            [0] => /forum/threads/sondrel-announces-tape-out-of-its-largest-chip-design.13718/
Sondrel announces tape-out of its largest chip design
Divide design to conquer
Reading, UK – 2 November 2020. Sondrel has announced the tape-out of its largest chip design for a customer. This has taken a team of up to 200 engineers working on it simultaneously at times to design the 500 square millimetre chip that has over 30 billion transistors, 40 million flipflops, and 23 thousand pads for I/O, power and ground.
“This initially started out as a design for 28nm technology,” explained Stuart Vernon, Sondrel’s Senior Director of Physical Design. “However, it soon became apparent that, on 28nm, it would either be one very big chip, which would not have been cost effective, or it would have to be be split into two connected chips, which would introduce parasitics and timing issues. So the decision was made to use the 16nm TSMC process node to enable the design to fit onto a single chip at a cost effective price point.”
Around a third of the floor plan of the chip is the block with the customer’s IP that handles the real-time image processing. Sondrel wrapped round that support blocks of Graphical Processor Unit, two Central Processor Units, on-chip cache memory, PCI and USB interfaces plus memory controllers to off-chip memory using over 7 kilometres of metal tracks on a chip the size of a postage stamp.
It would be impossible to design a chip of this complexity in one go as it has 300 million placeable logic cells and the placement tool can only handle 3 million at a time without the runtime becoming excessive. It was therefore divided into manageable-sized, functional blocks over four levels of a hierarchy structured like a pyramid. This enabled the design of the blocks to be divided between Sondrel teams that are located around the world. Once each block was finished, the big challenge was to bring them all together by creating abstract models of the lower blocks to provide input for the higher blocks so that the size of the part of design being implemented remained manageable. As the chip can run at up to 100 Watts, even the heat output of the different parts of the chip have to be allowed for in the design to prevent hotspots
Once all the component blocks had been implemented, the whole design was run as a complete unit on a dedicated computer farm consisting of 25 computers, each with 24 CPUs and 1.5 Terabytes of memory, and over 100 software licenses to perform physical validation checks, which took two days.
“We are one of the few digital design companies that can handle a design of this size and complexity, and we have several more nearing completion,” said Graham Curren, Sondrel’s CEO and Founder. “A key part of this is our experience of managing the logistics of having teams in seven different locations and co-ordinating their work. For example, our teams in India and China work in the evenings to maximise the overlap with our teams in Europe.”
About Sondrel™
Founded in 2002, Sondrel is the trusted partner of choice for handling every stage of an IC's creation. Its award-winning define and design ASIC consulting capability is fully complemented by its turnkey services to transform designs into tested, volume-packaged silicon chips. This single point of contact for the entire supply chain process ensures low risk and faster times to market. Headquartered in the UK, Sondrel supports customers around the world via its offices in China, India, France, Morocco and North America. For more information, visit www.sondrel.com/careers
Press contact:
Sondrel is a trademark of Sondrel Limited
