Woodcliff Lake, NJ — July 9, 2026
Production-proven CSENT-RX core adds certified Safety-Enhanced version for automotive sensor-interface designs
Semiconductor intellectual property provider CAST today announced the availability of a Safety-Enhanced version of its SENT/SAE J2716 Receiver IP core that is certified as ISO 26262 ASIL B Ready.
The new certification expands CAST’s growing portfolio of Functional Safety IP cores and gives automotive ASIC and FPGA developers a compact, low-risk receiver for Single Edge Nibble Transmission (SENT) sensor interfaces. The SENT Receiver core has been in production use by multiple customers since 2022, and a leading automotive semiconductor customer has already selected the new Safety-Enhanced version for two ASIL B projects.
SENT is widely used for reliable, high-resolution digital communication from automotive sensors to electronic control units. The CAST CSENT-RX core implements a configurable receiver compliant with the SAE J2716 standard, supporting both synchronous and asynchronous sensors and enabling data reception from one or multiple sensors over a single SENT line.
The CSENT-RX core is now available in two versions: Standard and Safety-Enhanced. The Safety-Enhanced version implements additional protection mechanisms including CRC, extended parity, dual modular redundancy where needed, and fault-injection test support. It includes a Safety Manual, Failure Modes, Effects and Diagnostics Analysis (FMEDA), and an ASIL B Ready certificate issued by SGS-TÜV Saar GmbH. These deliverables help customers integrate the core into SoC-level safety analyses more efficiently and provide stronger evidence for meeting system-level functional safety goals.
To reduce host-processor load, the core provides fast-channel data mapping and an optional configurable receive FIFO. An external metadata port allows the system to add custom timestamps or other metadata into the received data packets. For synchronous sensors, CSENT-RX can generate programmable trigger pulses activated through software control or a dedicated hardware input, allowing up to four sensors to share a single physical SENT connection.
On the system side, CSENT-RX provides a 32-bit AMBA® APB or AXI4-Lite interface (optionally bridged to AXI5-Lite). It includes synthesis-time-defined reset values for control registers, a comprehensive interrupt set, and handshaking signals for external DMA controller integration. The design is LINT-clean, scan-ready, and uses a single clock domain for straightforward ASIC or FPGA implementation.
Technology-agnostic, the CSENT-RX can be mapped to ASIC technologies or any suitable FPGA device. Standard configurations can be implemented in as few as 6,000 ASIC gates, while Safety-Enhanced ASIL B Ready configurations range from 22,000 to 31,000 gates.
The ASIL B Ready CSENT-RX receiver expands CAST’s line of Functional Safety IP cores for automotive and other safety-critical designs, which includes processor, CAN, LIN, Ethernet MAC, SafeSPI, serial memory, and other interface cores. These give system developers a broad source for proven IP blocks that support safety-aware SoC development.
For pricing, evaluation options, or technical details, contact CAST at sales@cast-inc.com or visit the CSENT-RX product page.
CAST is a trademark of Computer Aided Software Technologies Inc.
Other trademarks are the property of their respective owners.
“Automotive developers increasingly need even small sensor-interface blocks to fit cleanly into the system safety case,” said Peter Dumin, product manager for CAST. “Already a proven SENT receiver, the ASIL B Ready Safety-Enhanced version of the core gives customers the added safety mechanisms, documentation, and independent certification evidence needed to reduce risk and accelerate ISO 26262-oriented development.”
Rich SENT Feature Set with Low Host Overhead
CSENT-RX supports SENT fast and slow channels; 4-, 6-, and 8-bit CRC checking; programmable glitch filtering; all SENT frame types; programmable fast-channel data length; Short and Enhanced Message Formats for the slow channel; and inverted SENT protocol operation.To reduce host-processor load, the core provides fast-channel data mapping and an optional configurable receive FIFO. An external metadata port allows the system to add custom timestamps or other metadata into the received data packets. For synchronous sensors, CSENT-RX can generate programmable trigger pulses activated through software control or a dedicated hardware input, allowing up to four sensors to share a single physical SENT connection.
CAST’s Automotive Interfaces Portfolio
The CSENT-RX core is part of CAST’s Automotive Interfaces IP family, which also includes a SENT Transmitter and most other popular bus and interface controllers.The ASIL B Ready CSENT-RX receiver expands CAST’s line of Functional Safety IP cores for automotive and other safety-critical designs, which includes processor, CAN, LIN, Ethernet MAC, SafeSPI, serial memory, and other interface cores. These give system developers a broad source for proven IP blocks that support safety-aware SoC development.
Availability
The CSENT-RX SENT/SAE J2716 Receiver IP core is available now for ASIC and FPGA implementations. It is delivered in synthesizable RTL source code or targeted FPGA netlist form, with a SystemVerilog testbench, sample synthesis and simulation scripts, documentation, and IP-XACT register definitions. The optional Safety-Enhanced package adds the Safety Manual, FMEDA, and ASIL B Ready certificate.For pricing, evaluation options, or technical details, contact CAST at sales@cast-inc.com or visit the CSENT-RX product page.
About CAST
Computer Aided Software Technologies, Inc. (CAST) is a silicon IP provider founded in 1993. The company’s ASIC and FPGA IP product line includes microcontrollers and processors; compression engines for data, images, and video; interfaces for automotive, aerospace, and other applications; networking stacks and offloading engines; various common peripheral devices; security primitives and comprehensive SoC security modules. Learn more by visiting www.cast-inc.com.CAST is a trademark of Computer Aided Software Technologies Inc.
