Array ( [content] => [params] => Array ( [0] => /forum/index.php?threads/does-ic-design-houses-contribute-significant-ip-or-advise-for-advanced-packaging.16391/ ) [addOns] => Array ( [DL6/MLTP] => 13 [Hampel/TimeZoneDebug] => 1000070 [SV/ChangePostDate] => 2010200 [SemiWiki/Newsletter] => 1000010 [SemiWiki/WPMenu] => 1000010 [SemiWiki/XPressExtend] => 1000010 [ThemeHouse/XLink] => 1000970 [ThemeHouse/XPress] => 1010570 [XF] => 2021370 [XFI] => 1050270 ) [wordpress] => /var/www/html )
Does TSMC have some edge for advanced packaging development over Intel and Samsung because TSMC's customers such as AMD and Apple work with TSMC for advanced packaging?
My opinion, the difference is not fab to fab, it is fab to OSATs. The wafer-to-wafer or die-to-wafer attach processes require a clean-room environment standard that is higher than what traditional C4-to-substrate attach requirements are, because the particle size relative to the pitch of the attach needs to be maintained for yield (eg: a particle that won't disrupt a 130um pitch C4 attach might definitely impact a 9um HBI attach). So Apple / AMD are using the advanced assembly from TSMC for the 'wafer level' attach points (including InFO, CoWoS, etc), and the fact they get the substrate assembly is nice-to-have. AMD very well could still use an OSAT for final substrate attach of their V-cache stacked CPUs, or for their floating-bridge dGPUs; those are still in the ~55-30 um pitch regime driven by HBM specs, but Apple's M1 Max has a Si bridge at 25um pitch, and the actual V-cache SRAM attach is ~10-12um (slightly looser than the 9um TSMC advertises for SoIC). IMO they cannot get this work done at OSATs because of the cleanroom spec requirements, and there would be immense costs to the OSATs to build that up "preemptively" (meaning, once there is obviously enough market business to support, the OSATs can fund it, but while it is still only 1-2 customers pursuing this tech, the ROI is too low).Does TSMC have some edge for advanced packaging development over Intel and Samsung because TSMC's customers such as AMD and Apple work with TSMC for advanced packaging?
How about Intel? Is Intel as competitive as TSMC for advance packaging in the future?My opinion, the difference is not fab to fab, it is fab to OSATs. The wafer-to-wafer or die-to-wafer attach processes require a clean-room environment standard that is higher than what traditional C4-to-substrate attach requirements are, because the particle size relative to the pitch of the attach needs to be maintained for yield (eg: a particle that won't disrupt a 130um pitch C4 attach might definitely impact a 9um HBI attach). So Apple / AMD are using the advanced assembly from TSMC for the 'wafer level' attach points (including InFO, CoWoS, etc), and the fact they get the substrate assembly is nice-to-have. AMD very well could still use an OSAT for final substrate attach of their V-cache stacked CPUs, or for their floating-bridge dGPUs; those are still in the ~55-30 um pitch regime driven by HBM specs, but Apple's M1 Max has a Si bridge at 25um pitch, and the actual V-cache SRAM attach is ~10-12um (slightly looser than the 9um TSMC advertises for SoIC). IMO they cannot get this work done at OSATs because of the cleanroom spec requirements, and there would be immense costs to the OSATs to build that up "preemptively" (meaning, once there is obviously enough market business to support, the OSATs can fund it, but while it is still only 1-2 customers pursuing this tech, the ROI is too low).
Intel has shipped products with their EmIB silicon bridge, which has a similar ~50um pitch, and Foveros which is logic-over-logic 3D stacked also using ~50um per their 2020 architecture day disclosures. Roadmap includes Hybrid Bonding, similar to TSMC SoIC, but nothing in-market on that yet, compared to the AMD V-cache. Samsung has also disclosed at VLSI/IEDM etc 2.5D / 2.3D / 3D assembly roadmaps including for Foundry customers, though I believe their focus (for HBI) is around DRAM stacking in support of HBM3 first and foremost.How about Intel? Is Intel as competitive as TSMC for advance packaging in the future?
I remembered 10% of tsmc's CapEx is for Package and Mask. But most of it should be in Package.Yes, TSMC has put a lot of money into packaging and will continue to do so. If I remember correctly 10% of the CAPEX is for packaging. Packaging keeps customers loyal to TSMC and with the importance of multi die packaging it is also a competitive edge. Tom Dillinger is our packaging blogger. We have been briefed on both TSMC and Intel packaging and do not see a clear advantage for either. TSMC has the advantage of wide customer collaboration. Intel has much deeper packaging experience. It will be interesting to see how Intel commercializes their packaging but one thing I can tell you is that a foundry with packaging offerings is much more competitive than one without, absolutely.
Yield & good die loss during packaging are very important besides the pitch numbers and other technical electrical or thermal mechanical parameters for beneficial product design or architecture applications - TSMC or its customers may have some claims on the adv. packaging yields.Yes, TSMC has put a lot of money into packaging and will continue to do so. If I remember correctly 10% of the CAPEX is for packaging. Packaging keeps customers loyal to TSMC and with the importance of multi die packaging it is also a competitive edge. Tom Dillinger is our packaging blogger. We have been briefed on both TSMC and Intel packaging and do not see a clear advantage for either. TSMC has the advantage of wide customer collaboration. Intel has much deeper packaging experience. It will be interesting to see how Intel commercializes their packaging but one thing I can tell you is that a foundry with packaging offerings is much more competitive than one without, absolutely.
