            [0] => /forum/threads/nvidia%E2%80%99s-800v-push-how-liteon-is-poised-to-leap-ahead-in-the-ai-power-race.23923/
Nvidia’s 800V Push: How LITEON Is Poised to Leap Ahead in the AI Power Race
karin623
Sequoia Capital partner David Cahn recently called AI power “the best trade of 2025.” The real bottleneck for artificial intelligence, he argued, isn’t compute—it’s electricity.
As firms like xAI and OpenAI build their own power plants, generator shortages are expected to last through 2030. Siemens Energy has surged 13× in two years, Bloom Energy 6× in six months—and now the AI-power boom has reached Taiwan.
Delta Electronics and LITEON Technology have seen their shares more than double as they prepare for Nvidia’s 800-volt direct-current (VDC) revolution, which will blur the line between the clean, air-conditioned “white zone” of server racks and the heavy-electrical “gray zone” of transformers and substations.
This feature includes an exclusive interview with two Lite-On executives leading Nvidia-related power projects, revealing how Taiwanese suppliers are moving beyond server racks and into the global AI energy race.
Interesting, I didn't realize data centers were powered by as low as 50V? according to the article. I thought it was usually more like 240V?
Anyway, 800V vs anything lower would definitely help reduce cable costs and ease installations due to thickness of cables. The downside of higher voltage is increased shock risk to humans handling the cabling.
Almost everything is 240VAC. Only experimental stuff is doing DC, and all the dangers of running kiloampers through flimsy looking wiring
Not sure what you are talking about. The AC lines coming into data centers are 480VAC three-phase. Nvidia is pushing the 800V architecture:
If you want more technical docs from the power/analog semiconductor companies:
I mean the racks themselves will receive 240VAC single phase as regular. DC powered racks are an expensive rarity, and few large dotcoms got vendor trapped with specialty solutions by becoming the sole large operator of a given DC rack power delivery standard.
Having worked on million-watt systems, you just learn to be careful and not do it on a bad day. I supervised crews in this area and made some of the work voluntary.
Huh? It makes no sense to use single-phase. Data centers are getting industrial three-phase power. It's better for handling power factor correction and has better efficiency.
I mean the power going to racks, no the one coming into the datacentre from the grid.
Some big dotcoms decided to use DC power inside the datacentre racks themselves, which require DC PSUs.
Yes, so did I. DC power makes sense, and three-phase power makes sense. Single-phase AC doesn't make sense anytime you're using high-power systems. But apparently you're right, at least w/r/t this CloudFlare article from 2020, where they have three-phase PDUs but they split locally into three single-phase branches.
Which still boggles my mind. Single-phase -> DC power conversion is such a pain, and it has poorer PFC/efficiency characteristics. I wonder why the heck they didn't switch to 3-phase -> DC conversion much earlier.
