            [0] => /forum/threads/optics-is-moving-closer-to-compute-scalable-trusted-realization-layer-strl-is-needed.25305/
Optics is moving closer to compute. Scalable Trusted Realization Layer STRL) is needed
moh.kolb
Optics is moving closer to compute. Realization risk is moving closer with it.
Optical interconnect is moving closer to the compute engine.
From FRO and TRO to LPO, LPO with CPC, and ultimately CPO, the direction is clear: reduce electrical signal distance, remove unnecessary DSP overhead, and improve power efficiency.
At 1.6T, power can potentially drop from roughly 25W in full-retimed optics to around 7W with co-packaged optics.
For AI data centers, optics is no longer just a connectivity layer. It is becoming a core part of compute infrastructure.
But this shift also changes the engineering problem.
The closer optics moves to the engine, the less it behaves like a replaceable module and the more it becomes part of the package/platform realization path.
Electrical launch, package escape, fiber attach, thermal drift, coupling stability, test access, serviceability, and lifecycle reliability all become part of the same system challenge.
This is why CPO is not optics alone.
It is electro-optical realization.
Light may reduce distance and power, but package-level realization determines whether the architecture can scale.
Final question:
Are we evaluating optical interconnect only by power per bit, or by the full electro-optical realization path needed to make it manufacturable and reliable?
#OpticalInterconnect #CPO #LPO #SiliconPhotonics #AIInfrastructure #AdvancedPackaging #DataCenters #HeterogeneousIntegration #ElectroOpticalRealization #TrustedRealization
