            [0] => /forum/threads/security-goes-offence-instead-of-defence.10033/
Security Goes Offence instead of Defence
This security that takes system security from defense to offense could bring major changes to both software and hardware. Right now the economic scales make attacking a system far cheaper than defending one. This would tip the scales in favor of defense, making defense cheaper than offense, causing a radical change throughout the tech industry at all levels. Polyverse may be a game changer across both hardware and software. Any opinions and thoughts on this are solicited and appreciated. Could this be the radical change of fortunes needed to speed progress in the industry by removing a ever growing security problem?
It works by constantly using binary scrambling of code making an attack strategy a single use event, driving up cost and difficulty immensely. Any other thoughts on security defense would also be appreciated. How might this also affect semi design?
This is especially important with the massive security failure in Intel chips. I wonder if a version of this might be the best fix for the Intel security problem. It's time for better security than the failing patch work mess we have now, it's way beyond time for a more effective approach.
With the new Meltdown and Spectre attacks that may even require new hardware to mitigate and the performance drop caused by new patches and the fact like old routers may never get an update this has become an even more serious issue for the semi industry. This is further degenerated now that class action lawsuits have been filed in several jurisdictions.
The bottom line is it takes not just technical excellence to solve the security issues now and in the future, but great strategy and strategy is a totally different skill set than technical skills and rarely in the same person. This will have to be a team work effort.
Polyverse | Cyber Resilience, Zero-Day & Moving Target Defense
Meltdown and Spectre Vulnerability Fixes Have Started, But Don'''t Solve Everything | WIRED
Addition, the story behind the current meltdown
‘It Can’t Be True.’ Inside the Semiconductor Industry’s Meltdown - Bloomberg
Good find Arthur. Address Space Layout Randomization has been around for a while, usually static in what is practiced today. Dynamic randomization is likely to be more expensive (more overhead). I wrote about this a couple of years ago (https://www.semiwiki.com/forum/content/6446-hack-q-making-software-moving-target.html). Like all good defenses, we probably need a spectrum of anti-invader barriers. Behavioral detection is a hot area right now, honeypots to trap attackers are another possibility.
