            [0] => /forum/threads/2nm-leaked-logic-density-comparison-from-x-rapidus-tsmc-intel-samsung.23528/
2nm Leaked Logic Density Comparison from X (Rapidus TSMC, Intel Samsung)
Comments on the accuracy? The other thing to note is that TSMC N2 and Intel 18A are in production. Rapidus 2HP is targeted for 2027. Intel will have 18P and TSMC will have N2x by then and Samsung 3nm never made it into HVM. I don't know where this leaked from but it certainly was not from the Rapidus presentation at HotChips. That was a nothing burger without fries.
The TSMC numbers are suspicious: TSMC has said N2 density is ">1.1X N3"; presumably that would be comparing N2 to N3B here; which is showing only a 1.03X difference.
It also looks like this leak is claiming Rapidus's "high performance" library (2HP) is comparable to TSMC's HD libraries (see below), which seems unlikely?
A lot of the numbers line up with the analysis here: Reddit post says for HD Libraries:
18A = 185
Intel 3 = 140
TSMC N2P = 236
TSMC N3E = "216 or 192"
And then the post also lists HP libraries:
18A = 164
Intel 3 = 123
TSMC N2P = 197
TSMC N3E = 183
P.S. Some interesting text in the comments comparing Scotten Jone's projections for 18A/N3 density vs. these numbers:
For N3, I believe Scotten Jones uses the densest possible 1+1 config. I don't think that's appeared in any products yet, I don't think TSMC has shown it at any presentation, and I believe it's rumored to be coming with a possible "N3S" variant.
For 18A and N2, both of Scotten Jone's 18A and N2 estimates are ~30% higher than what I'm getting. This may suggest that there potentially is some scaling factor inherent to GAA that I'm not compensating for (hence why both GAA nodes are different by an almost equal factor), or that Jones is using a theoretical, or future "densest possible library" option on both nodes (18A-P potential denser libs, N2P finflex? or still, more dense libs) like he did with N3.
Funnily enough Scotten Jones's projection for 18A's competitiveness in density is worse than mine, he has N3 peak density being ~15% better than what my numbers show
18A = 185
Intel 3 = 140
TSMC N2P = 236
18A = 164
Intel 3 = 123
TSMC N2P = 197
TSMC N3E = 183
This is very vauge afaik these are the logic densities.
Intel
Intel 7 HP -> 60 Mxtor(H408G60)
Intel 4/3 3-3 Fin -> 123 Mxtor/mm2(H240G50)
Intel 4/3 2-2 Fin -> 140 Mxtor/mm2(H210G50)
18A/AP -> hd lib -> 164Mxtor/mm2(H180G50)
18A/AP -> HP lib -> 185Mxtor/mm2(H160G50)
TSMC
N5 2-2-> 138Mxtor/mm2(H210/51)
N4 2-2 -> 143Mxtor/mm2(Wikichip)
N3 3-3 -> 124 Mxtor/mm(H221G54)
N3 3-2 -> 140 Mxtor/mm2(H195G54)
N3 2-2 -> 182 Mxtor/mm2(H169G48)
N3 2-1 -> 215 Mxtor/mm2(H143G48)
N2 HP -> 195Mxtor/mm2(H156G48)
N2 HD -> 237 Mxtor/mm2(H130G48)
These calculation are based on Mark Bohr's formula and public pitches available. There is a shortcut to calculate that just do 1.48/(H*G) if you know the value it roughly turns out to be this xDd
As expected, the development of transistor density has slowed down...
Furthermore, there seems to be relatively little difference between companies in terms of density.
intel I'm curious about the Intel 18a...
Panther I want Panther Lake...
Panther lake teardown are/will be very interesting. Also Intel financials and wafer cost from 18A ramp and JV in Arizona.
