there are any published reports or pieces on their success with them. I know they have been using EUV pellicles of different generations since at least the nxe3400 model euv machines. I wonder what progress has been made. To @tomatoma 's point, if it was profitable to make the process internal im surprised intel wouldnt have done that by now. Will the pellicles be fundamentally different to intels and recently samsung announced they will use pellicles too now.
I know intel has had years of internal debate on their worth due to rupturing issues causing loss of MA time, but seeing all these companies join the pell bandwagon this late makes me think pellicles must be the right move. So did intel gain an advantage and has more knowledge and experience? Or did they just waste years for little payoff when they couldve onboarded now like everyone else. Fascinating to see
Besides being expensive on their own, EUV pellicles limited throughput due to transmission as well as rupturing or destabilizing faster at higher power. So pellicle-less procedures have been developed. DUV pellicles are much cheaper and do not limit throughput this way but still need to deal with haze.
I dont know a single foundry that uses pellicle-less reticles.
Some 1X masks 9in+ have known use witbout pellicle
Same as the packaging guys I guess. TSMC is adding to the moat.
I'll rephrase it differently: all critical tech in-housing. Latest node manufacturing is has extremely fragile supply chains, on top of semi already being dependent on countless single source chemicals, and consumables.
While with resists, and most chemicals, you can still settle for inferior alternatives without crippling yields, a single source process stage with a consumable is a dreadful risk.
