[0] => /forum/threads/graphene-to-replace-silicon-is-it-viable.20431/
I think you meant this: https://research.gatech.edu/feature/researchers-create-first-functional-semiconductor-made-grapheneAny thoughts or comments on this would be appreciated
This is interesting as a academic exercise - "Can we engineer a bandgap in graphene" - but I think misses the point. Graphene is special precisely because it doesn't have a bandgap and that it's just one element ('C'). The community needs to think about how to exploit this in unique and novel ways, rather than trying to fit Graphene into existing paradigms.
A material does not have to be special in just one way. Plenty of ideas - and actual uses - have been found for the conductive form of graphene. That does not invalidate looking for uses for an ultra-high mobility semiconductor variant epitaxial on SiC. We can walk and chew gum.Graphene is special precisely because it doesn't have a bandgap and that it's just one element ('C'). The community needs to think about how to exploit this in unique and novel ways, rather than trying to fit Graphene into existing paradigms.
True. 2D is now a rich toolbox, Graphene, hBN, TMDs, MXenes etc!A material does not have to be special in just one way. Plenty of ideas - and actual uses - have been found for the conductive form of graphene. That does not invalidate looking for uses for an ultra-high mobility semiconductor variant epitaxial on SiC. We can walk and chew gum.
Yep. And of course, we're only considering the technical aspects here (contact resistance etc). An entire supply chain has to come together as well, from precursors to process to OEM/metrology to foundry/EDA.Plenty of uses for graphene, but for it and for any material one considers for computing purposes (unless you go back to Shannon/Turing/.... and start anew) you need something to make a good switch and for that purpose graphene is pretty lousy. Mobility is important but can be useless if you do not have all the other parameters (subthreshold slope, effective mass, complementary devices, contact and sheet resistance,....) that are also good. People is so used to silicon , where current is just proportional to mobility and all the rest is already there, that forget the basics. It already happend with the III-V hype for CMOS a few years ago with plenty of people missing the low effective mass impact in highly scaled devices.
I wrote this back in 2018 https://www.semi.org/en/blogs/techn...er-material-change-the-semiconductor-industry - https://www.semi.org/en/blogs/techn...er-material-change-the-semiconductor-industry - mostly holds but we can fill in a lot more gaps now given where the 2D field is today.Any thoughts about what place graphene may play in the semi sector if any at all?
Thanks for excellent informationI wrote this back in 2018 https://www.semi.org/en/blogs/techn...er-material-change-the-semiconductor-industry - https://www.semi.org/en/blogs/techn...er-material-change-the-semiconductor-industry - mostly holds but we can fill in a lot more gaps now given where the 2D field is today.
