            [0] => /forum/threads/versatile-whitebox-1g-ethernet-phy-ip-core-with-broadr-reach.22844/
Versatile Whitebox 1G Ethernet PHY IP Core with BroadR-Reach
t2mip
Member
T2M-IP proudly announces the availability of its Whitebox 1G Ethernet PHY IP core, a production-proven solution delivering unmatched customization, flexibility, and performance for automotive, industrial, and embedded Ethernet applications. Designed to support long-term integration and innovation, this cutting-edge PHY IP empowers customers with unlimited usage and full source-level modification rights under a highly permissive Whitebox license model.
Built on mature, high-volume production technology and compliant with IEEE 802.3-2008, IEEE 802.3az (EEE), and IEEE 1588-2008, this Gigabit Ethernet PHY is ideal for companies seeking full control over their Ethernet IP stack—whether optimizing for power, cost, or advanced system integration.
Key Highlights:
  • Whitebox Licensing Model
    Unlimited usage with full RTL access and modification rights — ideal for companies seeking long-term control and customization of their IP portfolio.
  • Multi-Node Portability
    Designed in bulk 28nm process, the PHY is easily portable across multiple process nodes, ensuring broad compatibility and futureproofing across silicon generations.
  • Automotive-Ready with BroadR-Reach™
    Integrated BroadR-Reach™ technology delivers robust, high-speed communication over single twisted-pair cables, optimized for next-generation Automotive Ethernet networks.
  • Flexible Interface Support
    Dual-port MAC interface supporting GMII (10/100/1000BASE-T) and MII (10/100BASE-T) for versatile SoC integration.
  • Comprehensive Protocol Support
    Supports 1000BASE-T, 100BASE-TX, and 10BASE-T, in both full and half-duplex modes, with advanced features like Auto-MDIX and skew correction.
  • Energy Efficiency
    Built-in Energy Efficient Ethernet (EEE) support and power-down modes make this PHY ideal for low-power and green designs.
  • Time-Sensitive Networking Ready
    Supports IEEE 1588 Precision Time Protocol (PTP) for synchronization in industrial and automotive TSN (Time-Sensitive Networking) environments.
Proven in silicon and already licensed by multiple tier-one customers in the United States, Korea, China, and Europe, this 1G Ethernet PHY IP is quickly becoming the preferred choice for companies seeking a scalable, modifiable, and future-proof Ethernet IP solution.
T2M-IP has a wide and diverse silicon Interface IP Core Portfolio, including USB, PCIe, HDMI, Display Port, MIPI, DDR, V-by-One, programmable SerDes, SD/eMMCs, and many more Controllers with matching PHYs, available in major Fabs in process nodes as small as 7nm. On request, they can also be ported to other foundries and cutting-edge process nodes.
Immediate licensing Availability: These Semiconductor Interface IP Cores are immediately available for licensing as stand-alone IP Cores or with pre-integrated Controllers and PHYs. Please submit a request / MailTo for more information on licensing options and pricing.
About T2M: T2M-IP is a global independent semiconductor technology expert, supplying complex semiconductor IP Cores, Software, KGD, and disruptive technologies to allow faster development of your Wearables, IOT, Automotives, Communications, Storage, Servers, Networking, TV, STB, and Satellite SoCs. For more information, please visit www.t-2-m.com.
