            [0] => /forum/threads/john-carmack-on-how-high-bandwdith-flash-can-power-ai-inference.25466/
John Carmack on how high-bandwdith flash can power AI inference
Xebec
John Carmack is a famous "low level" programmer, and has switched to studying AI in recent years. I thought his recent post explains where HBF can address AI inference requirements:
.. [From John Carmack:]
Memory cost and capacity are significant issues for AI accelerators.
Unlike game rendering, model inference can have a deterministic memory access pattern. You don’t need “random access memory” at all for model weights, and you could tolerate cold-start latencies in the multiple milliseconds, as long as continuous reads were delivered at the necessary bandwidth.
NAND flash is over 100 times cheaper per GB than HBM, so there should be opportunity there, even after giving a flash controller a 1024 bit interface with HBM bandwidth.
You could make a specialized pin protocol that just supported pipelined transfer of full 16KB+ pages from the flash to program-managed accelerator scratchpad memory and improve per-pin performance over HBM, but it might be more convenient to make it still look like a true random access memory with very fragile performance characteristics, where anything but sequential reads falls off a 1000x+ performance cliff.
That has the advantage of automatically using existing cache hierarchies, and providing a natural path to update the flash memory with new model weights. With the stream-to-scratch interface, code has to be completely rewritten before it works at all, while the ram-emulation interface will start off just extremely slow, and you can incrementally sort out the changes for full performance.
There may be cases where there isn’t enough scratchpad SRAM to hold the weights for a layer, which might force you to deploy the old optical drive optimization technique of duplicating data in multiple places on a sequential read to avoid seeking, but there would be capacity to burn.
It might be possible to do something like cuda graph capture to record a memory access trace and have everything magically remapped to a linear sequence, but deploying programmer / agent elbow grease to manage transfers and access in a scratch ram ring buffer would be lower risk.
A split memory system consisting of some channels of flash and some channels of HBM will probably be suboptimal compared to a uniform memory, but it could be much cheaper, and allow much larger models to be run.
I think th case is strong for inference, but you have to stretch more for training. You can still linearize all the weight memory accesses, both reads and writes, but flash memory would quickly wear out from the writes, even if they were all perfectly page aligned. Replacing low-latency HBM with massively parallel cheap(er) DRAM at high latency might still be a worthwhile cost savings.
inference is the real cost. You only need to train model once per year. Selling cheap token is the key for the AI bubble not pop
From my perspective the picture for disaggregated transformer-based MoE inference is already evolving toward different memory for different functions.
HBM/DRAM on the accelerator:
• KV cache for current sequences.
• Router and attention state.
• A small cache of frequently used experts per layer
HBF in disaggregated memory nodes:
• Full expert weights for all layers (terabytes+).
• Next level of KV/context storage hierarch for very long contexts
Conventional SSD / object storage:
• Model snapshots and cold experts that are rarely used and can tolerate higher latency
Whichever type of memory the chip maker can make the most money from is what will be produced. Whatever is best for what ever application is not relevant.
