            [0] => /forum/threads/correct-by-construction-io-timing-solution.3724/
Correct by construction IO timing solution
Jaweed Mohammed
Hello Experts,
I'm researching a solution for correct by construction approach to solve block - block IO timing closure. Without the need to do traditional IO budgeting/prototyping, iterative constraints refining, etc..
Would appreciate any ideas/leads/references.
HI Eoin,
Thanks for the response, I guess you are referring to chip level IO pins. I'm looking for block-block IO pin timing solution.
Jaweed
