            [0] => /forum/threads/asml-sets-new-euv-chipmaking-density-record-proposes-hyper-na-tools-and-radical-euv-speed-boosts.20305/
ASML sets new EUV chipmaking density record, proposes Hyper-NA tools and radical EUV speed boosts
Smaller, faster transistors at unprecedented speed
ASML
(Image credit: ASML)
ASML announced at imec’s ITF World 2024 conference that it has now set a new chipmaking density record with its first High-NA machine, surpassing a record it set just two months ago. ASML‘s former President and CTO, Martin van den Brink, who now serves in an advisory role at the company, also proposed that the company could develop a Hyper-NA chipmaking tool to deliver further scaling beyond its High-NA machine and shared potential roadmaps. He outlined a plan to reduce EUV chipmaking costs by radically boosting the speed of future ASML tools to 400 to 500 wafers per hour (wph), more than double the current peak of 200 wph. He proposed a modular unifying design for ASML’s future families of EUV tools as well.
Van der Brink said that, after further tuning, ASML has now printed 8nm dense lines with its pathfinding High-NA EUV machine—a density record for a machine designed for production environments. This beats the company’s own record it set in early April when it announced it had printed 10nm dense lines with its pathfinding High-NA machine located in its joint lab with imec at ASML's Veldhoven, Netherlands headquarters.
For perspective, ASML’s standard Low-NA EUV machines can print critical dimensions (CD—the smallest feature that can be printed) of 13.5nm, and the new High-NA EXE:5200 EUV tool is designed to create even smaller transistors by printing 8nm features. As such, ASML has now demonstrated that its machine can meet its basic specifications.
ASML
(Image credit: Tom's Hardware)
“Today we have made progress to the point that we are able to show record imaging down to 8nm being corrected over the full field, but also having some level of overlay,” Van der Brink said, “This is not perfect data, by the way, but it is just to show you the progress. We are confident today that where we are with High-NA, that we will be able to cross this to the finish line in the coming time."
The milestone represents the culmination of more than 10 years of R&D and billions of Euros of investment, but more work remains to be done to optimize the system and ready the technology for mass production at major chipmakers. That work is already underway in the Netherlands, while Intel, the only chipmaker that’s known to have a High-NA system already fully assembled, is following closely in ASML’s footsteps as it brings its own machine into operation at its D1X fab in Oregon. Intel will use its EXE:5200 High-NA machine for R&D purposes at first, and then press it into production for its 14A node.
Van der Brink also proposed a new Hyper-NA EUV machine once again, but no final decision on the machine has been made — It appears ASML is gauging industry interest, but only time will tell if it comes to fruition.
Today’s standard EUV machine uses light with a 13.5nm wavelength and a 0.33 numerical aperture (NA—a measure of the ability to collect and focus light). In contrast, the new High-NA machines use the same light wavelength but employ a 0.55 NA to enable printing smaller features. Van der Brink’s proposed Hyper-NA system would use the same wavelength of light again but widen the NA to 0.75 to enable printing even smaller features. We aren't sure of the proposed critical dimension, but ASML's transistor timeline above shows it is intercepting at 16nm metal pitches (A3 nodes) and extending to 10nm (sub-A2 nodes).
According to the roadmap above, Hyper-NA could be feasible for single-exposure 2DFET transistors, but it isn't clear if using High-NA with multi-patterning could also create such fine pitches.
As you can see in the first slide above, this machine wouldn’t come until ~2033. Today’s High-NA machines already cost around $400 million. Hyper-NA would be a more expensive option due to the need for larger and more advanced mirrors and an improved illuminator system.
As with its predecessors, the goal of Hyper-NA is to enable printing smaller features with a single exposure to avoid multi-patterning techniques (multiple exposures of the same region) that tend to add time and steps to the chipmaking process while also increasing the chance of defects, all of which conspires to increase costs. Van Der Brink said that continued development work on resists and advanced masks would be key to improving the resolution of printed features. Hyper-NA would also use an improved illumination system for optimum results. ASML didn't elaborate, but It's logical to think the improved illuminator would pair with a higher-power light source to help increase the dose to both offset the higher mirror angles used for 0.75 NA and to improve throughput.
Van der Brink also proposed increasing the throughput of the company’s future machines from ~200 wph today to 400 to 500 wph in the future. This is another lever that ASML can pull to reign in costs, thus combatting the increasing price per transistor trend with each new generation of chips.
ASML
To speed development and reduce costs, ASML already uses its existing Low-NA Twinscan NXE:3600 EUV machines as a building block for its new High-NA machine. ASML's Low-NA models have a modular design that allows the company to leverage proven technology and modules for its new tools, and the company only adds new modules where needed.
However, there’s room for much more optimization. Van der Brink sees the company doubling down on the modular design philosophy as it creates new tools over the coming decade. The proposed long-term roadmap shows Low-NA, High-NA, and Hyper-NA all having an increasingly common modular platform with shared components. This design is yet another lever that ASML could pull to rein in costs.
The chip industry appears to have a solid runway for future development through Gate-All-Around (GAA) and complementary field-effect transistors (CFETs) built with Low-NA and High-NA tools, but aside from Hyper-NA, no real candidate has stepped forward to potentially enable future generations of process node technologies. As always, cost will be the key factor, but ASML is obviously already thinking of ways it can make the Hyper-NA pricing equation more attractive to its customers.
16nm metal pitches for A3 node and 10nm for sub-A2 nodes?Unlesss we are talking about CFET, that seems too pessimistic even considering the slower NS/FS metal-pitch scaling due to the power rails moved to wafer backside. 0.33NA EUV + SADP/SALELE can get close, even 193i DUV+SASP(7x) have a chance to reach 12nm metal pitch (but certainly with a lower yield). Our industry may push the NS/FS metal pitch to the extreme (most likely using high-NA EUV+SADP/SALELE: ~10-nm metal pitch) before they switch to CFET structure. After that, CFET density scaling is totally different as the n+p vertical stacking will have extra space to allow much more relaxed BEOL metal pitches. In short, once logic moves to CFET, we don't need that tight pitch (just like NAND going vertical and no litho bottleneck any more) and a hyper-NA EUV won't be a must-have for a very long time.
The stochastic electron scattering in the EUV resist is more of a limiter below 40 nm pitch, so the NA increase doesn't offer any benefit, while adding the issues of reduced depth of focus and polarization. High-NA can't even resolve 12 nm pitch optically.
There were so many recent SPIE papers on attempts to do 28 nm pitch by single exposure, that's already a big hint. 28 nm pitch doesn't push the optical limit of 0.33NA.
The CFET transition will probably happen above 20 nm pitch (~2nm node design rules).
It's a good to remind our society that there exists a critical point where the optical resolution will be annihilated by the thermodynamics related stochastic phenomenon (e.g., shot noise) . Indeed, that is around the corner at the deep nanoscale. CFET still faces tons of technical challenges and it probably will take a longer time to be developed.
The critical parameter that's really slowed down per node though is power consumption -- density is still increasing, power has almost stalled, which also means that power density (self-heating) is going up. This is increasingly a problem, especially for high-speed circuits, and backside power makes it even worse... :-(
There's no "magic bullet" coming to fix this that I can see, it's all about cramming more and more drive and transistors into a smaller and smaller area.
I agree heat density makes things worse but why do you see BSPD as worse? It reduces impedance and droop which should improve operation at lower voltage. The self heating limits are reachable on front side anyway, so improving the power path should be a good thing for power.
BSPD helps with power delivery, means clock rates can be increased, density goes up a bit all of which increases power density in W/mm2.
But we're finding self-heating is becoming an increasing problem, especially for high-speed circuits such as SERDES. BSPD increases thermal resistance in the on-chip heat transfer path both globally (the whole chip runs hotter) as well as locally (hotspots caused by local rises in substrate temperature underneath -- or over, with BSPD -- high-power-density circuits) -- where "temperature" here means the transistors and low-level metal layers where self-heating causes the biggest problem by reducing allowable current density while keeping under electromigration limits.
The global problem is why TSMC recommend BSPD (A16) for "data-centre products with active cooling", because the temperature difference between transistors/metal and heatsink increases, which means for the same EM limits you have to keep the heatsink cooler. The local problem means there can be a significant local temperature rise under (or over with BSPD) high-power-density circuits -- in the past we've seen up to +20C due to this, which would mean you have to keep the heatsink 20C cooler to meet the same reliability criteria. This isn't all due to BSPD -- it happens with FSPD as well -- but it makes the problem worse.
Whether this matters for a given device completely depends on the application. For example if it's a liquid-cooled AI chip (or with a *massive* air-cooled heatsink) where the heatsink can be held at maybe 50C none of this is a problem; if it's a device with passive cooling where there's no space for a massive heatsink or liquid cooling and the heatsink is at maybe 90C then it is a problem.
And yes, this is all based on detailed thermal analysis of actual devices where reliability is critical, not just some hand-waving speculation... ;-)
