            [0] => /forum/threads/why-advanced-packaging-programs-fail-late-the-%E2%80%9Creality-gap%E2%80%9D-and-the-case-for-sega%E2%84%A2-by-dr-moh-kolbehdari.24894/
Why Advanced Packaging Programs Fail Late: The “Reality Gap” and the Case for SEGA™ By Dr. Moh Kolbehdari
moh.kolb
Modern AI and chiplet platforms are pushing the semiconductor industry into a new regime of execution complexity. We are no longer building loosely coupled systems. Today’s platforms integrate heterogeneous chiplets, HBM, kilo-amp power delivery, advanced packaging, and die-to-die fabrics operating under razor-thin margins. Yet many programs are still managed as if the answer were simply more tools, more simulation, or more sign-off steps.
That is not the real problem.
The real problem is closure.
The industry is facing an execution gap I call the Reality Gap: the delta between intended behavior, validated behavior, and manufacturable outcomes. A design may look perfect in simulation yet fail to correlate in the lab. A successful prototype may still break against OSAT variation, assembly drift, or manufacturing reality. Teams may report local progress across multiple functions while the total system is actually diverging rather than converging.
In advanced chiplet systems, this gap grows because the domains are tightly coupled. Packaging changes signal integrity. Mechanical deformation alters electrical behavior. Thermal behavior shifts power and timing margins. Manufacturing variation perturbs all of the above. Local success in one silo can easily hide system-level failure in another.
To close this gap, we need to move beyond fragmented tool integration and focus instead on governed convergence.
This is the thinking behind SEGA™ — Scalable Engineering Governance Architecture.
SEGA is not an EDA tool. It is not a dashboard. It is not another checklist layered onto an already overloaded process. It is an execution architecture that sits above the engineering stack and governs how evidence becomes progression. Its job is to force a disciplined answer to one question:
When are we truly ready to advance?
In my view, readiness requires admissible evidence across three coupled loops.
The first is the Physics Loop: does the design satisfy its intended technical targets?
The second is the Correlation Loop: does measured behavior agree with predicted behavior within bounded tolerances?
The third is the Manufacturing/OSAT Loop: does the result survive implementation fidelity and OSAT reality, rather than just a golden prototype?
Passing one loop does not excuse failure in the others. That is exactly where many advanced packaging programs get into trouble.
And this is why packaging now matters so much.
Packaging is no longer a passive container around the silicon. It has become the active control plane for system outcomes. It shapes interconnect behavior, thermal coupling, power delivery, manufacturability, and ultimately the economics of yield and ramp. If packaging now shapes the system, it cannot be governed by fragmented evidence and meeting-driven interpretation. It needs a bounded execution model.
That is the case for SEGA.
The future of advanced packaging will not be won by whoever simulates more. It will be won by whoever closes the Reality Gap faster, with higher confidence, and with fewer late-stage surprises.
