            [0] => /forum/threads/long-term-reliability-of-10nm-chips.7724/
Long term reliability of 10nm chips ?
  • Thread starter Thread starter ippisl
  • Start date Start date
I
ippisl
Will long term reliability of chips decrease with 10nm, say over 28nm chips, because electromigration ? can this be happen, or is there a long term reliability that all chips must pass before being sold, something of industry standard ?
Good question, there are EDA tools that will check for Electromigration reliability effects, so the foundries will mandate that these checks be run prior to tape-out. It is in the best interest of design companies, foundries and consumers that our semiconductors be reliable and therefore validated prior to fabrication.
You're pretty optimistic Daniel. In many consumer industries we've already seen deteriorating reliability and planned obsolescence.
In the past semiconductor processes were developed for computer chips, FPGA's, instrumentation, and other longer life devices. Then came the SoC generation, which, like our millennial children, have a much lower attention span. So yes, MTBF and such is a great concern. The good news is that automotive now has the fabless semiconductor ecosystem's attention as one of the next big things so process development will need to be more MTBF focused. The same can be said for Industrial and medical IoT. Sound reasonable?
I might offer up two answers... :cool:
On the one hand, the answer is "No, designers are always responsible for analyzing powerEM and signalEM, and ensuring that the design meets their product reliability targets regardless of the silicon process node." That's kind of what some of the previous comments have suggested -- the targets vary widely, based upon whether the end application is consumer, automotive, medical, mil/aero, etc.
On the other hand, there's an underlying message in your question, about the relative difficulty in achieving EM reliability targets at 10nm... And, the answer to that question is "Yes, between 28nm and 10nm, the scaling of interconnects and the increased current density per unit area associated with FinFET devices will result in significant changes to design methods and subsequent EM analysis."
The increase in current density at 10nm will have the greatest impact on local interconnect ("M0"), low level metals (e.g., "M1" and "M2"), and especially the contacts/vias between these layers. The design variability in lithographic width/space/pitch for these layers is very limited -- unlike upper level metals, you can't simply "just make them wider".
This will manifest itself in two main areas:
(1) There will be more stringent rules from the foundry on the maximum number of fins per device, to be able to get current into and from the device through the local metal stack. (Although the distributed FinFET gate resistance is another reason to limit max_fins/device, EM will become the dominant factor.) That max_fins limit has a substantial impact throughout all facets of the methodology, from library design to wiring track allocation to signal buffering/repowering strategies. Some of the impact is already emerging, as foundation IP offerings are indeed utilizing smaller track height cell libraries.
(2) The transition from 28nm bulk to 10nm FinFET introduces an analysis issue, one that SOI designers have always needed to consider, but is new to many. The heat dissipation paths in a FinFET are much more constrained than a bulk device, and the thermal flow is increasingly toward the interconnect metals. A "self-heating" thermal analysis is required at 10nm, to estimate the local temperature increases. (Recall that the "activation" for metal migration in an interconnect is exponentially dependent upon temperature.) Previous semiwiki articles have discussed how EDA vendors are collaborating with the foundries, to incorporate thermal self-heating maps into their analysis flows.
-chipguy
Operation voltage drops ~30%. Compared with 28nm, stronger gate control will bring less variation. So EM is not necessarily the reliability killer in my opinion.
Both power density and especially current density are a lot higher in 10nm than 28nm, and metal is thinner with lower current capacity -- so all reliability issues related to these increases (EM, hot-spots, fin self-heating onto metal) are much more difficult to deal with. Variation would be smaller if not for the fact that the gate areas are smaller and supply voltage is lower, so in fact variation isn't any better at 10nm, in fact it can be worse. This is based on actuial design, not guesswork...
