            [0] => /forum/threads/intel-officially-drops-high-na-euv-for-18a-production.18835/
Intel officially drops High-NA EUV for 18A production
Fred Chen
High-NA machines are no longer a part of Intel’s production plans for 18A. But the 18A setup line in Oregon can be used for evaluating the High-NA systems.
High-NA EUV systems have significant operation logistic differences from current 0.33 NA EUV systems, due to the different field size and the hole in the pupil mirror ("central obscuration"). The former can lead to requiring stitching of lines across field boundaries, while the latter leads to pitch incompatibilities (https://semiwiki.com/lithography/31...incompatibilities-in-high-na-euv-lithography/). In particular, 16 nm pitch and smaller will have the 1X/2X pitch incompatibility made worse by the central obscuration.
High-NA EUV systems also require much thinner resists, due to 64% less depth of focus, which aggravate the roughness and stochastic effects.
dedicated offshore developers: By leveraging dedicated offshore developers, companies can tap into a diverse talent pool, often with specialized skills and expertise that may be scarce or expensive locally. This access to a wide range of skills can be particularly advantageous for niche or cutting-edge projects.
