            [0] => /forum/threads/intel-10q-filing-we-may-cancel-14a-if-we-do-not-win-a-large-external-customer.23236/page-2
            [XF] => 2031270
Intel 10Q filing - We may cancel 14A if we do not win a large external customer
Let's not forget TSMC is already demonstrating monopoly behaviors here. "If you go outside TSMC you're no longer in our inner circle" seems to be the culture, which makes it risky for AMD, Apple, Nvidia to try other foundries..
The behavior will get worse when they're safe in knowing they are a permanent monopoly.
And then, you know, just within that, given the plans, you know, at least the the contingency plans to maybe not do 14 a, I mean, I guess, this suggested if 14 a dies, does the foundry strategy die with it? And can you run a sustainable business just on internal volume with 18A and increasing outsource if 14A doesn’t do what it needs to do?
I agree this was a very good question to which LBT mumbled some generic answer only for Dave to intervene and answer.
- If 14A development is cancelled, Intel would have to outsource its CPU tiles to TSMC on notebooks, desktops and server (why? because AMD & Qualcomm are going to be on A14 for their chips by then, so if Intel wants to compete, then they have to)
- Right now, only a niche LNL & low volume of ARL-H & ARL-S are on TSMC, Xeons are still on Intel nodes. Rest are all Intel 7 or Intel 3 based notebooks. Intel said they are outsourcing about 30% of their wafers to TSMC. So, we can say that outsourcing is going to be >>30% wafers if 14A is dead in 2028.
- So now 30% of wafer outsourcing led to fab underutilization and foundry operating margins tanking from -20% in 2021 to -60% in 2024. Intel is saying 18A ramped to full volume and bringing most of the outsourced wafers back to Intel will lead them to breakeven in 2027 on Intel volume alone + some contribution from Intel 16, 12 & adv packaging.
- Foundry node trajectory - Intel 16 is ready, Intel 12 ready in 2027. Intel 6 likely ready in 2028+. Intel 18A/18A-P ready in 2025/2027.
- Idle fabs when 14A dies (2028/2029), Most of Intel 7, Intel 14 & Intel 3 because no one else can use it anymore. Let's assume Intel 3 will have uses for Intel's own products for base tiles etc. Intel 18A\18AP will have partial use as well but since most of the volume was Intel in 2027, there is a big hole in 18A wafer volume.
So, they write down all the idle fab on Intel 7 & 14, maintain underutilized Intel 4/3 fab (1 fab in ireland) and underutilized 18A fabs (fab 42/52) and outsource >>30% of wafer volume to TSMC and expect everyone to believe that economics work? So >3 leading edge EUV wafer fabs underutilized, atleast 1 Intel 6 fab (prev 7nm) & 1 Intel 16 fab (prev 14nm).
Counter argument from David Zinsner - we will win more customers for 18A along the way to make up for the outsourced Intel volume, would that customer be as large as Intel to replace most of Intel's outsourced wafer volume? If not the 18A fabs will remain underutilized. [SO, Intel does think they have capability to win customers on a node after its own use 2 year down the line to recover R&D costs - why that thinking does not extend to 14A - no clue]
So, a bunch of fabs that are underutilized (losing money as they are fixed costs), and a significant portion of your wafer volume is outsourced to TSMC. Gee! I wonder what that situation reminds me of? The answer is Intel in 2024 but only the outsourcing plan is a stop gap.
LBT should make up his mind if he wants to be committed external foundry or take Intel fabless. This strategy as described now sounds more like one leg on a boat and the other on the shore and I don't see how that works financially unless they can win considerable external customers which begs the question then why not win customers for 14A too (even on wave 1 or 2 or 3 to recuperate the R&D cost)?
If all of them second source, the monopoly would break. But this option now has a expiry date.
So, what is the worst case for IFS? It seems to me that it won't be too bad for Intel, even if 14A doesn't work out. 18A could be a super long node, potentially serving for 10 years. Its ROI is going to be quite positive from now on. However, quite a lot of process R&D jobs would be cut if that were the case.
Worst case is 14A abandoned milk 18A+++ mix and match using advanced packing.
TSMC won’t have a monopoly for very long. China will figure out EUV in the next 3-5 years and catch up.
Can you elaborate where this 3-5 years prediction comes from? What kind of research and system level engineering needed for them to have similar capability ASML now have in production?
China hired ASMLs former head of technology and have been aggressively been poaching people from ASML. They had some breakthroughs announced this year and I think they probably gave some version of EUV working in the lab. I am guessing 3-5 years from lab to commercializations but at small scale initially.
EUV is not something that is impossible for China to figure out, it’s something that’s already been done before and with some backward engineering, corporate espionage, as well as real Chinese innovation I am sure they will get there.
Actually for leading node like 14A, I don’t think there are much customers that’s have the financial resources to be early adopters. Apple , AMD , Nvidia , Broadcom and hyperscalers? Amd and Nvidia is out of question. Apple doesn’t seem to have engaged in some discussions with Intel , at least not publicly announced. Hyperscalers actually use many parts and IP from Broadcom. So I m guessing Broadcom is that external customer that Intel is engaging with to build 14A from ground up to be a foundry node
Qualcomm would be a good partner, they have an excellent foundry team. Lip-Bu knows Apple from his Cadence days. Apple would be the best fit. They could get a better deal with IFS than TSMC right now and Apple writes some VERY big checks. Remember, Apple tried to use Intel before they went to TSMC. The Intel CEO (Paul Otellini) regretted that they rejected the Apple offer. Intel Foundry would be the big dog today if the Apple deal happened, absolutely.
Actually for leading node like 14A, I don’t think there are much customers that’s have the financial resources to be early adopters. Apple , AMD , Nvidia , Broadcom and hyperscalers? Amd and Nvidia is out of question. Apple doesn’t seem to have engaged in some discussions with Intel , at least not publicly announced.Y Hyperscalers actually use many parts and IP from Broadcom. So I m guessing Broadcom is that external customer that Intel is engaging with to build 14A from ground up to be a foundry node
Y.H, this analyst (Jeff Pu, who has an OK track record on Mac Rumors - he's in Hong Kong) believes that Apple is engaging with
Intel on 14A:
July 25, 2025
Jeff Pu’s note​
According to Pu, Intel has already started handing out early 14A process design kits (PDKs) to partners, and Apple is one of the companies showing interest:
The next focus Intel 14A process will incorporate second-gen RibbonFET and PowerDirect, marking a technological evolution built upon the foundation of the PowerVia introduced in Intel’s 18A. Targeting both AI and edge applications, Intel has already provided early versions of the 14A PDK to key customers, with several expressing interest in producing test chips. We anticipate NVIDIA’s gaming GPU (low-end version) and Apple’s M series to emerge as adopters of Intel14A.
This means that Pu believes that both Apple and NVIDIA will be among the first customers to adopt 14A, possibly for lower-end gaming GPUs and future M-series chips, respectively.
Apple’s case is particularly interesting because the M-series chip manufacturing has been exclusive to TSMC, but having Intel as a second source (especially with U.S.-based fabs) could prove quite handy amid growing geopolitical (and trade) tensions.
https://9to5mac.com/2025/07/25/apple-may-be-intels-last-hope-in-the-foundry-business/
Qualcomm would be a good partner, they have an excellent foundry team. Lip-Bu knows Apple from his Cadence days. Apple would be the best fit. They could get a better deal with IFS than TSMC right now and Apple writes some VERY big checks. Remember, Apple tried to use Intel before they went to TSMC. The Intel CEO (Paul Otellini) regrets it to this day that they rejected the Apple offer. Intel Foundry would be the big dog today if that happened, absolutely.
Daniel, good points. But I was hoping that regrets don't continue in heaven - Paul
left us in 2017.
Intel on 14A:
Apple does full chip SoCs so they would be a great partner. Nvidia has designs with chiplets which would be an easy fit for Intel 14A. Jensen and Lip-Bu are well acquainted. Nvidia is a big customer of Cadence. Jensen keynoted at the last Cadence Live Conference here in Silicon Valley and announced the purchase of 10 Cadence Millennium M2000 Simulation Systems. They are around $2M per system and are packed with Nvidia GPUs.
I guess that Apples and Nvidias do not give a shxt about monopoly prices, as long as their competitors are paying the same prices. Also, Corp. executives are quite (and sometimes extremely) short-sighted, they usually don't worry about things that may (and may not) happen in 2 years out.
Every company even the trillion dollar ones or superscalar have limited resources. Do you allocate people and money to enable sa second source at Intel or use that same resource on a new and better product or accelerate one in flight?
Unless government policy or tariffs make it more economical. Was there a lesson anyone took away from cannonlake ? Who has track record to deliver and who is just talking maybe more humble now, LOL
A
Even if you have it who’d you bet your next product and ramp too?
Qualcomm and broadcom are more likely external customers. And if I heard it correctly, LB mentioned "two customers".
Intel on 14A:
July 25, 2025
Jeff Pu’s note​
Actually apple story is quite plausible. Apple is a (maybe the only) customer TSMC dare not to offend even if apple second sources from IFS. Apple also gets political cues, e.g. it just invested in $mp materials.
Some other possibly engaging companies include broadcom and qualcomm. If broadcom had enough interest to try 18A, they should try 14A as well.
Intel on 14A:
July 25, 2025
Jeff Pu’s note​
Thanks. I didn’t know that
I just think Jensen had some really bad blood with the old Intel. Also, I think Jensen and pat also know each other well but that didn’t result in anything. Thus I am doubtful. But I could be wrong 😂
People always think china once has EUV tool then they can catch up leading edge node.
Cmon, semiconductor is not only LITH or ETCH.
Like GAA or BSPDN technology which can achieve higher density/ performance with less dependency to LITH tool or small dimension request, does we see these technology appeared in China semiconductor?
The answer is no.
There are still much of thing china need to catch up, far and far away than people or some “expert” think.
As I said in another post, they should always try to get a bitcoin chip customer.
Bitcoin chips might be the only customers willing to pay for low-yield wafers.
As long as they're not confidently executing SAQP, I doubt they can advance quickly. SAQP is about how well they can leverage existing modules.
