Agentic AI workflow cuts datasheet analysis and verification-testbench construction from an estimated four days to five hours while increasing test patterns and functional coverage
Summary
Using ChipAgents, eMemory reduced the engineering effort for datasheet analysis and verification-testbench construction, the two most labor-intensive stages of its functional-model verification flow, by approximately 80%, from an estimated four days to five hours. The agentic AI workflow also increased verification test patterns by 18% and improved functional coverage by 5%.
The deployment addresses a growing semiconductor engineering challenge: scaling the volume and complexity of IP development without proportionally increasing engineering resources. eMemory delivers more than 40 IP products each month with a small, dedicated functional-model verification team. The traditional process required engineers to manually interpret datasheets, identify inconsistencies, and build verification testbenches, work that was time-consuming, difficult to reuse and vulnerable to human error and implementation bias.
"Semiconductor companies are being asked to develop more products and more complex designs without a corresponding increase in engineering resources," said William Wang, Founder and CEO of ChipAgents. "eMemory demonstrates what becomes possible when AI agents move beyond code generation and deliver full-flow engineering outcomes. By automating the path from datasheet analysis through testbench generation, ChipAgents helped eMemory dramatically reduce manual engineering effort while expanding verification coverage."
eMemory deployed a ChipAgents-based agentic AI workflow on NeoFuse, its production one-time-programmable (OTP) NVM IP. The workflow automates three stages of functional-model verification: Datasheet Recognition, which extracts structured information from datasheets; Datasheet Quality, which identifies inconsistencies and documentation errors; and Testbench Generation, which automatically generates verification plans and UVM testbenches. Machine-readable rule decks guide agent actions throughout the process to help ensure consistent and repeatable results.
In testing, ChipAgents processed 10 NeoFuse datasheets in eMemory's internal datasheet format, containing 120 tables, figures and timing diagrams, and recorded zero mismatches when comparing extracted information with eMemory's internal specification database. The system also detected all 15 intentionally introduced datasheet errors, including parameter inconsistencies, spelling errors, and missing descriptions, with zero false positives.
ChipAgents then used the datasheet information to automatically generate a functional-model verification plan and UVM testbench. The generated verification environment identified additional scenarios that had not previously been considered, increasing test patterns by 18%.
"ChipAgents has gone beyond serving as an AI evaluator for eMemory’s behavioral model," said Max Yeh, CAD Director at eMemory. "It has also enabled our engineers to significantly enhance the quality and reliability of our IP datasheets." To the eMemory team, verification efficiency and consistency are critical to keeping pace with customer requirements. ChipAgents’ AI-native workflow gives eMemory engineers a more repeatable way to turn complex datasheets into verification assets, helping maintain quality at scale while allowing the team to focus its expertise where it adds the most value.
Beyond the controlled NeoFuse evaluation, eMemory deployed ChipAgents' Datasheet Quality workflow across 100 manually edited production datasheets. The system identified five documentation issues, primarily spelling and unit-notation inconsistencies, demonstrating how agentic AI can help engineering teams surface such issues before they propagate further into the development process.
The eMemory deployment points to an industry-wide shift in semiconductor engineering: agentic AI is moving beyond code generation to orchestrating complex, cross-domain workflows end to end. These workflows often require multiple engineers to interpret technical documentation, apply specialized design rules, and translate specifications into verification-ready assets. By automating more of this reasoning and execution with AI, engineering teams can shorten design cycles, improve verification consistency, and free engineers to focus on the highest-value decisions required to bring increasingly complex chips to market.
About eMemory Technology Inc.
eMemory is a leading global provider of logic-based non-volatile memory (NVM) silicon IP. Founded in Taiwan in 2000, the company provides a comprehensive portfolio of OTP, MTP, embedded Flash, emerging memory, and hardware security technologies for semiconductor designs across advanced and mature process nodes. Working closely with major foundries worldwide, eMemory’s silicon IP is widely adopted in AI, HPC, automotive, mobile, IoT, and other advanced semiconductor applications. Through its subsidiary PUFsecurity, eMemory also provides PUF-based hardware security solutions anchored directly in silicon.
About ChipAgents
ChipAgents is an Agentic AI platform that transforms specifications and code into production-ready RTL, verification assets, and automated root-cause analysis, dramatically shortening design and verification cycles. Founded in 2024, the company brings autonomous AI Agents into production semiconductor workflows, serving both design and verification engineers and embedded systems teams at leading semiconductor companies worldwide. The company is headquartered in Santa Clara, California. For more information, visit chipagents.ai.
FAQ
mstubbs@voxuspr.com
Voxus PR
Summary
- - eMemory deployed ChipAgents to automate critical portions of functional-model verification for its NeoFuse non-volatile memory IP, reducing the engineering effort for datasheet analysis and verification-testbench construction by approximately 80%, from an estimated four days to five hours.
- - ChipAgents automatically generated a functional-model verification plan and Universal Verification Methodology (UVM) testbench, helping eMemory increase verification test patterns by 18%.
- - ChipAgents processed 10 NeoFuse datasheets in eMemory's internal datasheet format with zero mismatches and detected all 15 intentionally introduced datasheet errors with zero false positives.
About ChipAgents
FAQ
- How is eMemory using ChipAgents for semiconductor IP verification?
- eMemory is using ChipAgents to automate functional-model verification for NeoFuse, its production one-time-programmable (OTP) non-volatile memory IP. The workflow analyzes datasheets, identifies documentation issues, and generates verification plans and UVM testbenches, reducing work engineers previously performed manually.
- What results did eMemory achieve with ChipAgents?
- eMemory reduced the engineering effort for datasheet analysis and verification-testbench construction by approximately 80%, from an estimated four days to five hours. The workflow also increased test patterns by 18% and functional coverage by 5%, helping a small verification team support more than 40 IP product deliveries each month.
- What parts of the verification process does ChipAgents automate?
- ChipAgents automates three stages: extracting information from datasheets, identifying inconsistencies and documentation errors, and generating verification plans and UVM testbenches. Machine-readable rule decks guide the process to help make verification more consistent and repeatable.
- How did ChipAgents perform in eMemory’s testing?
- ChipAgents processed 10 NeoFuse datasheets in eMemory's internal datasheet format, containing 120 tables, figures, and timing diagrams, with zero mismatches against eMemory’s internal specification database. It also detected all 15 intentionally introduced errors with zero false positives, demonstrating that the automation maintained verification accuracy.
- Was ChipAgents used beyond the controlled NeoFuse evaluation?
- Yes. eMemory deployed ChipAgents’ Datasheet Quality workflow across 100 manually edited production datasheets, identifying five documentation issues, primarily spelling and unit-notation inconsistencies. Catching issues earlier can help prevent them from carrying into later stages of development, where they become more difficult to address.
Contacts
Matt Stubbsmstubbs@voxuspr.com
Voxus PR
