            [0] => /forum/threads/sega%E2%84%A2-solving-the-fragmentation-trap-in-heterogeneous-system-execution.24871/
SEGA™: Solving the Fragmentation Trap in Heterogeneous System Execution
moh.kolb
As modern high-performance computing shifts toward heterogeneous AI platforms, the traditional fragmented engineering lifecycle has reached its scaling limit. SEGA™ (Systematic Engineering Governance Architecture) is a bounded-extensible execution framework designed to govern convergence across advanced heterogeneous system programs.
The Missing Layer: Governed Execution
SEGA is organized around six fixed execution phases:
Playbook
Backbone data
Ecosystem Onboarding
Convergence & Evidence Engine
Decision Control
Convergence Visibility
The Core Convergence Mechanism: Triple-Loop
At the center of SEGA is the Triple-Loop engine, which formalizes three critical closure loops:
Multi Physics Loop:
Correlation Loop: Measures simulation-to-lab agreement
Manufacturing/OSAT Loop: Verifies if production implementation matches
The XX-Step Implementation
To prevent process sprawl, SEGA classifies all actions into five step classes (Definition, Binding, Validation, Engine, and Governance) and caps the core flow at XX-steps . This allows the framework to scale from simple pilots to massive 3D multi-die HBM platforms without losing coherence.
The Path Forward: Reality Gap
The implementation success of SEGA™ is not measured only by whether a design eventually passes a gate; it is measured by how the Reality Gap closes across revisions .
By tracking the "decay rate" of the delta between simulation, lab, and OSAT, we turn convergence into a measurable engineering maturity signal rather than a vague impression of progress.
I welcome the community's thoughts on:
How are you currently normalizing evidence across your distributed EDA and OSAT ecosystems?
At what percentage do you currently "lock" your correlation tolerance for high-speed chiplet interfaces?
