            [0] => /forum/threads/shift-left-with-s2c-prodigy-from-rtl-verification-to-real-world-software-validation.25627/
            [XF] => 2031270
Shift Left with S2C Prodigy: From RTL Verification to Real-World Software Validation
S2C Prodigy helps SoC teams run longer software workloads, connect real interfaces, and validate system behavior before first silicon.
Software-based RTL simulation remains indispensable for block-level verification and detailed debug. Runtime becomes a limiting factor, however, when teams need to boot an operating system, run long software regressions, or exercise realistic traffic across a large SoC. These workloads can require billions or trillions of design cycles, making simulation alone impractical.
Hardware emulation extends verification into early system-level RTL, with broad visibility and repeatable debug at MHz-class performance. As the RTL stabilizes, FPGA prototyping becomes the high-speed bridge to firmware, operating systems, real interfaces, and system-level workloads.
The S2C advantage: Prodigy combines scalable FPGA prototyping hardware with automated partitioning and control, multi-FPGA debug, host connectivity, ready-to-use interfaces, and enterprise resource management.
Complementary Roles, with Prototyping as the High-Speed Bridge​
Emulation and FPGA prototyping remain distinct. Emulation is optimized for early RTL verification and observability; FPGA prototyping is optimized for runtime speed, software execution, and physical connectivity. For many projects, the handoff to prototyping is where hardware/software integration begins to resemble the final system.
From Emulation to Prodigy​
The objective is not to make emulation and prototyping identical. It is to reduce friction as designs, interfaces, test environments, and software workloads move through the pre-silicon flow. Prodigy provides the higher-speed environment for the stages that benefit most from long execution runs, real I/O, and software-driven validation. S2C is releasing a dual-mode solution for prototyping and emulation pretty soon.
Figure 1. S2C Prodigy extends the pre-silicon workflow into higher-speed software bring-up, compliance testing, and system validation with real I/O.
Prodigy: A Complete Prototyping Environment​
Prodigy is more than a prototyping board. Its hardware platforms and toolchain address the practical work required to turn RTL into a reusable system-validation environment.
  • - Scalable prototyping platforms. Prodigy Logic Modules, Logic Systems, Logic Matrix platforms, and the latest S8 family support a wide range of design sizes and deployment models. The S8-100 supports up to 100 million ASIC gates per FPGA and up to 400 million gates in a four-FPGA system.
  • - Prodigy Player Pro. An integrated environment for compilation, automated and guided partitioning, debug setup, configuration, monitoring, and remote system control.
  • - Multi-Debug Module Pro. Concurrent deep-trace debugging across multiple FPGAs helps teams investigate system-level behavior without treating each FPGA as an isolated debug target.
  • - Prodigy ProtoBridge. High-bandwidth transaction connectivity between a host computer and the device under test supports hardware/software co-development and hybrid validation.
  • - Prototype Ready IP. More than 100 ready-to-use daughter cards, speed bridges and memory model reduces custom interface bring-up with pre-tested cards, integrated rate adaptation, and reference flows.
What an Enterprise Prototyping Platform Must Deliver​
The commercial value comes from solving the implementation problems that otherwise delay prototype availability and limit its usefulness.
Shift Software and System Validation Left​
Once the RTL is stable enough for a prototype build, firmware, drivers, operating systems, and application software can begin running before first silicon. Teams can exercise real interfaces, run longer regressions, reproduce software-driven corner cases, and prepare system demonstrations while design changes are still comparatively inexpensive.
Earlier integration reduces late-stage surprises and improves readiness for silicon bring-up. The approach is especially valuable for CPU and RISC-V, AI and HPC, automotive, communications, and cloud-oriented SoCs with large designs, long software workloads, or demanding I/O.
Evaluate Your Design on Prodigy​
Bring S2C a representative design partition, target interface configuration, and software workload. S2C's engineering team can help identify an appropriate Prodigy configuration and assess capacity, partitioning, debug, host connectivity, memory, and real-I/O requirements.
