            [0] => /forum/threads/tsmc-discloses-n2-defect-density-lower-than-n3-at-the-same-stage-of-development.22699/
TSMC Discloses N2 Defect Density Lower Than N3 At The Same Stage Of Development
fansink
Two Quarters Before Mass Production
TSMC exposed the defect density (D0) of its N2 process technology relative to its predecessors at the same stage of development at its North American Technology Symposium this week. According to the company, the defect density is below that of N3, N5, and N7 manufacturing nodes. In addition, the slide published by ComputerBase reveals that N2 is two quarters away from mass production, which means that TSMC is on-track to start making 2nm-class chips in late Q4 2025, as expected.
Although TSMC's N2 is the company's first process technology to adopt gate-all-around (GAA) nanosheet transistors, the node has lower defect density than its predecessors at the same stage of development, two quarters before mass production (MP). The predecessors — N3/N3P, N5/N4, and N7/N6 — all relied on well-known FinFET transistors. So, despite being TSMC's first node using GAA nanosheet transistors, the N2 defect density is getting lower quicker (well, steeper) than that of its predecessors before the high volume manufacturing (HVM) milestone.
The chart plots defect density against time, spanning from three quarters before mass production through six quarters after MP. Across all nodes shown — N7/N6 (green), N5/N4 (violet), N3/N3P (red), and N2 (blue) — defect densities drop significantly as production ramps, though at different rates depending on node complexity. Notably, N5/N4 displayed the most aggressive early defect reduction, while N7/N6 showed a more gradual yield improvement. The N2 curve begins with higher initial defect levels than N5/N4 but declines sharply, closely matching the defect reduction trajectory of N3/N3P.
The slide emphasizes that production volume and product diversity remain the key drivers for accelerating defect density improvements. Larger production volumes and a wide variety of products using the same process enable faster identification and correction of defect density and yield issues, enabling TSMC to optimize defect learning cycles. TSMC stated that its N2 fabrication technology got more new tape outs than predecessors (as TSMC now risks producing N2 chips for smartphone and HPC customers), so the defect density decrease curve mostly proves that.
The fact that N2's defect reduction rate aligns well with previous FinFET-based nodes is particularly significant, given the risk factors associated with introducing an all-new transistor architecture. It suggests that TSMC has successfully transferred its process learning and defect management expertise into the new GAAFET era without major setbacks (at least based on what TSMC discloses).
That translates to a current defect density, for TSMC's N2, of less than 0.2/cm^2.
I suspect that Intel's 18A defect density is north of 0.3/cm^2.
Source for Intel cause pat publicly announced D0 of 0.4 in August that would mean only 0.1 reduction in ~2 Quarters I would guess it would be between 0.25 and 0.2.
That does not square with the dramatic decline in external foundry revenue, and that would mean that although they started 18A trial production ~2Q after TSMC's N2, they miraculously caught up to N2.
One thing is certain, TSMC shares their defect density lifecycle, at least out of pride, and to demonstrate consistency, Intel does not.
Intel's FY23 external foundry revenue was $953M, FY24 was $384M, 1Q25 was $31M
I had my doubts about N2 but I have heard nothing but good things based on the PDK and the test chip results. The thing that baffles me is how are the N2 design starts outpacing N3?!?!?! TSMC N3 is the most dominant node in my career, everyone is using it. How does N2 beat that?!?!?!? Zero competition is the only answer I can think of. We shall see.
Because the cost of NRE is small compares to the advantage of N2.
If you can afford N3, you can afford N2.
N5 is a big filter.
N5 is a big filter.
Remember, ego is a big deal in the semiconductor ecosystem. If your competitor is on N2 and you are not it will be used against you. That has been the case for my 40 year career and it continues today. TSMC did not say what the split is between N2 and N2P. The early mobile adopters (Apple, QCOM, MediaTek, etc...) will probably start with N2 and the HPC customers may wait for N2P. We shall see.
Like I have said before Intel and TSMC trial production/risk production schedule are not same.
Their trial/risk production may not be the same, but the total collapse in external foundry revenue, does not indicate 18A is flourishing, quite the opposite.
Do you have concrete information that Intel Foundry would be able to recognize revenue for customers testing or in the process of taping out on 18A? My understanding is that does not come until wafers are being run. That would not be happening yet for external customers as even PTL is likely only just now running first wafers on 18A.
I take the dive in Intel Foundry revenue to be a ramp down of previously announced packaging work for the likes of Amazon.
With the tariffs and Trump's Make American Chips Again, I would think that there would be lots of interest and prepayments if 18A was working as alleged.
It's a little strange, that with all the gloom and doom surrounding Intel, an impressive defect density update would shut down the naysayers, and have everyone cheering.
We’ll all know shortly.
N2 looks to be an absolute monster of a node.
Edit: I’m going off topic with the below discussion. Probably should be in the other thread.
Again, not sure that there’s concrete information that any of these prepayments would be recognizable revenue at this point.
An industry watch item re: Intel's 18A revenue. 18A is higher performance but not density than N2/N3; which should mean it's most attractive for AI and HPC customers. A drop in demand for 18A may be signalling a slowdown in AI/HPC in general.
(Building billions of $ of AI chips on TSMC for customers not yet making money off of AI is already risky).
FANSINK, I get similar chitchat on 18A defect density ~0.3 and progressing slowly
Intel external Foundry revenues are 90% packaging, not wafers - and 18A isn't in production in 1Q25 so Intel 1Q "external foundry" revenue tells you nothing about 18A
Besides, you can't use the 1Q25 $31m revenue number in isolation because 1Q24 external foundry revenue was US$13m. So it's up 2.5x year-on-year... Very small numbers are insignificant anyways. You're not a Foundry with 384m revenue / year.
BRADY, correct. Tape out, test, qualifications are not revenues.
By looking at IFS disclosure, what do you think 18A (best wafer)'s DD is? assuming the target DD of 18A is 0.1 and a few quarters ago it was 0.4, then currently it also looks like 0.2. WDYT?
No my work out is that TSMC N2 D0 above 1
How it works:
What is size of 256 Mb SRAM TSMC Mentioned that the current Yield achieved is 90%+
1) how big is the 256 Mb SRAM
38 Mb/mm^2
256 / 38 = ~6.74 i.e. 7mm^2
2) if Intel 18A is use to make such a SRAM chip then
The assume that is a square so I square root that making plus minus 2.7mm * 2.7mm and using the D0 to yield calculator
Enter Intel 18A presented D0 figure i.e. 0.4 and if that is true that is 97% yield
3) how High the number (high is worse) that D0 to go before it dip to around 90% yield as TSMC mentioned.
The answer is D0 > 1.0 && D0 < 1.5
I am not sure myself but if the calculation is right, please TSMC don't DREAM that they can produce EYPC, that at least needed to be below D0 < 1.0 now for 6 month improvement to D0 < 0.4 this just sound too far fetch for TSMC.
Sorry TSMC is way behind Intel 18A if such a small SRAM currently can only be D0 < 1.5
As TSMC did not specified, I remember TSMC N3B was reported to be having "serious" issues
also rumor that Apple was paying only usable die not the whole wafer.
With such a low target, it is not surprise that they can beat it and it is really not mean that much.
That just bring my calculation above making more sense, i.e. N2 is not production ready for a larger chip such as EYPC compute i.e. 50 - 80 mm^2 range, it could be the same 55 - 70% yield if they go ahead. AMD will then only pay for good die not the whole wafer. I also explain why Apple do not jump into N2 right away.
They are not ready !!!!
