            [0] => /forum/threads/digital-twins-are-not-automatically-authority.25271/
Digital Twins are not Automatically Authority
moh.kolb
Digital twins are not automatically authority.
That is the next problem in semiconductor realization.
Digital twins, fab twins, package twins, EM models, PDN models, thermal models, and AI-assisted simulations are becoming essential because modern systems are too complex to validate only through physical trial-and-error.
But a model output is not the same as decision authority.
A simulation may predict acceptable thermal behavior, but real TIM thickness, lid attach, airflow, workload burst, or board interaction may change the result.
A PDN model may pass under nominal assumptions, but package inductance, decoupling placement, VRM response, silicon switching current, and thermal drift may create real droop.
An EM model may show margin, but package escape, return path, connector transition, crosstalk, jitter, and voltage noise may reduce the field result.
The next step is not just more simulation.
The next step is governed system realization:
model fidelity
measured evidence
CTQs
uncertainty
causality
lifecycle feedback
bounded decision authority
Digital twins model the system.
Governed System Twins determine whether the model-supported evidence is mature enough to support a real decision.
#SEGAI #DigitalTwin #Semiconductors #AdvancedPackaging #AIHardware #SystemsEngineering #ThermalManagement #PowerIntegrity #SignalIntegrity #GovernedRealization
Good question.
What I mean is that a digital twin can model or simulate a system, but the simulation result by itself should not automatically be treated as a final engineering decision.
For example, a thermal model may predict that a package is safe, but the real result can still depend on TIM thickness, lid attach, airflow, board design, workload, and manufacturing variation.
So “governed system realization” means connecting the model to measured evidence, uncertainty, critical requirements, causality, and approval rules before using it to close a real design or manufacturing decision.
In simple terms:
A digital twin shows what may happen.
Governed system realization decides whether the evidence is strong enough to act on it.
Yeah I feel like the concept of a "digital twin" is more aspirational than anything because a true digital twin needs to simultaneously solve electrical, mechanical, and thermal equations.
Right now the most practical "digital twin" implementations are workflows that pass models to a number of industry-standard simulators. This is an iterative process like digital design where verification, timing, and PnR feed back to themselves.
This likely requires design-of-experiments to understand how variables affect electrical, mechanical, and thermal characteristics. This would require huge computational density. Fabs use DoEs all the time to tweak their recipes.
Rather than putting our hopes on digital twins, I think we need more DoEs than in the short term so that engineers can build intuition on how cross-domain effects couple to each other.
I agree with this. A practical digital twin should not be viewed as one perfect simulator that solves electrical, mechanical, thermal, manufacturing, and runtime behavior all at once.
The practical path is exactly what you describe: multiple simulators, DoEs, measurements, and engineering feedback loops.
That is why I frame it as governed system realization.
DoE is not separate from the twin. DoE becomes one of the main evidence-generation mechanisms inside the governed twin.
The key question is not only “what does the model predict?” It is:
Was the model calibrated?
What DoE supports it?
Which assumptions are still weak?
Are the boundary conditions correct?
Is the evidence causally connected across domains?
Is the uncertainty low enough to support a real engineering decision?
So I agree that more DoE and engineering intuition are needed. My point is that those DoEs should feed a governed evidence path so we do not overtrust any single simulator or model output.
