            [0] => /forum/threads/when-local-closure-becomes-globally-wrong-by-dr-moh-kolbehdari.25715/
            [XF] => 2031270
When Local Closure Becomes Globally Wrong By Dr. Moh Kolbehdari
moh.kolb
Member
One of the most difficult problems in advanced packaging is not necessarily obtaining an accurate result.
It is determining whether several accurate results still describe the same physical system.
Consider a high-current heterogeneous package.
A die-level extraction may accurately represent the local interconnect.
The package model may accurately represent its own geometry.
The PCB PDN model may accurately calculate board-level impedance.
Thermal analysis may accurately calculate temperature using its own boundary conditions.
Electromigration analysis may accurately calculate lifetime using the temperature and current-density inputs it was given.
Individually, none of those analyses has to be wrong.
Yet the complete system can still be wrong.
The reason is that their boundary conditions are connected.
Temperature does not stay inside the thermal model​
A local rise in temperature changes conductor resistivity.
That changes current distribution.
Current distribution changes local power dissipation and electromigration stress.
The changing electrical state can alter the temperature distribution again.
So thermal and electrical behavior are coupled even when they are analyzed by different tools.
The package edge does not end the electromagnetic problem​
Return current does not recognize organizational ownership.
It follows physical geometry.
A package model can use one reference-plane assumption while the PCB analysis uses another.
A stackup revision can change a return path.
A geometry change can modify parasitics.
A board-level change can therefore invalidate assumptions that were perfectly reasonable when the package analysis was originally completed.
Model accuracy is not enough​
This is an important distinction.
A model can be highly accurate inside its own boundary and still become misleading when connected to another model that assumes a different:
  • geometry revision,
  • temperature state,
  • reference plane,
  • return-current path,
  • material condition,
  • operating state,
  • or abstraction level.
That means the emerging challenge is not simply simulation fidelity.
It is physical continuity across simulation boundaries.
AI/HPC makes the problem harder​
As systems move toward chiplets, HBM, advanced substrates and increasingly high current density, the coupling becomes stronger.
Current affects temperature.
Temperature affects resistance and reliability.
Impedance affects voltage behavior.
Voltage behavior affects switching and timing.
Mechanical and manufacturing variation shift the geometry underlying all of them.
The result is a system where local sign-off becomes progressively less equivalent to system sign-off.
That leads to a useful engineering question:
When one domain changes, which earlier conclusions are still physically valid?
The answer cannot always be obtained by simply running another isolated simulation.
Sometimes the harder problem is recognizing that a result which was once correct is no longer describing the current system.
That is why I think one of the next important challenges in heterogeneous integration will be moving from:
accurate models of individual domains
toward
physically consistent models of the complete path.
The package, board, PDN, thermal environment and interconnect are increasingly becoming different views of the same physical system.
