Daniel Payne
Stefan Wallentowitz, FOSSi Foundation
Tim Ansell, Google
Tim Ansell, Google
Array ( [content] => [params] => Array ( [0] => /forum/index.php?threads/an-open-source-pdk-for-130nm-process-node.12729/ ) [addOns] => Array ( [DL6/MLTP] => 13 [Hampel/TimeZoneDebug] => 1000070 [SV/ChangePostDate] => 2010200 [SemiWiki/Newsletter] => 1000010 [SemiWiki/WPMenu] => 1000010 [SemiWiki/XPressExtend] => 1000010 [ThemeHouse/XLink] => 1000970 [ThemeHouse/XPress] => 1010570 [XF] => 2021370 [XFI] => 1050270 ) [wordpress] => /var/www/html )
FYI, links to the EDA tools:You may want to check the design flow I have been working on, called Revolution EDA (RevEDA in short). It consists of Glade schematic/layout editor, Gemini DRC/LVS, Xyce circuit simulator and simulation GUI developed by me. Simulation GUI allows point-and-click selection of nodes and instances, saving of simulation state to a plain-text yaml file, backannotation of DC voltages, plotting of device parameters. It also has callback routines to define the layout dependent parameters in schematics. DC, AC, TRAN and Noise simulations are already possible. The RF performance measures such as IP1dB, IIP3 and IIP2 based on Xyce harmonic balance simulations are almost ready. Once S-parameter simulations were added, it would amount to a complete solution targeting custom IC design. I already created a short video to summarise its status:
By when is it expected to be released and how can update on same be received.Hello,
I am planning to release Glade/Revsemi combo with preliminary Sky130 support. I am afraid that it will not be free/open-source software though. However the cost will be around one fiftieth (1/50) cost of big names.
Hi,Hello engrvip,
I expect to have it ready in a few months. Is there a format such as a container you prefer?
And? Starting on 300mm is still way to expensive at a startup company volumes, especially if you are into mixed signals, or any other specialty process.Being a 200 mm foundry faces difficulty to get very advanced nodes.
